CD Players
Michi Debuts Prestige Q430 Luxury CD Player That Leaves Out SACD
At $4,000, the Michi Prestige Q430 CD Player targets compact disc fans with ESS DAC and balanced outputs, but was omitting SACD playback a mistake?
Michi Q430 CD Player Angle
Rotel’s luxury Michi brand has expanded its digital lineup with the Michi Prestige Q430 CD Player, a full-function disc player designed for listeners who still take Red Book CD playback seriously. Unlike a transport-only design, the Q430 includes its own internal DAC while also offering a digital output for those who prefer to experiment with an external converter. Rotel already has a long track record in the two-channel component space, and while we’ve covered the brand extensively at eCoustics, the Michi line sits firmly at the company’s high-end tier.
The Prestige Q430 now enters a surprisingly competitive premium CD player category that includes impressive new models from Marantz, Quad, Hegel, TEAC, Shanling, and several other brands determined to prove that the compact disc still has plenty of life left in it.
In recent years, we’ve also covered several other Michi products including the Q5 CD Transport DAC (2024), the Series 2 Amplifiers and Preamplifiers (2023), and our full review of the Michi X3 Integrated Amplifier (2022); all of which reinforced the brand’s focus on premium construction, refined industrial design, and performance aimed squarely at the higher end of the hi-fi market.
Michi Prestige Line Adds the Q430 CD Player
The Michi Prestige line is designed to give listeners a clear entry point into ultra-high-performance components built with the same design discipline, power supply priorities, and craftsmanship expected of reference-level audio.
Drawing on more than 60 years of Rotel amplifier and circuit development, Prestige models aim to deliver effortless dynamics, exceptional clarity, and the kind of long-term reliability that serious two-channel systems demand.
Michi Prestige Q430 CD Player atop Michi X430 Integrated Amplifier
For 2026, Michi has introduced two new additions to the series: the Prestige Q430 CD Player and the X430 Integrated Amplifier. We covered the X430 in a companion article, but here the focus shifts to the Q430 CD Player, a premium disc player designed for listeners who still value dedicated CD playback in a high-end system.
Building on Michi’s heritage of precision engineering and industrial design, the Q430 combines a high-quality floating CD mechanism capable of playing Red Book CD, CD-R, and CD-RW discs with a meticulously designed proprietary power supply built in-house. Multiple stages of isolated voltage regulation reduce noise at the source, helping deliver exceptionally low distortion and a very quiet acoustic background where subtle details and ambient cues can emerge clearly from the mix.
At the heart of the digital stage is an ESS SABRE ES9028PRO 8-channel DAC, configured and optimized for stereo playback. The DAC is intended to deliver precise, neutral sound with wide soundstage presentation and strong resolution through both single-ended RCA and balanced XLR analog outputs, providing flexibility when integrating the player into a wide range of high-end systems.
Measured performance is equally ambitious. The Q430 is rated for ultra-low distortion (THD below 0.0006%) and a signal-to-noise ratio exceeding 120 dB, helping preserve transient impact and low-level detail even in complex musical passages. Channel separation greater than 105 dB at 10 kHz further supports precise stereo imaging and spatial detail, contributing to a convincingly three-dimensional soundstage.
michi-q430-back
Connectivity is straightforward but purposeful. In addition to its analog outputs, the Q430 includes a coaxial digital output, allowing the player to function as a dedicated CD transport when paired with an external DAC for listeners who prefer to experiment with different digital conversion stages.
However, there are a few notable omissions for a player positioned at this level. The Q430 does not support SACD playback, which some listeners may expect given its price category and the capabilities offered by competing models. In addition, the internal DAC cannot be used with external digital sources or streamers, a feature that has become increasingly common in 2026 as manufacturers try to broaden the utility of standalone disc players within modern streaming-focused systems.
