MilesTek: New Solid-Core RGB Cable, Digital Video Cable, Connectors, Tools & Kits
User-Friendly New 25 and 23 AWG Cables and Accessories Provide Essential Solutions for A/V Professionals; New Pricing Guide Details All Options
INFOCOMM ’08, LAS VEGAS, May 14, 2008 — MilesTek, a global distributor delivering a vast range of networking and A/V integration products, introduces a variety of new cables, connectors and accessories at INFOCOMM International 2008, the annual convention of the International Communications Industries Association, beginning in June.
Designed for Custom Installation and other A/V professionals, the new products include Solid-Center RGB Cables, Digital Video Cables, Compression Connectors for both types of cable, specialized tools and pre-packaged Connector Kits. All are described in a new detailed product guide, RGB and Serial Digital Solutions, packed with vital, full-color information, including specifications and prices.
MilesTek’s new solid-center Mini RGBHV Cables are available in 25- and 23-gauge sizes, and are complemented by 25 AWG and 23 AWG single-piece BNC and RCA Compression Connectors. The solid-center construction of the conductor provides the cable with better performance, lower attenuation, and longer signal distance than typical stranded-center conductor cables.
The solid-center 25-gauge cable has a small diameter and is ideal for short-run RGB installations. The solid-center 23-gauge cable is a little larger and offers higher bandwidth and longer distance capabilities. Both are also ideal for HD and digital applications, and are swept-tested to 3 Ghz. An added benefit of the solid-gauge cables is that they allow the use of MilesTek’s one-piece connectors, which simplify installations and save time on the job.
MilesTek also offers solid-core Serial Digital Coax Cables in RG59 and RG6 styles. Special shielding and construction allow the cables to be used in a wide variety of HDTV, broadband and baseband applications, including jobs involving DBS, RGB, component video and line-level audio formats. Most coax cables can only serve specific applications, like CCTV or CATV. MilesTek’s multi-purpose cables help reduce bulk cable inventories, and are complemented by MilesTek’s high-quality, single-piece Compression Connectors.
MilesTek’s new accessories include a lightweight Compression Tool for terminating any and all of the company’s BNC, RCA and F connectors; a Coax Stripper for perfectly stripping RG59, RG6, Mini RGB Coax, and all other appropriate cable types; and several unique Compression Connector Kits, which each include a 12-pocket Traytote tool bag, a Connector Case, a Compression Tool, a Coax Stripper, a round Cable Cutter, and a variety of connectors.
MilesTek’s new cables, connectors, tools and connector kits can be seen with the company’s other outstanding products at Booth C1952, Las Vegas Convention Center, during InfoComm. An essential reference for busy professionals, RGB and Serial Digital Solutions is available free of charge.
About MilesTek
Established in 1981, MilesTek has steadily grown from a supplier of custom-designed telecommunications products to become a global distributor delivering a vast range of low-voltage integration products. MilesTek products are used primarily in audio/video, networking, security and military applications. They consist of a complete line of bulk wire and cable products, connectors, connector termination systems, molded and custom assemblies, networking equipment, racks and enclosures, and a broad range of related accessories. MilesTek principally serves residential, commercial, education, telecom and government markets, and holds memberships in CEDIA, ICIA and BICSI. MilesTek is based in a 40,000-square-foot warehouse and assembly facility in Denton, Texas, just north of Dallas-Fort Worth. For further technical information, visit www.MilesTek.com
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
