Mesanovic CDM65 Studio Monitor Speaker Incorporates WiSA Capability
The Mesanovic CDM65 Studio Monitor Speaker incorporates WiSA capability. Check out the details.
Mesanovic CDM65 Wireless WiSA Speaker
Wireless speaker technology is expanding the options consumers have to set up and enjoy a great listening experience. Bluetooth is the most popular wireless technology in use, but there are others, such as DTS Play-Fi, Denon HEOS, Yamaha MusicCast, BluOS/Bluesound, Sonos, and WiSA.
As part of their certification program,  WiSA has given Mesanovic’s new CDM65 Controlled Directivity Monitor Speaker, WiSA HT Interoperability Certification
Mesanovic & WiSA
Mesanovic CDM65 Wireless WiSA Speaker Back and Angle Views
The Mesanovic CDM65 is a powered three-way speaker with a built-in digital signal processor (DSP). The CDM65 is able to receive wireless audio from any WiSA transmitter, such as the WiSA SoundSend, and be paired for inclusion in a stereo or 7.1 channel setup if desired. This speaker is designed to be used in both professional studio and home environments.
Tip: All WiSA HT-certified devices, regardless of brand, can work together.
Designed for uncompromised performance and connectivity, The CDM65 can upload predefined tuning to the speaker such as the cardioid mode, which controls the speaker’s directivity down to 150Hz.  In this mode, the sound is directed toward the listener and away from the rear and side walls. This reduces undesired room effects and the need for extensive room treatment.
From Deni Mesanovic, founder of Mesanovic: “We are very proud to deliver precision accuracy, controlled directivity, and wireless connectivity in a no-compromise system that studio recording engineers and audio enthusiasts alike will appreciate,…Earning the Certification from WiSA and incorporating its HT technology adds immense value to this product and delivers next-generation wireless audio capabilities to our customers.
From Tony Ostrom, WiSA President: “The performance, quality, and engineering of Mesanovic’s studio-grade products are truly impressive,…The CDM65’s integrated WiSA HT technology enables the speaker to seamlessly integrate into any system configuration and deliver stunning sound wirelessly, whether used in a professional recording setting or to create the ultimate home theater experience.
Platin Stereo Hub
Mesanovic CDM65 WiSA Box Rear
In addition to being able to pair with any WiSA transmitter, the CDM65 also wirelessly connects to the Platin Stereo Hub, manufactured for Mesanovic.
Tip: The Hub can transmit 24-bit 48kHz/96kHz audio to Mesanovic CDM65 speakers with latency down to 2.6ms.
The Stereo Hub includes several source input options including USB Audio, HDMI (ARC), Digital Optical, Digital Coaxial, RCA, AirPlay, Spotify Connect, ChromeCast, and Bluetooth.
Tip: The Stereo Hub is also Roon Ready.
The Hub also incorporates a DSP processor which can be used with the Mesanovic app (app details and availability forthcoming). The app provides room correction and manual EQ to accommodate user preferences. A wireless remote control is included.
Platin Hub Remote
Platin Hub Remote
Tip: If you don’t want to use the CDM65’s WiSA capabilities, you can connect a wired analog source directly to each speaker via its XLR/Balanced input connection
Mesanovic CDM65 Speaker Rear Connections
CDM65 Specifications
Speaker Drivers:
  • HF: 1-inch aluminum dome waveguide tweeter
  • MF: 5-inch aluminum cone woofer
  • LF: 2 x 6.5-inches paper kevlar subwoofers
  • Amplifier Class: Class D
  • Power Output: (HF) 150W, (MF) 150W, (LF) 300W
  • Frequency Response: 40Hz-20kHz ±1.0dB, -3dB @ 36Hz
  • ​Harmonic Distortion (96dB SPL @ 1m): > 85Hz ≤ 1.0 %
  • Max SPL: 103dB from 40Hz per speaker before limiting (Tested at 1m with full bandwidth 20Hz-20kHz pink noise)
  • Crossover Points: 150Hz, 2300Hz
  • Standby Mode: The speaker will enter standby mode if no audio signal is detected for 20 minutes.
  • Connections: Balanced XLR Input, WiSA Wireless, Auto switching 115/230V
  • Dimensions (HWD): 15 x 8 x 14-inches
  • Weight: 32 lbs
Mesanovic CDM65 Wireless WiSA Speaker Front
Availability and Pricing
The Mesanovic CDM65 is priced at $2649 (ea)/$5298 (pr) and is available for pre-order, with shipping expected to start in May 2023. Mesanovic Contact and Dealer pages.
Tip: Mesanovic will offer a product package that includes two CDM65 speakers and the Platin Stereo Hub. If you pre-order before March 31, 2023, the Hub ($649 value) is free!
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Ask an Expert
If you can't get picture or sound from your TV or projector don't despair. Here are some debugging tips from our resident home theater...
An immersive and dynamic listening experience, with a bold omni-directional design that creates a spacious, all-encompassing soundstage.
Digital Music Systems
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
The Audioengine B1 has been updated with Bluetooth 5.3, aptX Adaptive, and 32-bit Audio, but still has the same $189 price tag
DAPs
The FiiO JM21 portable digital audio player supports high-quality music playback at an extremely low price.
Audio Pro can add more style to your home entertainment system with new walnut finish on its A28 wireless speaker at $650 pair.
A/V Furniture & Accessories
AUDIO Cu plug-in adapters eliminate long cable runs by sending up to 10 channels of audio over power lines already in your home.
The Onkyo Icon Series includes three components offering network streaming, MM/MC phono capabilities, Roon-Ready support, and Class A/B amplification priced below $2,000 each.
