The New McIntosh PS1K Subwoofer Costs the Same as a Tesla
At $35,000, the new McIntosh PS1K subwoofer combines 1,000-watts of Class D power with dual 13-inch drivers.
McIntosh PS1K Powered Subwoofer Lifestyle
In 2023, McIntosh announced its flagship subwoofer, the PS2K. A towering behemoth standing about 6 1/2 feet tall with the ability to push out 2,000 watts of power using four 13-inch drivers each powered by a 500 watt Class D AmplifIer. The PS2K also carries a $50,000 price tag.
As a follow-up for 2024, McIntosh has released a smaller model, the PS1K. However, don’t let that fool you as it carries a $35,000 price tag — the same price as a 2024 Tesla Model 3 after tax incentive.
Although the PS1K won’t actually drive you around, it will drive some of the finest high-end audio and home theater systems in the world. Let’s find out what it offers.
Dual 13-inch Drivers
McIntosh PS1K Powered Subwoofer Front, Rear, and Angle Views
To start, the PS1K incorporates two 13” drivers featuring McIntosh’s proprietary Low Distortion High Performance (LD/HP®) Magnetic Circuit Design. This reduces distortion and improves power handling. In addition, the use of Finite Element Analysis (FEA) supports enhanced linearity. The PS1K’s woofers are constructed with multi-layer carbon fiber cones for superior rigidity and sound clarity, resisting high flex outputs.
McIntosh PS1K Powered Subwoofer Parts Exploded
Amps & Enclosure
In order for the two 13-inch woofers to do their job they are powered by two 500-watt Class D amplifiers for a total of 1,000 watts of output in a sealed box design with a 1.5″ thick enclosure baffle that claims to eliminate port noise and vibration. According McIntosh, the PS1K’s bass is tight and clear for both music and movies, filling large spaces with ease.
The PS1K is designed primarily to complement McIntosh speakers but can used with any high-end system. The PS1K provides several input and output options for easy integration with stereo or home theater setups. With balanced and unbalanced subwoofer connections, adjustable filters, and parametric EQ, the PS1K can be tuned to suit large listening environments and user preferences.
McIntosh PS1K Powered Subwoofer Rear Panel
Power Control
Just like its bigger brother, the PS2K, McIntosh’s Power Guard, and Sentry Monitor are built into the PS1K to protect against overloading and short circuits, ensuring reliable, long-term performance. The PS1K’s eco-friendly signal sensing and Power Control technology enhance convenience and power management.
Finish
The PS1K comes with a high-gloss black finish, carbon trim, and an aluminum base. Glide feet for hard floors and spikes are included for carpets to support table placement.
McIntosh PS1K vs PS2K Subwoofers Compared Front
Comparison
PS1KPS2K
Price$35,000$50,000
Product TypePowered SubwooferPowered Subwoofer
Enclosure TypeSealed Sealed
Drivers 2 x 13-inches4 x 13-inches
Amplifier TypeClass DClass D
Power Output2 x 500 watts
(1,000 watts total)
4 x 500 watts
(2,000 watts total)
Max SPL> 113 dB > 120 dB
Frequency Response20Hz – 500Hz with LFE
20Hz – 100Hz without LFE
THD (Total Harmonic Distortion)Amplifier: 0.05%
Preamplifier (rear panel outputs): 0.005%
Amplifier: 0.05%
Filter (Crossover) FrequenciesHigh Pass: 40 Hz – 100 Hz Low Pass: 40 Hz – 100 HzHigh Pass: 40 Hz – 100 Hz Low Pass: 40 Hz – 100 Hz
EqualizationParametric: Two bands 30 Hz – 100 Hz, variable bandwidth and level +/- 8 dBParametric: Two bands 30 Hz – 100 Hz, variable bandwidth and level +/- 8 dB
PhaseContinuously VariableContinuously Variable
Input Sensitivity500mV unbalanced (0.5V) 1V Balanced) 500mV unbalanced (0.5V) 1V Balanced)
SNR (A-Weighted)Amp: 115dB
Preamp: 100dB
Amp: 115dB
Preamp: 100dB
Input Impedance20,000 Ohms Balanced
10,000 Ohms Unbalanced
Max Input Signal9V Balanced
4.5V Unbalanced
9V Balanced
4.5V Unbalanced
Power Control In 5-20 VDC Trigger5-20 VDC Trigger
Connectivity (Inputs)1 x Stereo Inputs (Balanced)
1 x Mono In (Balanced)
1 x Mono In (Unbalanced)
Connectivity (Outputs)1 x Stereo Out (Balanced)
1 x Mono Out (Balanced)
1 x Mono Out (Unbalanced)
SettingsLow Pass Filter
Phase Level
Parametric Equalizer (6 bands)
Meter
Logo
Power
Auto On/Off
LFE/Sub
Low Pass Filter
Phase Level
Meter
Logo
Power
Auto On/Off
LFE/Sub
Enclosure FinishHighly polished Piano Grade BlackHighly polished Piano Grade Black
Metal FinishAnodized Aluminum Base, High Durable Powder Coated Plate SurfacesAnodized Aluminum Base, High Durable Powder Coated Plate Surfaces
Subwoofer Dimensions (WxHxD)19-1/4” (48.9cm) x
50-1/16” (128.7cm) x
22-1/2” (57.2cm)
19-1/4 inches (48.9cm) x
78-5/8 inches (199.7cm) x
22-1/2 inches (57.2cm)
Subwoofer Base Dimensions25-5/16″ (64.3cm) x 28-7/16″ (21.43cm)25-5/16″ (64.3cm) x 28-7/16″ (21.43cm)
Weight370 pounds (167.8 kg)458 lbs (207.7kg)
McIntosh PS1K Powered Subwoofer Angle
Bottom Line
Every audio or home theater system needs a good subwoofer, and there are hundreds to choose from. However, McIntosh would not be living up to its reputation if it didn’t take things to an even higher (or stratospheric) level in both performance and price.
We were surprised when McIntosh introduced the megalithic PS2K subwoofer in 2023 for $50K. Even though it offers undeniable performance, its sheer size limits practicality except in extremely large rooms. So the smaller PS1K subwoofer may be a better alternative for cost-no-object buyers, even though it halves the power output and number of drivers.
McIntosh PS1K Powered Subwoofer VU Meters
VU Meters on the McIntosh PS1K show how many watts the subwoofer is using.
Price & Availability
The McIntosh PS1K is available in late October 2024 through authorized dealers with a MSRP of:
  • $35,000 USD
  • $50,000 CAD
  • €41,999 EUR including VAT
  • £35,995 GBP including VAT
2 Comments
2 Comments
  1. Edward Brumbaugh
    October 24, 2024 at 11:10 pm
    Interesting, look cool and knowing McIntosh, I’m sure they are awesome. Me, personally, I’d buy a pair of SVS PB17 – Ultra R|Evolution Subwoofers and pocket the other $24,000.00 … I could even splurge and run 4 independant PB17s and pocket the other $18K and be better off.
  2. Chris Boylan
    October 28, 2024 at 2:56 am
    I’ll take the Tesla. Oh wait, I already did.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
Digital Music Systems
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
At $8,000, the McIntosh MSA5500 streaming integrated amplifier isn't for everybody, but it's hard not to be impressed with its styling and audio technology.
