Microlab MD332 iPod Speaker Dock
The Microlab MD332 iPod 2.1 stereo system with alarm clock, AM/FM radio and remote control is available for $119.99.
Features
  • All-in-one 2.1 speaker system with iPod docking/charging and FM/AM radio.
  • Reflex bass 5.25″ S12 woofer and 2 x 2.5″ V12
  • Full range speakers, designed by Denmark master, Peter Larsen.
  • Dock and charge your iPod, transform portable music to high fidelity standards instantly.
  • Clear highs and deep bass – ideal for all audio playbacks
  • Includes Clock radio with alarm set to your favourite iPod music or radio station.
  • Comes with remote control for easy operation and full front panel controls
Microlab MD332 iPod Speaker Dock Controls
Amplifier
  • Output power: 54 Watt
  • Distribution: 16 Watt x 2 + 22 Watt RMS
  • Harmonic distortion: 0.3% 1 Watt 1kHz
  • Frequency range: 40Hz – 20kHz
  • Signal/Noise ratio: >75 dB
  • Separation: >40 dB
  • Input sensitivity: 300mV
  • Fuse: T500mAL250V
Microlab MD332 iPod Speaker Grille
Speakers
  • High frequency drive unit: 2.5″ tweeter
  • Power: 30 Watt 4 ohm
  • Bass drive unit: 5.25″ woofer driver
  • Power: 30 Watt 8 ohm
Radio
  • Quartz-PLL Synthesizer
  • FM frequency modulation: 87.0MHz- 108.0MHz, Step
  • frequency: 0.1MHz
  • AM amplitude modulation: 522kHz – 1611kHz, Step
  • frequency: 9kHz
  • 15 preset stations to save your favourite radio stations
Clock
  • Digital LED display
  • Alarm set to iPod music list, or tuned radio station
  • Sleep and Wake (alarm) functions
Interfaces
  • iPod dock 30pin
  • AUX input: 2 RCA sockets
  • Radio: FM and AM antenna connectors
  • AC power: 110V – 240V ~ 50Hz, 300mA
Dimensions
  • Product: 424 (W) x 155 (H) x 242 (D)mm
  • Weight: 6.5 kg
  • Giftbox packaging: 465 (L) x 353 (H) x 190 (D)mm
  • Gross Weight: 7.1 kg
  • Gross Weight: 15.1 kg
Package contents
  • Microlab MD332 speaker system
  • 2 RCA to 3.5mm stereo cable
  • FM antenna
  • AM antenna
  • Remote control
MSRP: $119.99
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
