Going Back to the Future with the Mission 778X Integrated Amplifier
The Mission 778x Integrated Amp and DAC offers a mix of nostalgia and modern connectivity options for only $549.
Mission 778x Integrated Amplifier
Around the time that I celebrated my Bar Mitzvah in 1983, British loudspeaker manufacturer, Mission, introduced its first integrated amplifier — the Mission 778. The 778 wasn’t ground breaking and it’s probably accurate to say that the industrial design was inspired by the earliest Naim amplifiers of the 1970s that featured a rather compact, half-width chassis.
12 months later, Mission introduced its Cyrus lineup of electronics and whilst there is a cult following overseas for the Cyrus One and Cyrus Two Integrated Amplifiers, the company wisely decided to focus on the loudspeaker side of its operations which are still going strong in 2022. Mission is part of IAG along with Wharfedale, Audiolab, Quad, Leak, Castle, and Luxman.
Mission introduced the 770 loudspeaker during the pandemic and it has already become one of the most popular modern “vintage audio” loudspeakers on the market.
Mission 778x Integrated Amplifier Front with Speaker
The new Mission 778X Integrated Amplifier is the third product in the series which includes two loudspeakers and it offers a mix of “Back to the Future” for a number of reasons.
The Mission clearly borrows some design cues from the Quad Vena Integrated Amplifier; the amplifiers are likely manufactured and assembled in the same facility overseas.
The Mission 778X is a revisit of a classic Mission amplifier concept that was the Mission 778 – an affordable integrated amplifier that offered simplicity in operation but over-performed in the driving of loudspeakers.
The new Mission 778X maintains the influence of simplistic operation, large tractile controls, and a multitude of inputs. It’s a compact, ’80s inspired integrated amplifier that is fully equipped to meet the demands of modern music lovers, from vinyl fans to digital streamers.
The 778X offers 65 watts (4 ohms) of power and includes a phono stage based around a JFET-based circuit with precise RIAA equalization. It’s optimized for MM cartridges.
Complementing the RCA line inputs are digital and coax connection options and a built-in Bluetooth receiver that supports the aptX and AAC codecs.
The 778X is also equipped with a high-performance ESS ES9018K2M Reference chip with ESS Technology’s 32-bit HyperStream architecture and Time Domain Jitter Eliminator; the internal DAC can decode up to 32-bit/384kHz PCM and DSD256.
As someone who owns the first generation Quad Vena and Audiolab 6000A Integrated Amplifiers — I’m slightly puzzled by this product which seems to offer features from both of them.
If the Mission 778X can offer the crisp and detailed presentation of its predecessors, they might have something that will appeal to very specific consumers looking for a mix of nostalgia and modern connectivity options.
Where to buy: $549 at Amazon
Mission 778x Integrated Amplifier Rear
Product Specifications:
Inputs1 x Coaxial, 2 x Toslink Optical, 1 x PC USB, 1 x Bluetooth (aptX/AAC),
2 x AUX,1 x RCA (Phono MM)
Outputs1 x Coaxial, 1 x Toslink Optical, 1 x RCA (PRE Out)
Sampling FrequencyOptical / Coaxial: 44.1kHz-192kHz;
PC USB:44.1kHz-384kHz(PCM) / DSD64, DSD128, DSD256
Preamplifier Section
Gain (max.)+0dB (Line), +47dB (Phono MM)
Input Sensitivity540mV (Line, Volume = 0dB)
2.5mV (Phone MM, Volume = 0dB)
Input Impedance10K (AUX); 47K//100pF (Phono MM)
Total Harmonic Distortion (THD)<0.003%
Frequency Response (ref. 1kHz)20Hz-20kHz (±0.1dB)
PRE Output Level2.1Vrms (max.)
PRE Output SNR>110dB (A-weighted)
DAC
D to A ConverterESS Sabre32 ES9018K2M
Resolution32-bit
Max. Sampling FrequencyOptical/Coaxial: 192kHz;
USB: PCM 384kHz / 11.2896MHz (DSD256)
Total Harmonic Distortion (THD)< 0.001% (1KHz @ 0dBFS)
Output level (0dBFS, 1KHz) 2.1Vrms
Power Amplifier Section
Gain+31dB
Rated Power Output2 x 45W (8 ohms)
2 x 65W (4 ohms)
Frequency Response (ref. 1kHz)20Hz-20KHz (± 0.5dB)
Total Harmonic Distortion (THD)<0.005% (30W / 8 ohms)
Input Sensitivity540mV (RCA AUX In)
2.5mV (Phono MM)
Signal-to-Noise Ratio (SNR)>108dB (ref. 45W, A-weighted)
Crosstalk @1K>80dB (ref.1W)
Standby Power Consumption<0.5W
Headphone Amplifier
Total Harmonic Distortion (THD)< 0.01% (1kHz, 50mW )
Output Impedance4.7 ohms
Load impedance20-600 ohms
General
Dimensions (mm) (W x H x D)236x98x380.6
450x392x175
Net Weight6.3kg
FinishBlack / Silver
Power requirements (depending on region)220-240V ~ 50/60Hz
100-120V ~ 50/60Hz
Standard AccessoriesPower Cord, Remote Control, User Manual, Antenna
Related Reading:
Best Budget Integrated Amplifiers
1 Comment
1 Comment
  1. Robert Lapin
    December 2, 2022 at 1:54 pm
    If you are going to clip your amp at 20khz, why even have a turntable? Even back in the late 60’s and early 70’s sounds as high as 27 to 28 khz were shown to color the audible range and to me seems the only reason to play vinyl is to recreate those analog harmonics up in the ultra sonic range.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
Advance Paris brings its range of affordable hifi components to the U.S. market, which feature blue VU meters and tube amplification.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
