Digital Music Systems
McIntosh’s MSA5500 Streaming Integrated Amplifier Might Be the Most Affordable Pathway to Blue Glass Nirvana
At $8,000, the McIntosh MSA5500 streaming integrated amplifier isn’t for everybody, but it’s hard not to be impressed with its styling and audio technology.
McIntosh MSA5500 Integrated Streaming Amplifier (Front)
It has been a rather busy 24 months for the most iconic brand in high-end audio. Not only did McIntosh Labs turn 75 and unveil a rather extensive range of new components, but it also reopened its House of Sound in New York City and was recently sold along with Sonus faber to Bose. The new McIntosh MSA5500 Streaming Integrated Amplifier puts a rather definitive final stamp on 2024 and whilst some might focus solely on the price — we actually think it might be the most affordable way to experience McIntosh’s trademark sound and build quality.
Streaming
On the streaming side, the MSA550 supports Apple AirPlay 2; Bluetooth; Chromecast; Spotify Connect; and TIDAL Connect (including TIDAL HiFi Lossless Quality).
Bluetooth streaming support includes Bluetooth 5.0; Advanced Audio Coding (AAC); Qualcomm aptX HD for hi-res audio playback; and Qualcomm aptX Adaptive.  The MSA5500 is also Roon Ready.
DAC
The MSA5500 employs an audiophile-grade digital-to-analog converter (DAC) to convert digital signals into the analog format needed for playback. The next generation, quad balanced, 8-channel, 32-bit DAC features a huge dynamic range and low distortion.
Physical Connectivity
McIntosh MSA5500 Integrated Streaming Amplifier Rear
The MSA5500 comes with 7 digital and 5 analog audio inputs for connecting audio components, such as a CD player or tuner, plus a Moving Magnet phono input to connect a turntable. There is also a set of balanced inputs.
In addition, the MSA550 also includes an HDMI (ARC) to provide better sound from compatible TVs than a TV’s internal speakers or most soundbars can provide.
Pro Tip: The HDMI (ARC) input will only play audio from a compatible TV. It will not pass video to or from a TV, or play audio from any non-TV source. TV must have an HDMI (ARC) output.
McIntosh MSA5500 Streaming Integrated Amplifier HDMI ARC Connection
McIntosh Amplification
On the amplifier side, the MSA5500 provides up to 100 Watts per channel into 8 Ohm speakers or 160 Watts per channel into 4 Ohm speakers.
Pro Tip: McIntosh suggests pairing the MSA5500 with their XR50 Bookshelf and/or XR100 Floorstanding Speakers which have been a part of their product offerings since 2012 and are still going strong.
The MSA5500’s internal amplifier can also be bypassed if desired via its preamp outputs if you want to connect high-power external amplifiers and use the MSA5500 as a preamp.
Pro Tip: A subwoofer output is also provided.
The MSA550 also provides a front-panel headphone output with Headphone Crossfeed Director (HXD) technology support. This feature mixes some of the left channel into the right channel, and vice versa, while applying filters and delays. This better approximates the listening environment as if the headphone user was listening to speakers.
McIntosh MSA5500 Streaming Integrated Amplifier Preamp and Subwoofer Outputs
Additional McIntosh Technologies
Additional McIntosh technologies designed to contribute to longevity and reliability include:
  • Power Guard:  This feature monitors the output signal for overdriving and makes real-time adjustments to the input signal to prevent clipping that could damage speakers.
  • Sentry Monitor: This feature disengages the output stage before the current exceeds safe operating levels and then resets automatically when operating conditions return to normal.
  • Monogrammed Heatsinks™: The heatsinks are connected to high-current output transistors that minimize thermal equilibrium lag (or warm-up) time. This helps keep the MSA5500 running cool.
  • Home Theater PassThru: This makes integration into a home theater setup easier.
  • Gold-plated Solid Cinch™:  These are speaker-binding posts that secure speaker connections.
  • Power Control:  This feature allows the sending of power on/off signals to connected McIntosh components for easy system power-up and shutdown
Just as with all McIntosh products, the MSA5500 is designed to provide years of listening enjoyment. Using the MSA5500 does not require downloading a smartphone app.
