In-Wall Speakers
Meridian DSP320 In-Wall/In-Ceiling Speaker
Meridian DSP320 Speaker Exploded
Meridian just released a new in-wall/in-ceiling custom installation loudspeaker, model DSP320. The $2500 speaker is designed for in-ceiling use while also being slim enough for an in-wall set-up. It is designed to deliver similar tone qualities and compatible performance and it can also be easily integrated into systems that combine Meridian’s free-standing DSP loudspeakers with Meridian in-wall loudspeakers.
Like Meridian’s current DSP520, the DSP320 has been introduced specifically to deliver wide dispersion for maximum listening area, with minimum unwanted diffraction thanks to careful baffle and grille design. The on-board DSP provides thermal and dynamic bass protection with very accurate transients, ensuring that when the loudspeaker is played at high levels, even over prolonged periods of time, the loudspeakers always deliver a clean, detailed and accurate sound.
As with all Meridian Loudspeakers, the DSP320 is enabled with Meridian’s unique EBA technology (Enhanced Bass Alignment).
Meridian DSP320
Features
  • Compact 300mm (12in) square design only 100mm (4in) deep delivers full DSP loudspeaker performance in-wall
  • Back-box and frame system allows simple and easy installation, with the flexibility to ensure precise positioning
  • 2-channel, high power amplifier with linear power supply, DSP crossover, setup controls, IR sensor
  • Fire-rated rough-in box with AC connection and mounting hardware
  • Damped, high-rigidity aluminium acoustic enclosure with internal mineral-filled midrange enclosure
  • High rigidity aluminium baffle with Bass/Wide Range drive units and high contact magnetic grille clamping
  • White scrim under high precision plated steel, paintable, matt white grille
  • DSP-based design delivers superior performance to conventional designs – equivalent to an enclosure of eight times the physical volume.
  • Features “Racetrack” oval bass driver, and the same 85mm wide-range driver as the DSP520, for full-frequency response
  • All aspects of the design including baffle and grille have been developed for maximum dispersion and listening area plus minimum unwanted diffraction
  • Ideal with DSP520 and stand-alone Meridian DSP loudspeakers, with complementary sound.
Price and Availability
The Meridian DSP320 In-wall/In-ceiling Custom Installation Loudspeaker is available now for $2,500 each. The back-box and frame system is an additional $400.00 each.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
