McIntosh’s ML1 MKII Loudspeaker Delivers Modern Sound From A Vintage Design: High-End Munich 2023
The McIntosh ML1 MKII is a unique loudspeaker where vintage style meets contemporary sound.
McIntosh ML1 MKII Loudspeaker Pair
Vintage Audio has become a huge trend in the high-end space; loudspeaker companies including Klipsch, PSB, Mission, KLH, JBL, and Wharfedale have successfully introduced modern iterations of some of their most popular loudspeakers from the past fifty years. McIntosh is joining that list with the launch of its latest speaker, the ML1 MKII.
The McIntosh ML1 MKII is a unique loudspeaker where vintage style meets contemporary sound. It’s made in the USA and said to be reborn with a similar bass response as the initial version but without the need of an equalizer.
The ML1 MKII can be connected with amplifiers up to 600 Watts to fill the largest of rooms with life-size sound. It also features wide dispersion, which allows for an equal distribution of sound throughout the listening area.
McIntosh ML1 MKII vs. Original Loudspeaker With Grille
McIntosh ML1 MKII vs. Original ML1 Loudspeaker
Design
The external design of the ML1 MKII retains the same charm as the original ML1 with its oiled American Walnut solid wood cabinets and satin finish veneers. Whereas, internally, it features a full modern revamp to reflect McIntosh’s present-day high performance speaker technology. The ML1 MKII is a 4-way speaker that uses five separate speaker drivers to produce a uniform listening area and highly resolved sound quality.
  • Woofer: one 12″ woofer in a sealed enclosure with a polypropylene cone and dust cap with synthetic rubber suspension.
  • Lower Midrange: two 4″ lower midrange drivers in a sealed sub-enclosure also with polypropylene cones and dust caps with synthetic rubber suspension.
  • Upper Midrange: one 2″ soft dome upper midrange.
  • Tweeter: one 3/4″ Titanium dome tweeter (the same tweeter used in the McIntosh XR50 and XR100 speakers).
McIntosh ML1 MKII vs. Original Loudspeaker No Grille
Unlike the original ML1, the drivers on the new generation ML1 MMKII are positioned symmetrically so there is not a dedicated left and right speaker, eliminating the possibility of installing the speakers in the wrong orientation, and providing a more uniform listening area.
A specially milled transition plate houses the midranges and tweeter and allows them to be placed close together. Their close proximity to each other reduces off axis lobing of the sound field and places all the acoustic output that typically impacts imaging together in a small space. The transition plate also provides a strong foundation for the upper frequency units to reduce vibrations that might affect the sound. Internal cabinet bracing provides an airtight and separated enclosure from the 12″ woofer to further minimize vibrations.
McIntosh ML1 MKII Loudspeaker Parts Exploded
The upper midrange in the ML1 has low resonance and high-power handling capabilities; this allows the crossover point between the lower and upper midranges to avoid the 1kHz frequency that is critical to producing clear vocals. The crossover frequency of the tweeter reduces vertical lobing of the sound field and allows the ML1 to reproduce the recorded music more faithfully.
Deep Bass
With its 12″ woofer, the ML1 has an incredible bass response down to 30Hz, which is close to the lowest frequency the human ear can detect. A subwoofer will typically not be needed to achieve deep, punchy bass. You might see some similarly sized speakers with more woofers, but don’t be deceived by a higher woofer count as there is no substitute for woofer size. In fact, the single 12″ woofer in the ML1 has the same surface area as four 6″ woofers – and when it comes to the bass frequencies that a woofer produces, the larger the surface area the better to push all that air.
McIntosh ML1 MKII Loudspeaker No Grille
The 12″ woofer has been designed to work in an acoustic suspension design enclosure, just like the original. However, much has been learned since the original ML1 speaker, and modern design and simulation tools were used to develop design parameters that provide a bass response similar to the original but without the need for an external equalizer. The woofer also uses McIntosh’s patented Low Distortion High Performance (LD/HP®) Magnetic Circuit Design that significantly reduces distortion while increasing power handling and efficiency. The performance improvements from LD/HP are so vast that the 12″ woofer in the ML1 could rival woofers twice its size.
Crossover
The ML1 uses a custom-built crossover network designed by McIntosh engineers for performance and durability. Over-specified components ensure high power handling, while solid state, self-resetting protection devices prevent damage to any of the drivers. The crossover design separates the high and low frequency circuits, and each are available both bi-wiring or bi-amping as desired. All the power sent to the ML1 from your amplifiers is fed through McIntosh’s Solid Cinch™ speaker binding posts that easily but securely attach the speaker cables to prevent them from coming loose and possibly causing a short. The binding posts are gold-plated to prevent corrosion and ensure a quality signal is sent through your speaker cables.
McIntosh ML1 MKII Loudspeaker Rear
Matching Stand
Lastly, the ML1 comes with a matching stand that features a vintage die cast aluminum name badge on the base that matches the badges found on some of McIntosh amplifiers and integrated amplifiers.
