McIntosh MTI100 Sun Records Turntable: Because Elvis Hated Cheap Gear and Cash Only Rolled With Tubes
McIntosh MTI100 Sun Records Limited Edition: integrated turntable with tube preamp, Bluetooth, and rare Johnny Cash vinyl for true audiophiles.
McIntosh MTI100 Sun Records Edition Integrated Turntable Top Angle View
Sun Records didn’t just record rock & roll—it set it on fire. Memphis was the crossroads, Sam Phillips was the match, and names like Elvis, Johnny Cash, Jerry Lee Lewis, and Roy Orbison were the gasoline. From gospel and blues to hillbilly stomp and western swing, Sun didn’t care what you called it—as long as it moved.
Now that same spirit gets the full McIntosh treatment. The MTI100 Integrated Turntable: Sun Records Limited Edition isn’t just a piece of audio gear—it’s a celebration of American music history, built by the tube-loving perfectionists in Binghamton. With a custom-printed Sun Records glass plinth and matching felt slipmat, this limited run is as collectible as it is functional.
It’s a fully integrated system—turntable, preamp, and amplifier in one—with Bluetooth, aux inputs, and that unmistakable McIntosh sound. Just add speakers and your favorite Sun-era LPs.
Only a handful will be made. And like Sun’s early catalog, once they’re gone—they’re gone.
mcintosh-mti100-sun-records-edition-front-top
The McIntosh MTI100 Sun Records Edition Rocks Harder Than a Drunken Jerry Lee on a Steinway
At a glance, the McIntosh MTI100 Sun Records Limited Edition looks like a turntable with a nice badge and a few tubes for show. Look again. This is a full-blown hi-fi system dressed in Memphis swagger and Binghamton brains—a modern-day music machine that just happens to spin records. It’s a one-box wonder for anyone who wants real audio performance without sacrificing their living room to a rack of separates.
And this isn’t just any MTI100—it’s a custom Sun Records Edition, complete with a stunning glass plinth printed with the legendary logo and a matching felt slipmat. It’s a tip of the hat to the birthplace of rock & roll, but built for today.
Under the hood, it’s packing a high-performance belt-drive turntable that plays both 33-1/3 and 45 RPM records. A 7-pound aluminum platter and matching tonearm sit atop McIntosh’s signature 3/8” glass and a 1/4” thick steel plate—because mass matters when you’re trying to keep the shakes of the modern world away from your vinyl. The industrial-grade synchronous motor keeps things locked in time with the precision of a Sun studio tape machine in its prime.
The cartridge? That’s a Sumiko Olympia Moving Magnet—punchy, dynamic, and just refined enough to do justice to your mono Elvis pressings and your Sunday jazz records.
mcintosh-mti100-sun-records-edition-turntable-top
But the MTI100 isn’t just about the turntable. There’s an 80-watt-per-channel (into 4 ohms) Class D amplifier inside—clean, efficient, and more than capable of waking up a pair of bookshelf or tower speakers. Two 12AX7 vacuum tubes run the main preamp section, while a separately shielded phono stage handles vinyl duties with the kind of care Roy Orbison reserved for heartbreak ballads.
Digital inputs? Covered—optical and coaxial. Bluetooth? High Definition 4.2 with an external antenna for better range and fidelity. Plug in your phone, stream whatever guilty pleasure you won’t admit to owning on vinyl, and it’ll still sound like McIntosh.
There’s an analog input for your old CD player or cassette deck, a subwoofer output to add some extra Memphis thump, and a front-panel headphone jack driven by McIntosh’s High Drive amp, which doesn’t care if you’re using vintage Beyers or planar cans from the future—it powers everything with ease.
You can control it all with the included remote or via the two aluminum knobs on the front panel. There’s a glowing McIntosh logo in the top glass (because of course there is), and the die-cast aluminum name badge on the front reminds you this isn’t some flash-in-the-pan reissue—it’s real McIntosh gear.
Limited. Custom. Built like a Cadillac with tubes under the hood. The MTI100 Sun Records Edition isn’t for everyone. But if you know where rock & roll was born—and you know how you want to hear it—this one’s already speaking your language.
McIntosh SESSIONS Volume 2: Pure Johnny Cash
McIntosh SESSIONS Volume 2: Pure Johnny Cash — More Than Just a Turntable
Johnny Cash’s legendary grit and gravitas get the McIntosh treatment on SESSIONS Volume 2: Pure Johnny Cash — a no-nonsense, 18-track collection of rare, early Sun Records recordings you probably haven’t heard this clear before. This is the Man in Black like you’ve never experienced: raw, rough, and remastered to sonic perfection.
This collaboration between Sun Records and McIntosh digs deep into Cash’s formative years, pulling out seldom-heard versions of classics like Train of Love, Ballad of a Teenage Queen, and yes, I Walk The Line. All tracks were painstakingly remastered from the original analog tapes, preserving that gritty authenticity while adding layers of richness and detail that only a high-end system can reveal.
Pressed on heavyweight 180-gram vinyl, spun at 45 RPM across two 12-inch records, this isn’t just another Cash compilation. It’s a vinyl event crafted for collectors, audiophiles, and anyone who knows that Johnny’s voice deserves to be heard in full, unvarnished glory.
