Meridian Debuts Ultra DAC for Audiophiles: Finest Ever?
Meridian Ultra DAC - front
Meridian Audio today announced their ultimate, hand built Ultra DAC (Digital to Analogue Converter) that is capable of playing virtually any recording format including DXD, DSD64 and DSD128 (DoP), or MQA at up to 384kHz/24-bit. It is the first product in the world to include MQA Limited’s Hierarchical Converter Technology, which employs multiple converters to increase temporal resolution while reducing noise and quantization errors.
Connectivity options include USB 2.0, S/PDIF, TosLink, 75 ohm BNC, and AES3 on XLR, as well as Meridian’s Speakerlink and the award-winning Sooloos music-management platform, for the very best user-friendly experience.  One pair of balanced and one pair of unbalanced analogue outputs are also provided.
Meridian Ultra DAC - rear
Significant user features are provided, including LipSync, PC setup, and RS232, enabling integration with third-party systems such as Control4 or Crestron. The Ultra DAC is the first Meridian product to give users the option to select one of three upsampling filters when reproducing sources with a sample rate of 44kHz or 48kHz, such as CD or DAT. In addition, a dedicated clock card is included for the lowest possible jitter.
Another first for a Meridian product is the construction of the Ultra’s Dual Mono DAC card, which incorporates multiple regulated power supplies and eight-layer circuit boards with low-impedance ground-planes, for peerless isolation and the low-noise grounding that is critical to digital-audio accuracy. A fully linear power supply provides isolation from the AC supply, and DC-coupled output prevents degradation from AC coupling capacitors. Even the Ultra DAC’s front panel was designed for quiet operation, with non-ferrous construction, and a static LCD display chosen for its low electrical noise and ease of readability.
Chief Technical Officer at Meridian, Richard Hollinshead comments, “The Meridian Ultra Digital to Analogue Converter is the culmination of nearly two decades of research and engineering. With considerable connectivity options, user features, and format support, the Meridian Ultra DAC incorporates an extensive list of performance-enhancing technologies, including Dual Mono DAC cards, DSP filter options, upsampling, and apodizing. This dedicated DAC utilizes Meridian’s renowned audio expertise to set a new standard in the analogue realm.”
Price and Availability
The Meridian Ultra DAC is built by hand in the UK and is available in beautiful high gloss black as standard for $23,000. Other colour options are available using Meridian’s Select bespoke color service (+$1,000).
The world’s first public showing of the Meridian Ultra DAC will take place at the 2016 T.H.E. Newport Show, June 3-5, in the Sunny Components Room 1203.
User Guide (pdf)
Specifications
AUDIO OUTPUTS
• 2-channel balanced audio output
• 2-channel unbalanced audio output
• Outputs driven by four 192 kHz digital to analogue converters
• The output stage incorporates Hierarchical Converter technology [by MQA]
AUDIO INPUTS
• One USB 2.0 input for connection to a computer. Up to 384 kHz sampling and up to 24-bit precision
• Two 2-channel balanced AES3 XLR inputs. 44.1kHz to 192kHz sampling and up to 24-bit precision
• Two 2-channel 750 Ohm BNC coaxial inputs. 44.1kHz to 192kHz sampling and up to 24-bit precision
• Two 2-channel digital coaxial S/PDIF inputs. 44.1kHz to 192kHz sampling and up to 24-bit precision
• One 2-channel Meridian Speakerlink input. 44.1kHz to 192kHz sampling and up to 24-bit precision
• Two 2-channel digital optical TOSLINK inputs. 44.1kHz to 96kHz sampling and up to 24-bit precision
• One network input (Ethernet) for connection to a Meridian Sooloos System
• All inputs provide re-nameable legends
CONTROL SIGNALS
• Two Meridian Comms 5-pin 240° DIN sockets
• RS232 interface for maintenance
• Three 12VDC/100mA trigger outputs con gurable by source
CONTROLS
• FRONT-PANEL: Source, DSP, Display, Mute, Off, Volume +/-, Setup, and Menu keys
• REMOTE CONTROL: Via MSR+ (Supplied) and RS232
DISPLAY
• 20-character dot-matrix display with adjustable brightness and contrast
• Indicators for Emphasis and Phase
POWER
• Advanced linear power supply: 100V ac 50/60 Hz | 110-120V ac 50/60Hz | 220-240V ac 50/60Hz
• Max power consumption: 40 Watts
DIMENSIONS
• HEIGHT: 175mm [6.9in]
• WIDTH: 480mm [18.9in]
• DEPTH: 411mm [16.2in]
• WEIGHT: 16kg [35.2lbs]
CONSTRUCTION
• A DC coupled output – no degradation from AC coupling capacitors.
• New linear supply – for isolation from AC supply and increased reliability.
• Non-ferrous chassis and panels (aluminium construction) – linear hysteresis free magnetics.
• Quiet display – static LCD for low electrical noise.
• Black finish in metal and glass
• Custom Meridian Select colours also available
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
At $3,000, Meridian Ellipse may be the most advanced table-top luxury wireless speaker. Is it a juiced up Bowers & Wilkins Zeppelin?
The Meridian Audio DSP9 utilize a mix of class AB and class D amplifiers to drive all 6 drivers in a new cabinet design.
LG and Meridian join forces again to demonstrate what is possible in a sound bar that is one-third the size of previous models.
Digital Music Systems
MQA Support Continues to Grow at Munich HIGH END show MQA, the ground-breaking music technology originated by Meridian Audio, is now in active discussions...
Meridian Audio just released the reference-quality Prime Headphone Amplifier, which provides an extremely high quality analogue signal path, powerful amplifier, multiple inputs and special Analogue...
US and UK headquarters move to larger facilities Huntingdon, UK, July 2004–In line with the enormous success of Meridian Audio Limited’s new G Series...
Loudspeakers
New 36in tall DSP loudspeaker echoes lines and technology of flagship products Huntingdon, UK, November 2004–Internationally-acclaimed Meridian Audio Ltd, based in Huntingdon, near Cambridge,...
CES 2005 Booth #21707 LVCC South 01 Huntingdon, UK, December 2004–The 800 optical disc player from leading British consumer audio manufacturer Meridian has received...
