MiLi Power Skin iPhone Case
World’s Thinnest External Battery & Protective Case for iPhone 3G and iPhone 3GS
MiLi, specialist in design and development of battery power and charging solutions, announces the release of the MiLi Power Skin external battery & protective case for iPhone 3G and 3GS. With MiLi’s aesthetic design, the Power Skin stays thin and slim while doubling the life of your iPhone battery. Available in 8 two-toned color combinations, the MiLi Power Skin delivers an affordable power solution in a sleek protective case.
Power Skin fits like a second skin to your iPhone providing protection and power without adding bulk. Equipped with a 1,200mAH lithium polymer battery, the Power Skin packs enough charge to double your iPhone’s battery life. Its low-profile casing provides durable protection against drops or mishaps while its high-gloss finish and two-toned color design adds a touch of style. With a simple slider case design the Power Skin is easily removed for use on speaker docks or other media players. Power Skin can be ordered by itself or a bundled Power Skin+ which comes packaged with a MiLi Pocketpal, the world’s smallest USB charger. Portable and easy-to-use, the Pocketpal USB charger features a small foldable AC plug that compacts into a lightweight pocket-sized cube compatible with any USB device.
MiLi Power Skin iPhone 3G Case
MiLi Power Skin features include:
  • World’s thinnest external battery and protective case for iPhone 3G and 3GS
  • Pass-through USB/mini-USB allows you to charge and sync your iPhone without removing case
  • 1,200 mAH battery capacity doubles the life of your iPhone 3G & 3GS
  • 8 two-toned color combinations using black, white, blue, green, orange, and silver
  • Apple certified with a one-year manufacturer’s warranty
MiLi
MiLi Power Skin PocketPal USB Charger
PocketPal features include:
  • World’s smallest mobile phone USB Charger
  • Foldable Plug for easy carrying
  • 100-240v Input with 1000mA output
  • 5 two-toned color combinations using black, white, blue, green, yellow, and pink
MiLi Power Skin ($69.95) and PocketPal ($19.95) can be purchased separately or bundled together for a discounted $79.95.
About Hali-Power Inc.
Based in Woodstock, NY, Hali-Power Inc. uses creative design, aesthetic appeal and innovative battery technology to develop powering and charging solutions for today’s mobile devices. MiLi’s mobile phone battery packs, cases and other accessories provide mobile phone users the tools they need to power through the day. Hali-Power is an Apple certified manufacturer. All of their iPhone, iPod and iPad products are licensed by Apple with genuine Apple plugs. MiLi uses Apple quality parts, built with gift quality appeal and fashionable colors that add life to the typically mundane battery and charger.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
