Preview: McIntosh’s MX200 AV Processor Supports Dirac Live, Dolby Atmos and DTS:X
At $6,000, the McIntosh MX200 delivers 11.2 channels of surround sound with higher resolution video pass-thru up to 8K.
McIntosh MX200 A/V Processor Angle Left
Although the McIntosh MX100 AV Processor was released in 2020, it looks like the engineering department in Binghamton has decided to release a replacement, the MX200.
MX200 Overview
Highly versatile, the MX200 A/V Processor offers up to 11.2 channels of signal processing and can be configured to support several speaker configurations from 5.1 to 7.2.4 to accommodate immersive audio formats such as Dolby Atmos.
The MX200 has a streamlined design that complements any home entertainment space. For video, the MX200 accepts 8K, 4K, or HD content from streaming services and Blu-ray and 4K Ultra HD discs.
McIntosh MX200 A/V Processor Back Angle
Four HDMI inputs and one HDMI output support 8K/60Hz and 4K/120Hz. Support is also provided for High Dynamic Range (HDR) formats including Dolby Vision, HDR10+, and HLG as well as 4:4:4 color spacing, Rec. 2020 color gamut, and 3D video pass-through. Audio support includes immersive audio formats such as Dolby Atmos and DTS:X.
In addition, compatibility with a variety of McIntosh home theater amplifiers and surround sound speakers provides users the ability to customize their home theater/home entertainment setup.
Tech Note: The MX200 takes care of the input sources and signal processing, but power amplifiers are required unless speakers are self-powered with XLR inputs. In addition, up to two powered subwoofers can connect to the MX200 via two subwoofer output (unbalanced RCA) connections.
McIntosh MX200 A/V Processor Front Top
Dirac Room Correction
The MX200 comes with Dirac Live Room Correction Full Bandwidth and its corresponding license, delivering advanced room adjustment and correction. An advanced room acoustic solution, Dirac Live enables users to optimize their sound systems and reduce unwanted effects introduced by the room. Utilizing purpose-built audio algorithms, Dirac Live provides:
  • Room correction with time domain correction using mixed-phase filter technology.
  • An easy-to-use, intuitive user interface and step-by-step guidance that allows for quick setup and personalization
Comparison
McIntosh MX200 and MX100 AV Processors
MX200MX100
Price (USD)$6,000$5,500
Device TypeAV Preamp/ProcessorAV Preamp/Processor
Channel Output Support11.211.2
Surround Sound Decoding Dolby Atmos
DTS:X
Dolby Atmos
DTS:X
Surround Sound ProcessingDolby Surround Upmixer
Neural:X Surround Upmixer
Color Support4:4:4 color spacing
Rec. 2020
4:4:4 color spacing
Rec. 2020
3D Support3D video pass-through3D video pass-through
HDR SupportDolby Vision
HDR10
HDR10+
HLG
Dolby Vision
HDR10
HLG
HDMI Support8K/60Hz
4K/120Hz
HDCP 2.3
4K/60Hz
HDCP 2.2
HDMI ARC/eARCYesYes
HDMI Transfer SpeedUp to 40 GbpsUp to 18 Gbps
Wired Connectivity (Inputs)4 x HDMI
2 x Digital Optical
2 x Digital Coaxial
2 x RCA (Unbalanced)
2 x XLR (Balanced)
4 x HDMI
2 x Digital Optical
2 x Digital Coaxial
Phono Input1 x Moving Magnet (MM)No
Wired Connectivity (Outputs)1 x HDMI
11 x XLR (Balanced)
2 x Subwoofer (RCA – Unbalanced)
1 x HDMI
11 x XLR (Balanced)
2 x Subwoofer (XLR-Balanced)
Room CorrectionDirac Live Full BandwidthAudyssey MultEQ XT32
Tone ControlBass, TrebleBass, Treble
DAC Support7 x 32-bit Digital-to-Analog Converters (DACs) 7 x 32-bit Digital-to-Analog Converters (DACs)
Frequency Response (+/- 0.5dB)20Hz – 20kHz20Hz – 20kHz
THD (Total Harmonic Distortion)0.005% maximum from 20Hz – 20kHz0.005% maximum from 20Hz – 20kHz
Third-Party ControlRS232
Web IP
IR Input
Control4
Crestron Home
RS232
Web IP
IR Input
Control4
Crestron Home
Network Connection (for control)1 x Ethernet1 x Ethernet
Rack Unit Size2U2U
Dimensions (WHD)17-1/2″ (44.45cm) (19″ (48.3cm with mounting ears)) x 4-5/16″ (11cm) (including feet) x 18-1/2″ (47cm) (including front panel and cables)17-1/2″ (44.45cm) (19″ (48.3cm with mounting ears)) x 4-5/16″ (11cm) (including feet) x 18-1/2″ (47cm) (including front panel and cables)
Weight17 lbs (7.7 kg)17 lbs (7.7 kg)
McIntosh MX200 A/V Processor Angle Right
Initial Impressions
McIntosh isn’t one of those A/V brands that brings out replacement models every year as they are designed from the ground up to last. However, in the A/V processor category, things have changed somewhat since 2020 to warrant a replacement model.
The MX200 provides all the connections, switching, and processing you might need to access your sources on your TV or video projector displays, but, as mentioned earlier in this article, the MX200 does not connect directly to speakers so external amplifiers are needed.
To take advantage of its 11-channel output, owners can connect 11 monoblock, 6 two-channel, two 5-channel + 1 monoblock, or other combinations of power amps that in turn power the speakers. The only caveat is the amplifier must allow for XLR connections, since the MX200 only provides XLR outputs.
Alternatively, customers can consider the McIntosh MHT300 Home Theater Receiver for $8,000 which provides processing and power in one box.
Price & Availability
The McIntosh MX200 is available for $6,000 USD through authorized McIntosh dealers with international pricing set at $8,400 CAD, €8,290 (including VAT), and £7,995 (including VAT).
Related Reading
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
While Record Store Day (RSD) is over for now, Mark Smotroff reports on his scores, some of which you still may be able to...
Think you’ve seen it all? These 25 essential American films are the ones every true movie lover should own.
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
