Loudspeakers
Mission MX Series Speakers
Loudspeaker manufacturer Mission just announced the MX Series, an all-new range of speakers that exemplifies the company’s longstanding reputation for delivering excellent sound at affordable price points.
The range consists of five stereo models, two center channels and a multipurpose speaker:
Every speaker in the Mission MX Series is designed to deliver maximum sound for minimum outlay, in a practical design that’s purpose-built for modern living. Every model is specifically designed to work well when positioned close to a wall, making the speakers easy to position in typical rooms. They are also engineered to deliver a balanced sound both on- and off-axis, aided by an integrated treble waveguide that optimises dispersion, thus ensuring great sound wherever the listener is seated.
Mission MX-3 Floorstanding Speakers
Throughout the range, the bass and midrange drive units incorporate cones fashioned from an advanced fibre formulation, providing excellent strength and rigidity. These drivers hand over to Mission’s classic 25mm silk dome tweeter via a sophisticated crossover network.
In traditional Mission style, the standmount models have the tweeter positioned below the mid/bass drive unit, in order to aid time alignment. By placing the treble unit lower than ear level, the path length from the treble unit to the listener is longer than that of the mid/bass unit. As the treble unit dome is physically forward of the mid/bass unit cone, the difference in path length helps to equalise the acoustic distance. Similarly, the two-way MX-3 and MX-4 floorstanders position the tweeter between twin mid/bass units in a D’Appolito configuration, while the MX-5 is a true three-way design, with the tweeter sited between a single midrange unit and two bass drivers.
In keeping with the theme of practical living, every MX model has been designed for optimum performance with the drive units’ protective grilles in place. Traditionally, speakers sound best with their grilles removed, but this leaves the drive units vulnerable to damage. Although the grilles may be removed if the user wishes, the MX speakers have been deliberately tuned for grille-on use — thanks not least to the built-in waveguide — thus further enhancing both practicality and aesthetics.
The speakers sport a sharp, modern look in keeping with Mission’s customary design focus, coupling keyed tonal graduations with a selection of smart wood-grain finishes, able to slot neatly into any domestic environment. All the speakers may be single- or bi-wired (bi-wiring is recommended for optimum performance) and the lower section of the floorstanders may be mass loaded with dry sand to enhance stability and provide additional cabinet damping, thus further enhancing transient response.
The result is a range of speakers that is smart, practical and affordable. Most important of all, they communicate music with engaging energy and detail, bringing performances to life with all the vibrancy and finesse one expects of Mission designs.
The MX Series is the first Mission range to be designed from the ground up by Peter Comeau and his team since Peter was appointed as Director of Acoustic Design for IAG, Mission’s parent company, in 2009. Peter previously designed speakers for the Mission brand between 1999 and 2005, his work encompassing multi- award-winning designs such as the Mission 780 and 782. Not surprisingly, the MX Series has been something of a labour of love for Peter, as he explains:
“Mission’s ethos has always focused upon bringing audiophile performance down to an affordable level, and the MX Series exemplifies this. With the aid of sophisticated modelling tools and software, we’ve been able to maximise the performance of the MX Series using the most modern technology available. Yet Mission’s original slogan, “Music is the Master, Technology is the Slave,” has never been more apt. Months of fine- tuning through listening to a diverse range of music across multiple genres have allowed us to create, from each the MX loudspeakers, a vibrant and exciting insight into every musical performance. I’m convinced that, whichever MX speaker you select, you’l want to explore your whole music collection all over again.”
The Mission MX Series is available from late August. Cabinet finish options include black, cherry, rosewood and walnut.
Mission MX-S Mission MX-2 Mission MX-4 Mission MX-C1 Mission MX-1 Mission MX-3 Mission MX-5 Mission MX-C2
Enclosure type two-way reflex two-way reflex two-way reflex two-way reflex two-way reflex two-way reflex three-way reflex two-way reflex
Mid/bass driver 100mm advanced fibre cone 165mm advanced fibre cone 2x 165mm advanced fibre cone 2x 100mm advanced fibre cone 130mm advanced fibre cone 2x 130mm advanced fibre cone 3x 165mm fibre cone (1x mid; 2x bass) 2x 130mm advanced fibre cone
Tweeter 25mm silk dome 25mm silk dome 25mm silk dome 25mm silk dome tweeter 25mm silk dome tweeter 25mm silk dome tweeter 25mm silk dome 25mm silk dome
Frequency response 75Hz – 20kHz 52Hz – 20kHz 44Hz – 20kHz 75Hz – 20kHz 58Hz – 20kHz 48Hz – 20kHz 40Hz – 20kHz 56Hz – 20kHz
Nominal impedance 8 ohms 8 ohms 8 ohms 8 ohms 8 ohms 8 ohms 8 ohms 8 ohms
Sensitivity 87dB 87dB 90dB 87dB 86dB 89dB 90dB 89dB
Recommended amplifier power 25 – 100W 25 – 100W 25 – 100W 25 – 100W 25 – 100W 25 – 150W 25 – 200W 25 – 150W
Weight (per speaker) 3.6kg 7.7kg 23.7kg 5.6kg 5.1kg 19.2kg 28.3kg 8.9kg
Dimensions (HxWxD) 240 x146 x210mm 340 x206 x310mm 965 x206 x360mm 146 x420 x190mm 280 x172 x258mm 865 x172 x340mm 1050 x250 x390mm 172 x500 x240mm
About Mission
Mission has built a world-class reputation for advanced audio design since the company’s formation in Huntingdon, Cambridgeshire in 1977, with an engineering-led approach to product development that has resulted in some of the most popular and iconic loudspeakers ever devised.
Three things have always characterised Mission speakers. First, the cabinets and drive units use innovative materials and sport a distinctive, modern appearance. Second, the sound they produce is fast, detailed and engaging. Third, they deliver excellent sonic and material value for money.
Today, Mission continues to stretch the boundaries of what can be achieved at specific price points, pioneering technologies to create fresh, new designs. The brand now benefits from the unrivalled manufacturing facilities and global reach of parent company IAG, with all the component parts of every speaker made in-house. Yet the company’s roots remain firmly entrenched in Huntingdon, where much of Mission’s design, servicing and technical support work is still carried out. Peter Comeau, the architect of many classic Mission designs since 1999, leads the acoustic design team. All of which helps to ensure that Mission speakers remain as impressive today as they were when the company first established itself at the forefront of the burgeoning British audio scene some three decades ago.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
