Microlab FC10 Triangle PC Speakers
Microlab FC10 Triangle Speaker System
Microlab just released the FC10 Triangle Speaker System, a low-cost powerful compact home and office stereo system, featuring two speakers, DSP Technology (Digital Signal Processing), a built-in amplifier, tweeter and woofer, and a unique modern white triangle shape for better design and sound.
Priced at only $77, the FC10 Triangle Speaker System provides high performance compact stereo speakers with a big 30 watt sound for the home or office. Easily connecting to PCs, tablets, phones, and other devices with a compact size of just 3” x 6.5” x 6” x 6.5”, the FC10 Triangle Speaker System is elegantly designed to fit on a desk or tabletop with a side panel for quick access to controls.
The FC10 Triangle Speaker features advanced DSP (Digital Signal Processing) Technology for Analog to Digital sound processing with minimum distortion and maximum precision; a powerful built-in amplifier using state-of-the-art digital processing for dynamic power; and high-quality tweeter and woofer drivers for the best full range sound. In addition, it features a bass reflex tunnel in each cabinet for strong low frequency sound with 30 Watt Output Power (Power Distribution 2x 15 Watt), a frequency range of 80 Hz – 20 kHz, with a metal grill front panel and rubber sides for an unprecedented vocal and depth in bass.
Microlab FC10 Triangle Speaker System with Macbook Air
Features:
  • Two high performance compact stereo speakers with big sound.
  • Advanced DSP Technology for high fidelity sound production with minimum distortion and maximum precision.
  • Unique stylish modern triangle design for better stereo sound effect with 2 triangle shaped speakers, with metal grill front panel and rubber side covers.
  • Stylish white color and design fits home and office.
  • Powerful amplifier uses state-of-the art digital processing for dynamic power.
  • Quality tweeter and woofer drivers.
  • Bass reflex tunnel in each cabinet to produce strong low frequency sound.
  • Easily connecting to PCs, tablets, phones, and other devices.
  • Side Panel easy access and control.
  • Compact size with dimensions: 3″ x 6.5″ x 6″ x 6.5″
  • Weight: 4.41 lbs.
  • Output Power: 30 Watt RMS.
  • Power distribution: 2x 15W RMS.
  • Harmonic distortion:< 0.5 percent 1W 1kHz. Frequency range: 80Hz – 20kHz. Signal/noise ratio: >65dB.
  • Separation: >45dB.
  • Speakers: Tweeter drive type: 0.5″, rated power: 5W, 8 ohm, full range driver type: 2.25″, full range driver rated power: 15W, 8 ohm.
  • Power input: DC.
  • Interfaces: Proprietary plug (output), 3.5 mm stereo (input)
  • Contents: two speakers, adapter, 3.5 mm-3.5 mm stereo cable, and user manual.
Availability & Pricing
Tthe Microlab FC10 is available immediately for $77 at Amazon, Newegg, Dailysteals, and Walmart, and distributed in the U.S. by Ma Labs.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
