Mitsubishi introduced its newest Diamond 3D 1080p full HD home theater projector.
The Mitsubishi Diamond 3D projector is packed with features that create crisp, vivid, engaging 3D images that can display over 100-inch screens, creating a true theater experience. Powered by an SXRD cutting-edge reflective liquid-crystal optical engine, Mitsubishi adds its own algorithms and processing technologies to create high-brightness, high-contrast (up to 120,000:1 full on/full off) images that are smooth, dazzling and true to the original content.
A key element in projector performance is its lens, and Mitsubishi has incorporated extra-low dispersion glass into its six-piece, 17-cluster structure for higher functionality that minimizes chromatic aberration. The result is colors and details that are impeccably crystal clear.
With its auto-iris function, Mitsubishi's Diamond 3D home theater projector automatically sets the optimal aperture according to each scene, and its 120Hz refresh rate produces ultra-smooth transitions and amazing and life-like images. An independent management function allows adjustment to color characteristics such as hue, intensity and brightness individually (red, green, cyan, magenta and yellow), without affecting the other colors.
With a wide range of powered lens shift (100% vertical and 45% horizontal), this new Mitsubishi Diamond 3D projector is easy to install, even in a complicated room configuration. In some cases there may not be a need to turn the projector upside down in a ceiling mount, and its 1.8x powered-zoom range also gives installers additional installation flexibility.
At only 19dBa, this Diamond 3D projector is extremely quiet, so viewers can easily hear the movie, even in whisper-soft scenes, instead of an annoying projector hum. Two HDMI version 1.4 inputs support 3D signals, as well as provide easy set-up options for multiple video inputs, and its RS232 support offers plug-and-play connectivity with third-party remote operations.
Mitsubishi's new Diamond 3D projector also offers low cost of ownership with an estimated 4000-hour lamp life in low conservation mode. It also has a convenient and simple rear-access lamp design for easy lamp exchanges and a one-year limited warranty on the lamp, one of the best lamp warranties in the industry.
Pricing has not yet been set; availability is in November.