The stand is designed to elevate and position the ML1 loudspeaker for optimum imaging and listening enjoyment. It comes with feet for use on hard floors, and spikes for use on carpet. The reimagined loudspeaker can also be set directly on the floor or placed on a sturdy piece of furniture.
“While we have been making loudspeakers for over five decades, the ML1 will always be our first and holds a special place in our hearts here at McIntosh,” said McIntosh President Charlie Randall. “We’re incredibly excited to showcase how far the brand has come over the more than half a century with the renewed ML1 and hope our community of listeners will enjoy listening to their favorite sounds on this classic remodel.”
McIntosh ML1 MKII Loudspeaker with Electronics
Price & Availability
The McIntosh ML1 MKII loudspeaker will be available for USD $12,000 per pair through Authorized McIntosh Dealers starting July 2023.
Related Reading:
11 Comments
11 Comments
  1. Donald Holland
    May 19, 2023 at 12:39 pm
    I owned a pair of ML1s, ML2s and ML4s which I traded up with Pyramid Audio in Anchorage, Alaska on a pair of XRT20s which I still own. Maybe I can trade up to a new pair of ML1s with the XRT20s. I do have a few other McIntosh components I have recently replaced with a new MA9500 and a new MCD12000 CD Player. I am anxious to hear the new ML1s
  2. ORT
    May 22, 2023 at 3:23 pm
    Gorgeous…Simply gorgeous. Like the beautiful Wharfedale Lintons, the McIntosh ML1 offer modern technological updates that are veiled beneath classic styling.
    Style is back in style, you say? Nay. Like James Bond, it never went away. It just needs to be shaken, and never stirred, to life.
    ORT
    • Ian White
      May 22, 2023 at 3:41 pm
      ORT,
      All of this new “vintage” audio has me clamoring for a DB8 or DB6. That being said…I’d settle for a NAIT 50 and some Lintons and be done with all of this. Possibly add a Michell Gyro SE.
      Ian Flemmi…I mean White
      • Ian White
        May 22, 2023 at 7:14 pm
        ORT,
        Just made a deal with the Devil. #summer2023
        IW
  3. ORT
    May 22, 2023 at 11:43 pm
    Ian –
    …ever dance with the Devil in the pale moonlight?
    HUZZAH!!!!
    BatORT
    • Ian White
      May 22, 2023 at 11:45 pm
      ORT,
      I have. And lost. Won the second time though. Messy.
      Frank Castle
      • ORT
        May 22, 2023 at 11:57 pm
        “Nonsense, I’ve not yet begun to defile myself.”
        ORT Holliday
        Dammit! Now (as if I needed a reason) I need to watch that film again!
        • Ian White
          May 23, 2023 at 12:58 am
          This industry needs an enema…
          And I’m just the guy to do it.
          IW
    • ORT
      May 23, 2023 at 1:46 am
      Superb!
      You remind me of a man.
      What man?
      The man with the power.
      What power?
      The power of hoodoo.
      Hoodoo?
      You do!
      Do what?
      Remind me of a man.
      What man?
      Give up?
      The Bat-chelor and the Bobby-Soxer…
      ORT
  4. NORMAN TOLBERT
    July 30, 2023 at 11:40 pm
    THE ML MK-2s LOOK FINE, AND NO DOUBT SOUND GREAT. THEY ARE, AFTER ALL, MADE BY McINTOSH –THE BEST IN THE UNIVERSE! WHEN I LOOK AT THE PHOTOS OF THIS SPEAKER ON MY COMPUTER,I SEE ONLY ML. WHY DO I NOT SEE ML MK2? THIS, I WOULD PREFER, TO DISTINGUISH IT FROM THE OLDER, FIRST GENERATION.
    • Ian White
      July 31, 2023 at 12:11 am
      Norman,
      It’s literally in every image posted. I have no idea what you are looking at.
      Best,
      Ian White
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Shanling ONIX Zenith XST20 SACD/CD Transport Shanling ONIX Zenith XST20 SACD/CD Transport
CD Players
At $2,399, the Shanling ONIX Zenith XST20 SACD/CD Transport is here to breathe new life into the "dead" audiophile formats of SACD and CD.
Sony's 2025 ULT wireless speaker line-up. Sony's 2025 ULT wireless speaker line-up.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
SVS SB-5000 and PB-5000 R|Evolution Subwoofers SVS SB-5000 and PB-5000 R|Evolution Subwoofers
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
Loudspeakers
KLH Audio and Victrola now exist under the same umbrella keeping two legacy American Hi-Fi brands alive.
Digital Music Systems
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
At $8,000, the McIntosh MSA5500 streaming integrated amplifier isn't for everybody, but it's hard not to be impressed with its styling and audio technology.
Without any public fanfare, Bose has recreated its legendary 901 Direct Reflecting Loudspeakers that we would like to see and hear in person.
