I-MEGO MAZE On-Ear Studio Headphones
I-MEGO MAZE headphones
I-MEGO just released the Maze on-ear headphones, which features a soft memory foam cushion and semi-transparent vinyl record-like deco plate with an integrated metal slider. Inspired by a phonograph cylinder, the MAZE utilizes a patent-pending design that serves to enhance acoustics and provide larger-than-life sound.
The MAZE studio headphones feature the brand’s characteristic stellar sound provided by two high performance neodymium 40mm drivers, designed 30% thinner than a normal speaker, maximizing the air cabinet volume and resulting in better low end response. Constructed with a titanium diagram, the balanced drivers deliver an extraordinarily natural, lifelike sound with extremely low distortion.
The lightweight, collapsible headphones are made up of a premium blend of aluminum, leather and plastic providing maximum comfort for long listening sessions. For added convenience, the MAZE headphones include a soft carrying pouch, completely detachable volume and microphone control, and adapters to accommodate any audio resource.
Specifications
  • Driver Diameter: 2 x 40mm
  • Frequency Response: 20Hz – 20kHz
  • Sensitivity: 102 ± 3dB
  • Impedance: 32Ω
  • Cable Length: 120cm
  • Connector: 3.5mm stereo gold plug
  • Controller: Detachable music volume and microphone control
Price and Availability
The I-MEGO MAZE headphones are now available at www.I-MEGO.com and retail for $139.99.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
