McIntosh’s PS2K Powered Subwoofer is a Tower of Power: CEDIA 2023
458 lbs subwoofer standing over 6.5 feet tall contains four 13-inch woofers powered by 2,000 watts at a price you won’t believe.
McIntosh PS2K Powered Subwoofer Lifestyle
The high-end subwoofer market has become very competitive and that’s a very good thing for consumers; brands such as RSL, SVS, Klipsch, KEF, and REL have flooded the market with affordable options that allow consumers to add high-end bass performance to their 2-channel and home theater systems.
The CI market has given us innovative in-wall subwoofer options like the Theory Audio Design iws12-6 and iws12-9 and SVS 3000 In-wall.
And then there is the McIntosh PS2K Powered Subwoofer which is now available for $50,000 USD.
McIntosh PS2K Powered Subwoofer Drivers
Before bemoaning the price tag, understand that the McIntosh PS2K is aimed at a very specific customer; primarily owners of the McIntosh XCS1.5K ($40,000) XRT2.1K ($130,000/pair) and XRT1.1K ($60,000/pair) Loudspeakers.
Having experienced both loudspeakers at the WoM townhouse in Manhattan and factory in Binghamton, we understand the target audience for the subwoofer. These rather enormous loudspeakers are being used in very large listening spaces where some additional bass reinforcement is probably necessary.
The main showroom at WoM in NYC was an enlarged living room with 30′ ceilings and was the equivalent of an entire floor in many large homes.
The McIntosh PS2K is 25-5/16″ (64.3cm) x 78-5/8″ (199.7cm) x 28-7/16″ (72.2cm) and weighs 458 pounds; do not attempt to install this without the assistance of a dealer unless you want to end up in the hospital.
McIntosh PS2K Powered Subwoofer Front and Back
Tower of Power
The PS2K Powered Subwoofer is powerful to say the least. With four 13″ woofers and massive magnets at the heart of the subwoofer, the system uses McIntosh’s patented Low Distortion High Performance (LD/HP) Magnetic Circuit Design to significantly reduce distortion while increasing the driver’s power handling and efficiency.
Each of the four woofers is driven by a dedicated 500 Watt class D amplifier, which unite together to unleash a total power output of up to 2,000 Watts.
The amplifiers are calibrated to minimize distortion and produce clear, tight bass with astonishingly low distortion in even the most expansive listening spaces.
More than just a tool to deepen the bass of sound, the PS2K Powered Subwoofer further pushes the pinnacle of McIntosh craftsmanship with its innovative multi-layer carbon fiber cones.
Previously, carbon fiber cones were made from a single layer of carbon fiber that had a bit of flexibility that could negatively impact sound. The new multi-layered carbon fiber cones are now integrated into a joint with a voice coil that are very strong and can resist long extended excursion travel and creates extreme rigidity that forbids unwanted flexing.
“McIntosh has always prioritized top of the line sound quality, innovation, versatility, and longevity within its products,” said McIntosh President Charlie Randall. “The PS2K Powered Subwoofer is a true testament to all of the brand’s core principles. We are incredibly excited to see consumers’ reactions as they transform their listening spaces with this premium subwoofer.”
McIntosh PS2K Powered Subwoofer Back Close-up
In addition to its breathtaking design, the PS2K features a variety of connection options that are compatible with virtually any installation. Whether you have a two-channel stereo system or a multi-channel home theater setup, the PS2K offers balanced and unbalanced stereo inputs and outputs, as well as balanced and unbalanced subwoofer inputs and outputs.
Its daisy-chaining abilities allow for further connectivity for users who prefer to use more than one PS2K in a singular system.
The woofers are stacked atop the amplifier module, which features a power output meter that shows  the total output of the PS2K. The enclosure baffle is nearly 1-1/2″ (3.8cm) thick to ensure ultimate  rigidity and low vibration, and has a sealed box design to eliminate any potential port noises.
McIntosh PS2K Powered Subwoofer front VU meters
Big Performance
The PS2K is designed to effortlessly keep up with the output levels that can be obtained with our Reference Two-Channel and Reference Home Theater systems. These systems are powered by our 2,000 Watt tri-chassis MC2KW monoblock amplifiers and feature our large XRT2.1K and XRT1.1K speakers (or the previous generation XRT2K and XRT1K speakers); the PS2K will be a perfect match.
Flexibility
Once connected to your preamplifier, integrated amplifier, or home theater processor, a variety of built in filtering controls makes it so you can precisely tailor the PS2K to your listening preferences.
Adjustable Low Pass and High Pass filters let you set the crossover frequency. Two fully adjustable parametric EQ filters help compensate for unwanted effects caused by the room, furniture, or loudspeaker placement. Finally, Level Control and Phase adjustment knobs allow you to harmoniously blend the PS2K’s acoustic output with your existing audio system.