For ease of operation, the Michi Prestige Q430 CD Player includes a wireless remote control that allows listeners to navigate album artwork, settings, and disc information displayed on the front panel’s full-color TFT display. The interface is designed to make browsing and playback straightforward while providing clear visual feedback during use.
michi-q430-internal
All of the internal components are housed inside a precision-milled aluminum chassis that reflects Michi’s design philosophy of durability, performance, and long-term reliability. The solid enclosure also helps minimize vibration and electrical interference, supporting stable disc playback and consistent sonic performance.
The Q430 measures 431 x 148 x 385 mm (17 x 6 x 15-1/4 inches) with a front panel height of 131 mm (approximately 5-1/6 inches). The unit weighs 8.8 kg (19.5 lbs), reflecting the robust chassis construction and internal power supply design typical of Michi components.
Comparison
Michi Prestige Q430
(2026)
Michi Q5
(2025)
Product TypeCD PlayerCD Transport/DAC
Price$3,999$7,499
CD Playback CompatibilityCD, CD-R, CD-RWCD, CD-R, CD-RW
Digital InputN/A1 x Coaxial
1 x Toslink
Analog Output1 x XLR
1 x RCA
1 x XLR
1 x RCA
Digital Output1 x Coaxial 1 x Coaxial
1 x Toslink
THD< 0.0006%< 0.0006%
Intermodulation Distortion  Not Indicated< 0.002%
Frequency Response20 Hz – 20 kHz (+0 dB, -0.3 dB)20 Hz – 20k Hz (+0 dB, -0.1 dB)
10 Hz – 70k Hz (+0 dB, -3 dB)
Channel Balance ± 0.5 dB± 0.5 dB
Channel Separation  Unbalanced (RCA) > 105 dB @ 10 kHz
Balanced (XLR)   > 110 dB @ 10 kHz
> 104 dB @ 10k Hz
Signal to Noise Ratio (IHF A-Weighted)Unbalanced (RCA)  > 120 dB
Balanced (XLR)   > 125 dB
> 115 dB
Dynamic Range > 99 dB> 99 dB
Input SensitivityNot Indicated0 dBfs / 75 ohms
CD OutputNot IndicatedDigital output (16-Bit / 44.1k Hz, 0 dBFS)
Analog Output Level / ImpedanceUnbalanced (RCA)  1.96 V / 100 ohms
Balanced (XLR) 4.2 V / 2 k ohms
Unbalanced (RCA) 2.3 V / 100 ohms
Balanced (XLR)  4.9 V / 4K ohms
Digital to Analog Converter  ESS ES9028PRO DACESS ES9028PRO DAC
Digital Output Coaxial OutSPDIF LPCM (up to 24-bit / 192 kHz)
PC-USBUSB provided for power and firmware updates only.USB Audio Class 2.0 (up to 32-bit / 384k Hz)* *Driver installation required
Support native DSD (up to 4X, 11.2M) and DoP (up to 2X, 5.6M)
Support MQA and MQA Studio (up to 24-bit / 384 kHz)
Power RequirementsEurope 230 V, 50 Hz
USA 120 V, 60 Hz
Europe 230 V, 50 Hz
USA 120 V, 60 Hz
Power Consumption 25 watts25 watts
Standby Power Consumption  < 0.5 watts< 0.5 watts
Full-color TFT DisplayYesYes
ControlWireless Remote, RS232, Ethernet, 12V TriggerWireless Remote, RS232, and Ethernet
Dimensions (WxHxD)431 x 148 x 385 mm
485 x 150 x 452 mm
(19 x 6 x 17-3/4 inches)
Front Panel Height  131 mm
(5-1/6 inches)
132 mm
(5-1/4 inches)
Net Weight 8.8 kg
(19.5 lbs)
23.5 kg
(51.8 lbs)
Finish  BlackBlack
michi-q430-cd-player-remote-control
The Bottom Line
The Michi Prestige Q430 CD Player is aimed at listeners who still value dedicated Red Book CD playback and want a component that matches the build quality and aesthetic of a high-end two-channel system. With its floating transport mechanism, ESS SABRE ES9028PRO DAC optimized for stereo use, balanced and single-ended outputs, and robust aluminum chassis, the Q430 is clearly designed to deliver refined CD performance rather than serve as a digital hub for multiple sources.
