Meridian HD621 HDMI Audio Processor Introduced
Meridian introduced the HD621 HDMI Audio Processor and 6-into-1 video switch allows all HDMI-equipped components to be fed via a single cable to the display. Going a step further, the processor also separates up to 8 channels of audio signal from the data stream at the HDMI source and provides audio-only outputs for connection to an existing Meridian Surround Controller.
HDMI (High Definition Multimedia Interface) connectors are a common sight on HD video and other equipment. Designed primarily to carry digital video, HDMI also carries digital audio. Unfortunately, having both audio and video on the same cable is not always convenient, nor does it deliver the maximum level of quality of which digital multimedia signals are capable.
Digital video signals have traditionally been the bane of those in search of the best audio quality. Common problems associated with the signal degradation include noise and even disrupting the signals themselves, causing muting, interpolation and other effects. In particular, digital video can leak into analogue audio circuitry, causing hum, buzz, noise and other unwanted artifacts.
Meridian’s new solution easily handles these problems allowing all components that deliver video via HDMI to a common destination. Thus, a single cable can be run from the HD621 to the display, while enhanced digital audio is fed to the sound system. The HD621’s audio outputs connect directly to an existing Meridian processor, offering complete and immediate system integration.
The HD621 includes Meridian’s comprehensive FIFO buffering and resolution-enhancement system, similar to that used in the acclaimed 800 Series. This process cleans up and audibly improves the quality of incoming PCM digital audio signals, ensuring that the audio extracted from the HDMI stream is of the purest quality. Meridian has also included a configurable lip-sync delay to compensate for the potential system latency caused by video processing which is commonly more time-consuming than audio processing.
The output section includes Meridian’s proprietary MMHR interface, an RJ45 connector that carries eight channels of balanced digital audio data at up to 96 kHz sample rate conforming to the Meridian Multichannel High Resolution (MMHR) specification, with encryption where required to carry high-resolution audio data. Additionally, the SmartLink output, four phono sockets each carry a pair of digital audio channel signals at up to 96 kHz sample rate. These are encrypted to Meridian High Resolution (MHR) specifications.
With ease of installation and integration in mind, the HD621 features a RS-232 serial port that enables it to be fully configured and integrated into a media system or touchscreen-controlled home theater, via serial command. There is also Meridian Comms (over DIN and BNC) for connection to a larger Meridian system. For the finishing touch, the HD621 is housed in an elegant black slimline 1U rack-mount panel for unobtrusive installation.
Price and Availability
The Meridian HD621 will be available January 2009 for $2,995.
February 2012 Firmware (3D) Update:
Meridian has launched brand new firmware that adds support for 3D video formats to its already impressive feature set, ensuring the HDMI Audio Processor remains the vital link in all surround-sound and A/V projects.
The 3D capable firmware is already being installed in all new production HD621 HDMI Audio Processors, and is now available to all Meridian retailers and installers who can update products already installed in customers’ homes and systems, bringing 3D support to their Meridian Digital Theaters and surround systems.
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
At $3,000, Meridian Ellipse may be the most advanced table-top luxury wireless speaker. Is it a juiced up Bowers & Wilkins Zeppelin?
The Meridian Audio DSP9 utilize a mix of class AB and class D amplifiers to drive all 6 drivers in a new cabinet design.
LG and Meridian join forces again to demonstrate what is possible in a sound bar that is one-third the size of previous models.
Digital Music Systems
MQA Support Continues to Grow at Munich HIGH END show MQA, the ground-breaking music technology originated by Meridian Audio, is now in active discussions...
Meridian Audio just released the reference-quality Prime Headphone Amplifier, which provides an extremely high quality analogue signal path, powerful amplifier, multiple inputs and special Analogue...
US and UK headquarters move to larger facilities Huntingdon, UK, July 2004–In line with the enormous success of Meridian Audio Limited’s new G Series...
Loudspeakers
New 36in tall DSP loudspeaker echoes lines and technology of flagship products Huntingdon, UK, November 2004–Internationally-acclaimed Meridian Audio Ltd, based in Huntingdon, near Cambridge,...
CES 2005 Booth #21707 LVCC South 01 Huntingdon, UK, December 2004–The 800 optical disc player from leading British consumer audio manufacturer Meridian has received...