McIntosh PS2K Powered Subwoofer Rear Controls Close-up
The PS2K also comes with two indispensable McIntosh protection technologies. The first is Power Guard, a feature created to monitor the audio input signal coming into the amplifiers to make near speed of light adjustments to prevent harsh sounding clipping in real time.
The second, Sentry Monitor, is a fuse-less short-circuit protection circuit that disengages the amplifier’s output stage before the current exceeds safe operating levels and automatically resets when operating conditions return to normal.
The PS2K’s high black gloss finish, carbon trim, and aluminum base, along with its included glide feet for hard floors and spikes for carpeting will be unveiled for the first time at the world renowned CEDIA Expo on September 7, 2023.
Price & Availability
The PS2K Powered Subwoofer will be available at Authorized McIntosh Dealers starting in October 2023 with an MSRP of $50,000 USD.
For more information: mcintoshlabs.com
11 Comments
11 Comments
  1. ORT
    September 7, 2023 at 3:22 pm
    These here powerificationalizationized submariner tranzducerizers are made pacifically by McDeknife of MacNcheze’ for the usage and reproducters in the musicalifragelisticexpealidociousness of notable notes best exemplified in the Mary-Ann Trench depths of Bass fishing depth.
    As such it come equipoised wif a single BuM-Eatermeter which is simployed to better visufy the bootay-bustin’bum-bouncin’BASS as it drops to theretofore unheard of deepness beyond the free-range abilites of all but the mostest Midasized of hEaring decepticles.
    ‘n’ Sheeeeeit. – ORTwald Bates Reviewer of Adious cum louda per sixellence’ Esq.
    • Steffen styrbord
      September 10, 2023 at 2:50 am
      Its so big so fancyshmancydancypantsy that they dont even bother mentaning hz or db. Well if u want to waste money feel free to wire me som $ 🤣🤣
  2. David Purton
    September 7, 2023 at 9:27 pm
    $50,000! One born every minute. Not a measurement in sight…but it’s ok, it’s McCintosh, so dig deep.
    Not how a pro would approach spending $50,000 on bass units,class d amps,filters and eq.
    Plus it can only be a monopole. Hey Ho..the “impress your neighbours club” will be gagging for it.
  3. GordM
    September 7, 2023 at 10:41 pm
    Ludicrously massive overkill, unless you operate a private nightclub complete with go-go dancers and a mirror ball.
    • Ian White
      September 7, 2023 at 11:08 pm
      Gord,
      You live in NJ as well? Meet you at the Bing. 😉
      IW
  4. Steffen styrbord
    September 10, 2023 at 2:47 am
    500w pr 13inch. 50k$ i would rather stack svs and buy a car hahaha
    • Ian White
      September 10, 2023 at 11:53 am
      Steffen,
      Think about the kind of system you could assemble for $50K. As I mentioned in the article, it is aimed at a very specific type of customer who already has a sizable investment in McIntosh.
      Best,
      Ian White
  5. Damien
    September 17, 2023 at 4:52 pm
    McIntosh hype customers only, performance is surely worse than couple of well placed real subwoofers at 10x the price.
    • Ian White
      September 17, 2023 at 7:35 pm
      Damien,
      I’ll let you know what I think on Tuesday. Private audition in NYC. For $3K, I’d buy two SVS subwoofers and go on with my life.
      Best,
      Ian White
  6. Joe Nunca
    November 18, 2023 at 8:57 pm
    No worth it. McIntosh are A-holes to deal with as well. They treat their customer and dealers like shit. Plus for 50K can can by 4 to 6 other subs to fil a room that will kick the shit out of these in performance.
    • Ian White
      November 18, 2023 at 10:56 pm
      Joe,
      1. They don’t treat their customers and dealers like shit. I have first-hand experience with that.
      2. You sound triggered by the price. Nobody is forcing you to buy it.
      3. Have you heard this product?
      Best,
      Ian White
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
Digital Music Systems
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Podcasts
Rune Skov, Gryphon Audio Designs' Global Sales Director joins us on the podcast from Denmark to discuss the brand's Nordic Noir ethos.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
At $8,000, the McIntosh MSA5500 streaming integrated amplifier isn't for everybody, but it's hard not to be impressed with its styling and audio technology.
Hi-Fi Components
Bose Corporation has acquired McIntosh Group, the parent company of two iconic high-end audio brands; McIntosh and Sonus faber.
McIntosh is offering limited edition versions of its RS150 and RS250 Wireless Speakers with Grateful Dead branding for a premium price.