However, its focus is also its limitation. At $4,000, the Q430 lacks several features that competing players in this price category increasingly offer, including SACD playback and digital inputs that would allow the internal DAC to be used with external streamers or transports. For some buyers, those omissions will be difficult to ignore.
Ultimately, the Q430 is best suited for high-end two-channel listeners who still maintain a substantial CD collection and want a dedicated player that prioritizes build quality and straightforward disc playback rather than broad digital flexibility. For everyone else, especially those looking for SACD support or a more versatile DAC—the competition from brands like Marantz, Esoteric, TEAC, and Shanling may offer a more compelling case.
Price & Availability
Priced at $3,999, the Michi Q430 CD Player will initially be available in North America beginning March 2026, with global availability to follow early in the second quarter of 2026 through Rotel’s Dealer Network at €3,999 or £3,599.
For more information: rotel.com/product/q430
2026 Vincent Audio SA-32MK and SV-737MK
Vincent Audio updates its SV-737MK and SA-32MK with HDMI ARC and Bluetooth while retaining hybrid tube circuitry. Is losing Wi-Fi a mistake?
2026 ELAC Debut Reference 3.0 DBR63 stand-mount loudspeaker lifestyle 2026 ELAC Debut Reference 3.0 DBR63 stand-mount loudspeaker lifestyle
ELAC's $899 Debut Reference 3.0 DBR63 gets an aluminum tweeter, new aramid woofer, and premium styling. Is this the bookshelf speaker to beat?
2026 Fluance RT86 Turntable Angle Black Lifestyle 2026 Fluance RT86 Turntable Angle Black Lifestyle
The Fluance RT86 offers a carbon fiber tonearm, acrylic platter, and cartridge choices in a single-plinth design. Is saving $100 over the RT87 worth...
2026 Volumio Rivo Ultra Streaming Transport 2026 Volumio Rivo Ultra Streaming Transport
Volumio Rivo Ultra makes a $4,999 leap into high-end streaming with a 12-inch touchscreen, seven digital outputs, and no DAC.
2026 Campfire Audio Cascara Mk2 IEMs 2026 Campfire Audio Cascara Mk2 IEMs
At $549, Campfire Audio Cascara Mk2 IEMs retain its 10mm dynamic driver with revised tuning, a new design, and upgraded accessories.
2026 Eversolo DAC-R8 and C10 Master Clock 2026 Eversolo DAC-R8 and C10 Master Clock
Eversolo's $1,280 DAC-R8 packs proprietary R2R conversion and serious DSP, while its $1,880 C10 promises precision clocking. Is the extra box worth it?
Black Friday Gift Guide 2026
Black Friday gift ideas and real deals on headphones, speakers, hi-fi and home theater you'd actually enjoy at the lowest prices all year.
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
CD Players
CDs are making a comeback, and Esoteric isn't holding back. The $45,000 Grandioso K1XE SACD player adds a new G2 DAC and an optional...
CD Players
Musical Fidelity's B1xcd CD player arrives as CD sales surge, offering a dedicated transport, ESS DAC, and serious hi-fi engineering without streaming distractions.
As physical media (both CDs and vinyl) continues its surge in 2026, eCoustics Editor-in-Chief, Ian White takes a look at what's happening behind the...
CD Players
FiiO’s $170 DP11 adds AES, a CS43198 DAC, CD ripping and USB conversion because apparently nobody told the compact disc it was dead.
Marantz MCR 60n combines a CD player and streaming amplifier with HDMI eARC, MM phono and optional Dirac Live. Is this the all-in-one hi-fi...
Do the new Michi Prestige P430 preamp and S430 power amp offer a smarter route into Rotel’s high-end separates lineup?