Specifications
Product McIntosh MSA5500
Price$8,000 USD
Number of Channels2 (left and right)
Power Output (per channel)100 W  (8 ohms) 160 W  (4 ohms)
Total Harmonic Distortion (THD)0.005%
Dynamic Headroom 1.8dB
Frequency Response+0,-0.5dB: 20Hz to 20kHz
0, -3dB: 10Hz to 100kHz
Input Sensitivity  (Phono – Moving Magnet)2.5mV
Input Sensitivity (Balanced/Unbalanced)0.5V/0.25V
Input Sensitivity (Power Amp Input)1V
Signal To Noise Ratio (Phono – Moving Magnet)82dB
Signal To Noise Ratio (Balanced/Unbalanced)95dB
Signal To Noise Ratio (Power Amp Input)110dB
Input Impedance (Balanced / Unbalanced) 20K/20K Ohms
Damping Factor:8 ohms: >200
4 ohms: >100
DAC8-channel, 32-bit/384kHz PCM/DSD, Quad Balanced
Streaming SupportApple AirPlay; Bluetooth; Google Cast (formerly Chromecast); Spotify Connect; and TIDAL Connect (including TIDAL Hi-Fi Lossless Quality)
Bluetooth SupportBluetooth ver 5.0, Advanced Audio Coding (AAC) standard; Qualcomm aptX HD. Qualcomm aptX Adaptive
Internet ConnectivityWiFi 6, Ethernet
Inputs1 x Balanced
4 x Unbalanced
1 x Phono Input Moving Magnet: (fixed loading)
2 x Digital Coaxial
2 x Optical
1 x MCT (McIntosh Controlled Transport)
1 x USB
1 x HDMI (ARC)
Outputs 1 x Unbalanced Variable Preamp Output
1 x Subwoofer Output
1 x Headphone Output
Home Theater PassThruYes
Speaker TerminalsStandard binding posts
Unit Dimensions (WHD)17.5  x  6  x 18.75 inches with vertical antenna
44.45 x  15.2  x  47.6cm with vertical antenna
Unit Weight 38 lbs (17.2 kg)
McIntosh MSA5500 Integrated Streaming Amplifier Front Angle Closeup
The Bottom Line
Streaming amplifiers are becoming increasingly popular with both audiophiles and mainstream listeners because they combine an integrated amplifier with a built-in DAC (Digital Audio Converter) and digital music streaming capabilities that are accessible via network (Ethernet or Wi-Fi) connectivity.
A quick look through our archives will reveal the reality that prices for network streaming amplifiers range from $300 through $30,000 and even higher.
Inexpensive options such as the WiiM Amp Pro meet the needs of a lot of music listeners, but don’t offer the power and connectivity of something like the MSA5500 that also offers a higher performance phono pre-amplifier and the build quality of a McIntosh amplifier.
There is no native control app which is one of the key selling points of something like the WiiM Amp Pro or Cambridge Audio Evo 150.
The $8,000 price is on the higher side, but a quick look through the McIntosh lineup reveals that the McIntosh MSA5500 might be the most cost-effective way to add some of the Binghamton magic to your listening.
McIntosh MSA5500 VU Meter
Price & Availability
The McIntosh MSA5500 will be available starting in December 2024 through authorized McIntosh dealers with an MSRP $8,000 USD / $11,200 CAD / €9,990 EUR / £9,995 GBP.
McIntosh MSA5500 Integrated Streaming Amplifier Angle Left Front
Related Reading
2 Comments
2 Comments
  1. Con
    December 15, 2024 at 1:09 am
    $8000 and no LDAC? Are you kidding?
  2. Man Jacovus
    December 15, 2024 at 3:11 pm
    And no output to a tape deck? Then what’s the point?
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Shanling ONIX Zenith XST20 SACD/CD Transport Shanling ONIX Zenith XST20 SACD/CD Transport
CD Players
At $2,399, the Shanling ONIX Zenith XST20 SACD/CD Transport is here to breathe new life into the "dead" audiophile formats of SACD and CD.
Sony's 2025 ULT wireless speaker line-up. Sony's 2025 ULT wireless speaker line-up.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
SVS SB-5000 and PB-5000 R|Evolution Subwoofers SVS SB-5000 and PB-5000 R|Evolution Subwoofers
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
Chord's new Suzi Pre preamplifier and Suzi power amplifier are scheduled for release Fall 2024.
At only $1,499 USD, the Naim CI-Uniti 102 feels like a streamlined Uniti Atom in a pair of skinny jeans.
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
The Audioengine B1 has been updated with Bluetooth 5.3, aptX Adaptive, and 32-bit Audio, but still has the same $189 price tag
The Onkyo Icon Series includes three components offering network streaming, MM/MC phono capabilities, Roon-Ready support, and Class A/B amplification priced below $2,000 each.