Available now in the US and soon hitting McIntosh dealers worldwide — $150 gets you the kind of audio treasure that turns any setup into a front-row seat at Sun Studios.
mcintosh-mti100-sun-records-edition-top
McIntosh MTI100 Sun Records Edition — Key Specifications
  • Turntable Playback Speeds: 33-1/3 & 45 RPM (manual speed change via 2-speed pulley)
  • Motor Type: Permanent magnet AC synchronous — precise speed control synced to power line frequency
  • Platter: 7 lb machined aluminum for stable, vibration-resistant playback
  • Cartridge Included: Sumiko Olympia Moving Magnet (dynamic and punchy)
  • Amplifier Output: 80W per channel (4Ω), 50W per channel (8Ω) — Class D power with vacuum tube preamp warmth
  • Preamplifiers: Dual vacuum tube main preamp + shielded phono stage for pristine vinyl signal
  • Inputs & Outputs:
    • Analog input (1 unbalanced)
    • Digital inputs (1 coaxial, 1 optical)
    • Bluetooth 4.2 HD wireless with external antenna
    • Subwoofer output
    • Speaker outputs (4 or 8Ω compatible)
    • Front headphone jack powered by High Drive amp
  • Signal-to-Noise Ratio: 75dB (Moving Magnet phono), 90dB (High-level inputs)
  • Dimensions & Weight:
    • 19.25” W x 6.75” H x 14” D
    • 33.5 lbs (15.2 kg)
mcintosh-mti100-sun-records-edition-top-angle-crop
The Bottom Line
$8,500 is a lot for a turntable, no sugarcoating it. But the McIntosh MTI100 Sun Records Edition isn’t just spinning records—it’s handling everything else too. Amp, preamp, Bluetooth, digital inputs, sub out, headphone jack. Just add speakers and cables. That’s it.
The only thing this rig will really “hurt” is your wallet — but hey, at least your ears won’t suffer. And with Johnny Cash on vinyl to soften the blow, you might even enjoy it.
Where to buy:
4 Comments
4 Comments
  1. Anton
    June 19, 2025 at 5:16 am
    $8500 is ridiculous for that but I’m sure they will sell out very quickly.
    The plinth and top plate are interesting. Did VPI make this table?
    • Ian White
      June 20, 2025 at 10:33 am
      Anton,
      I’m not sure it’s ridiculous based on what comparable McIntosh components purchased separately might cost you. They did raise their prices recently between 10 and 15% because of the tariff situation — which is odd considering they make it all in America, including the key components.
      I do see some VPI elements.
      IW
  2. tonyE
    June 22, 2025 at 5:56 pm
    Pretty much something built for looks for people who have no clue about audio.
    Value and sound quality are, of course, out of the window.
    Sure, they’ll sell them all.. I mean, they could have put a MC in there…
    What I can’t believe is that this got posted here…. did you guys just copy the marketing ad-copy directly?
    • Ian White
      June 23, 2025 at 5:50 am
      Why did this get posted? Have you actually listened to the stock version of this?
      I have and it didn’t suck. Do you think VPI turntables are beneath your audiophile sensibilities?
      And it took some genuine effort to remove all of the fluff from their marketing copy.
      They will have zero issues selling every unit even at that price.
Bluesound POWERNODE 2025 Streaming Amplifier Lifestyle White
Digital Music Systems
With upgraded DirectDigital amplification, Bluesound's new POWERNODE is a 2 or 3-channel streaming amplifier with support for a center channel speaker and even a...
Cambridge Audio Evo 150 SE Streaming Amplifier Cambridge Audio Evo 150 SE Streaming Amplifier
The Cambridge Audio Evo 150 SE ($3,299) refines a proven streaming amplifier with better sound and features, making it a top contender under $5,000.
Cambridge Audio Melomania A100 Wireless Earbuds White Lifestyle Cambridge Audio Melomania A100 Wireless Earbuds White Lifestyle
Earbuds & In-Ear Headphones
The Cambridge Audio Melomania A100 delivers hi-fi sound, advanced ANC, and top-tier codecs like LDAC for $149—challenging AirPods Pro 2 and SoundPEATS with premium...
OXS Storm A2 Gaming Headphones Lifestyle OXS Storm A2 Gaming Headphones Lifestyle
OXS Storm A2 delivers budget-friendly wireless gaming headphones with 7.1 virtual surround, hybrid active noise cancellation, ultra-low latency, and versatile cross-platform support.
STAX SR-007S Electrostatic Headphones STAX SR-007S Electrostatic Headphones
At $2,200, the STAX SR-007S isn’t for the budget-minded, but they provide celebrated Electrostatic Technology for those looking for the optimum headphone listening experience.
Panasonic Z95B OLED TV Panasonic Z95B OLED TV
HDTV 4K & 8K TV
After a long absence from the US TV market, this Japanese tech giant is making a comeback.
Father's Day Gift Guide 2024 Best Tech and HiFi Gifts
Upgrade Dad's digital lifestyle with gifts he'll enjoy all year and beyond this Father's Day. New Hi-Fi, Headphones, Home Theater and more!
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
Discover the Clearaudio Compass, a German-engineered entry-level turntable built for audiophiles. Precision, style, and performance—ready to shake up Rega, Pro-Ject, and VPI.
MoFi and Fender drop an alder-bodied stunner with Strat DNA and serious playback chops. Built in the USA for vinyl junkies with a taste...
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Audio Cables
At £1,000, Chord Company's PhonoARAY can minimize external interference and ground issues that may affect turntable performance.
