Digital Music Systems
Melco Announces The N5-H50 Digital Music Library: High-End Munich 2023
Melco’s N5-H50 Digital Music Library features a 5TB HDD, fiber optic connectivity, and bulletproof construction.
Melco N5-H50 Digital Music Library
Following up on its recent release of its N1-S38 Flagship Digital Music Library, Melco is back with a step-down model, the N5-H50
The main difference between the two models is that while the N1-S38 incorporates a built-in SSD (Solid State Drive) for storage, the N5-H50 uses a more traditional, and less expensive HDD (Hard Disk Drive). Also, the N1-S38 provides five USB ports while the N5-H50 only provides three.
However, despite those differences, the N5-H50 shares many of the features of the N1-S38, including the ground-up design, platform, chassis, and casework. The mainboard used in the N1-S38 is also used in the N5-H50.
Melco N5-H50 Digital Music Library Front
N5-H50 Key Features
  • Cabinet Design: The N5-H50 features a precision-machined two-tone metalwork industrial design similar to that of the N1-S38. This provides highly stable chassis construction centered around a 3mm stainless steel base plate to minimize unwanted vibration.
  • Controls and Status Display: The N5-H50 includes high-quality illuminated positive-click fascia control buttons, crystal-clear easy-read OLED display panel, and concealed shadow lighting which changes color in response to operating status.
Tip: Just as with other Melco digital library components, the N5-H50 is hand-made in Japan.
  • Clock: The N5-H50 features an NDK system clock which supports precise low-jitter performance.
  • Connectivity (Non-USB): Industrial-quality RJ45 connectors are used for the LAN port and PLAYER ports. In addition, SFP Fibre (Small Form Factor Pluggable) connectivity allows the use of noise-isolating optical connectivity with compatible SFP-ready devices, including the Melco entry-level S100/2 and flagship S10 data switches.
  • Connectivity (USB): The N5-H50 includes 2 rear mounted and one front USB port with industrial-quality Amphenol connectors. The front and one rear USB port are version 3.0 compliant which supports high-speed speed data transfers, such as CD importing with Melco’s dedicated D100 drive/ripper, expansion storage, etc. The remaining rear USB port is version 2.0 compliant and is compatible with audiophile-grade DACs.
Tip: The technical difference between USB 2.0 and  3.0
  • IEC Power: A high-performance EMC-filtered IEC power connection is also included. The N5-H50’s power supply uses multistage linear regulation following a high-specification audio-grade toroidal transformer on a special vibration-cushion mount device.
Melco N5-H50 Digital Music Library Rear
N5-H50 Specifications
  • Storage Device: HDD (Hard Disc Drive)
  • Music Storage Capacity: 5 TB
  • Network Connectivity: LAN Port-Gigabit Ethernet (1000Base-T), Dedicated PLAYER port, Gigabit Ethernet (1000Base-T), SFP Port (1000 mbps MAX)
  • USB Connectivity: USB 2.0 port USB DAC-dedicated 2 x USB 3.0 port assignable as Import, Backup, DAC, or expansion (1 rear port and 1 front panel port).
  • USB Digital Music File Support: DSF, DFF, FLAC, WAV, ALAC, AIFF, and AAC
  • Additional USB Player Support:
    • 16-32 bit (PCM) to 384 kHz:- auto downsamples to suit connected DACs.
    • Gapless PCM playback
    • 1-bit (DSD) to 11.3 MHz Quad DSD, Markerless DSD support, Gapless DSD support
    • DSD to 32-bit PCM conversion selectable
  • Power Supply: Pre-set 220-240 V AC or 110-120 V AC dependent on locality
  • Dimensions (WHD): 440 x 82 x 344mm (17.3 x 3.23 x 13.54 inches)
  • Weight: 13kg (28lbs 11oz)
Tip: The front panel OLED display shows the player sample rate.
Price & Availability
The Melco N5-H50 is available to order now in Black or Silver at a price of £7,499/€8,999. U.S. price is forthcoming.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Ask an Expert
Just what is a network streamer? Our explanation and 9 digital streaming options from $99 to $2,500 that offer the best for less.
The Audioengine B1 has been updated with Bluetooth 5.3, aptX Adaptive, and 32-bit Audio, but still has the same $189 price tag
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
At $3,680, the Eversolo DMP-A10 music streamer packs in so much it just may be the Swiss Army Knife of network streamers.
Borrowing design concepts from TEAC’s top-of-the-line 700 Series, the standout feature of the UD-507 is TEAC’s new proprietary "TRDD5" (TEAC Reference Discrete DAC) designed...
iFi claims that the ZEN Blue 3 is the world's first lossless audio receiver and transmitter with speeds up to 1200kpbs.
Cambridge Audio introduces the EXA100 stereo integrated amplifier for $2,199 and the EXN100 Network Music Streamer for $1,799.
