Meridian Prime Headphone Amplifier
Meridian Audio just released the reference-quality Prime Headphone Amplifier, which provides an extremely high quality analogue signal path, powerful amplifier, multiple inputs and special Analogue Spatial Processing for the ultimate in headphone listening. For further versatility, its preamplifier output can drive an external audio system or analogue active loudspeakers.
The unique new enclosure design echoes previous iconic Meridian designs such as the G Series and even Meridian’s original 100 Series. Its new, compact shape includes several special features and details. The metal enclosure is a dual-skinned design of interlocking extrusions, making the circuitry far less susceptible to interference. There are no screws – the box is opened by a hidden magnetic release mechanism. Even the curve on the volume knob was carefully chosen, recalling the compact M80 music system and a special flexible coupling links the knob to the shaft of the volume potentiometer towards the rear of the box, minimising microphony – mechanically-induced noise.
Meridian Prime Headphone Amplifier Rear
The Prime Headphone Amplifier can be powered by the wall-mounted supply provided or, for even higher audio quality, by the optional partnering Meridian Prime Power Supply, available early December. The use of this external power supply means that AC noise is kept well away from the pure analogue stages of the Headphone Amplifier.
Meridian’s Prime Headphone Amplifier, features unique Analogue Spatial Processing (ASP) technology to deliver more immersive, authentic sound to any headphones. Meridian’s advanced ASP transforms headphone listening, providing a more natural spatial soundstage that’s more like listening on loudspeakers.
Meridian Prime Headphone Amplifier PCB
Whether the listener chooses to listen on headphones because using loudspeakers is impossible, or simply because they prefer it, Meridian’s new Prime Headphone Amplifier represents headphone listening done right. In addition to an extremely high quality analogue path that is essentially remote-controlled from the front-panel for the shortest possible signal path and the ability to use almost any kind of headphones including separately wired types, the Prime Headphone Amplifier transform headphone listening from sometimes sounding “in your head” – into an experience much more like listening on loudspeakers
Features
  • All metal extruded chassis
  • 24bit/192kHz native conversion capability
  • Separate low-jitter crystal oscillators for 44k1 and 48k based sample rates (not a jittery synthesized clocks)
  • Asynchronous data transfer
  • Audiophile music grade power supplies and filter capacitors
  • 6 layer PC board
  • Direct-coupled outputs
  • Short signal path
  • Pure analogue throughput for analogue source
  • Analogue signal processing for optimized headphone listening: 3 options: Off, out-of-head, out-of-head with bass boost
  • Headphone capable output of 2.8vrms
  • Mechanical switches for source selection and analogue headphone processing mode.
Meridian Prime Headphone Amplifier Photo
Price and Availability
Meridian Prime Headphone Amplifier is available now for $2,000 (USD) on the Meridian website as well as authorized Meridian dealers.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
At $3,000, Meridian Ellipse may be the most advanced table-top luxury wireless speaker. Is it a juiced up Bowers & Wilkins Zeppelin?
The Meridian Audio DSP9 utilize a mix of class AB and class D amplifiers to drive all 6 drivers in a new cabinet design.
LG and Meridian join forces again to demonstrate what is possible in a sound bar that is one-third the size of previous models.
Digital Music Systems
MQA Support Continues to Grow at Munich HIGH END show MQA, the ground-breaking music technology originated by Meridian Audio, is now in active discussions...
US and UK headquarters move to larger facilities Huntingdon, UK, July 2004–In line with the enormous success of Meridian Audio Limited’s new G Series...
Loudspeakers
New 36in tall DSP loudspeaker echoes lines and technology of flagship products Huntingdon, UK, November 2004–Internationally-acclaimed Meridian Audio Ltd, based in Huntingdon, near Cambridge,...
CES 2005 Booth #21707 LVCC South 01 Huntingdon, UK, December 2004–The 800 optical disc player from leading British consumer audio manufacturer Meridian has received...
Huntingdon, UK, December 2004 — Meridian has been fully aware of DualDisc since its inception, having carried out extensive tests on the new music...
