McIntosh MX180 A/V Processor Supports 8K & 9.1.6 Dolby Atmos
The $17,000 McIntosh MX180 A/V Processor delivers 8K, Dolby Vision, and Dolby Atmos support for home theater enthusiasts with deep pockets.
One of the key lessons learned during my reviews of the Theory Audio Design 5.2.2 system and Acurus Muse A/V Processor was the importance of the latter. The impact of the Muse on the overall performance of the $18,000 loudspeaker system was significant and I’m not sure I would have come to the same conclusions had I connected the system to the outputs of my NAD AVR which does a good job but is not exactly state-of-the-art.
McIntosh MX180 A/V Processor Angle
The McIntosh MX180 A/V Processor is designed for those assembling a home theater system in the $100,000 range and is likely to be paired with something like the McIntosh MC303 or MC255 multi-channel power amplifiers.
The $17,000 McIntosh MX180 is designed to be used in multiple home theater or 2.0 setups including video; I can envision it being the hub in a dedicated home theater space while someone else is watching sports on a 4K HDTV in the next room.
When you are spending that kind of money, flexibility and connectivity options are key. One can obviously achieve a similar result with a less expensive A/V Processor or AVR when it comes to switching, but the type of customer purchasing the MX180 is going to be using far more expensive amplification and will want a similar quality processor to match.
McIntosh MX180 A/V Processor Rear Angle
Features
  • Supports 8K/60Hz and 4K/120Hz on all 7 Ultra-High-Speed HDMI ports (5 inputs and 2 outputs)
  • Each HDMI port supports HDCP 2.3, 4:4:4 Color, Rec. 2020, Dynamic Lip-sync, and 3D Video pass-through as well as enhanced features Auto Low Latency Mode (ALLM), Quick Frame Transport (QFT), Quick Media Switching (QMS), and Variable Refresh Rate (VRR)
  • Supports a numerous high dynamic range formats including HDR (static HDR), Dynamic HDR, HDR10+, HLG, and Dolby Vision (including low latency)
  • Includes 16 balanced audio outputs for popular 15.1 or 9.1.6 surround sound speaker configurations among others
  • Compatible with leading 3D surround sound formats including Dolby® Atmos, DTS:X® Pro, and Auro-3D®
  • The 2 HDMI outputs can simultaneously output one source material to two separate screens, or can output different content from two different sources to two separate screens
  • One HDMI output that features both Audio Return Channel (ARC) and Enhanced Audio Return Channel (eARC) functionality
  • Comes with sophisticated RoomPerfect™ room correction technology to measure and adjust the audio output to compensate for the specific acoustic properties for the space
McIntosh MX180 A/V Processor Back
The McIntosh MX180 Includes a variety of digital and analog inputs and outputs including a Moving Magnet phono input.
The MX180 features some of the latest analog to digital convertor technology to maximize the audio quality of analog sources. Bass and treble controls offer further audio fine-tuning. The MX180 also has a two-channel Zone B output to send audio to a second zone in the house.
The MX180 utilizes the latest technological advancements in processing power to run cooler than previous McIntosh home theater processors and has a robust and simplified setup program that allows for customization and optimization based on specific home theater and speaker needs.
It comes with the iconic McIntosh design of a black glass front panel, control knobs, illuminated logo and custom aluminum end caps. The MX180 can be paired with a variety of amplifiers and speakers to make up a complete home theater system.
Pricing and Availability
Orders for the MX180 can now be placed with Authorized McIntosh dealers. Shipping is expected to begin in February 2022 to the United States and Canada, and to the rest of the world shortly thereafter. Suggested retail price (VAT, shipping and any customs duties related to current standards of individual countries are excluded): $17,000 USD.
For more information: mcintoshlabs.com
Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Samsung Neo QLED TV 2025 with Vision AI Samsung Neo QLED TV 2025 with Vision AI
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Samsung HW-Q990D. Samsung HW-Q990D.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Close To Perfect, Expanded Atmos Mix Takes Yes Surround Sound To Immersive Heights.
HDTV 4K & 8K TV
Philips has teamed up with Roku to deliver a budget priced 65-inch OLED TV (model 65OLED974/F7) that's only $1,299 at Sam's Club.
Ask an Expert
HLG is one of several HDR formats in use. Find out what makes if different and what this means for TV viewing
Ask an Expert
Dolby Vision gets all the HDR hype, but HDR10+ also has a lot to offer. Let’s check out more about this dynamic HDR format.
Ask an Expert
Dolby's version of dynamic HDR (High Dynamic Range) can make Ultra HD 4K content come alive in your living room or home theater.
Digital Music Systems
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
