New McIntosh MA8950 and MA9500 Integrated Amplifiers Deliver Double the Musical Pleasure
The McIntosh MA9500 and MA8950 Integrated Amplifiers have been upgraded with some substantial changes and power is only part of it.
McIntosh MA8950 (left) and MA9500 (right) Integrated Amplifiers
McIntosh has powered through the past two years under very difficult circumstances in New York with incredible proficiency. As we discovered during our recent factory tour in Binghamton, the company has not allowed the pandemic and supply chain issues to derail some very important new product introductions like the MC3500 MKII Vacuum Tube Power Amplifier.
McIntosh is not like other brands and a healthy McIntosh Group is good for the entire industry because it lets us know if consumers are really spending on high-end components; and more affordable high-end products like Pro-Ject turntables and Rotel integrated amplifiers.
The brand new McIntosh MA8950 and MA9500 definitely fall into the more expensive product category but they are also two of their most popular products and were definitely due for an upgrade.
Shared features of the MA8950 and MA9500 include:
  • McIntosh signature large Blue Watt Meters and front panel dial controls.
  • McIntosh’s Power Guard® technology continuously monitors input and output signal and dynamically adjust input levels for maximum output while avoiding distortion and clipping that would cause speaker damage.
  • Fuse-less short-circuit protection technology (Sentry Monitor™) can disengage the output stage before current exceeds safe operating levels and resets automatically when operating conditions return to normal.
  • McIntosh Monogrammed Heatsinks™ made from high-quality materials provides excellent thermal conductivity and heat dissipation properties.
  • Home Theater Audio PassThru allows for easy integration into a home theater system.
  • High Drive headphone amplifier with Headphone Crossfeed Director (HXD®) for a more “speaker-like” listening experience – 1/4-inch headphone connection.
  • Power Control to send power on/off signals to connected McIntosh components for easy system power up and shutdown.
DA2 Digital Audio Module installed on both models – Roon Tested designation from Roon Labs.
McIntosh MA8950
McIntosh MA8950 Integrated Amplifier Front
McIntosh MA8950
Here are some of the additional features and specifications of the MA8950.
  • Power Output: 200 Watts x 2   (0.005% maximum THD from 20Hz to 20kHz)
  • Analog Audio Inputs: 1 Balanced, 6 Unbalanced, Moving Coil and Moving Magnet phono inputs.
  • Digital Audio Inputs: 2 Digital Coaxial, 2 Digital Optical, 1 HDMI (ARC), 1 USB, and 1 MCT (used with McIntosh SACD/CD transports).
  • 5-Band EQ/Tone Control: +/- 12dB range in 2dB increments at 30Hz, 250Hz, 500Hz, 2kHz, and 10kHZ.
  • Amplifier Weight: 75 pounds.
For complete features and specs, check out the official MA8950 product page.
McIntosh MA9500
McIntosh MA9500 Integrated Amplifier Front
McIntosh MA9500
In addition to the above, here are some of the additional features and specifications of the MA9500.
  • Power Output: 300 Watts x 2 (0.005% maximum THD) from 20Hz to 20kHz
  • Digtial Audio Inputs: 2 Digital Coaxial, 2 Digital Optical, 1 HDMI (ARC), 1 USB, and one MCT (used with McIntosh SACD/CD transports).
  • 8-Band EQ/Tone Control: +/- 12dB range in 2dB increments at 25Hz, 50Hz, 100Hz, 200Hz, 400Hz, 1kHz, 2.5kHz, and 10kHZ.
  • Speaker Terminals: McIntosh Solid Cinch Speaker Binding Posts
  • Amplifier Weight: 101 pounds
For complete features and specs, check out the official MA9500 product page.
McIntosh MA9500 Integrated Amplifier Rear
McIntosh MA9500
McIntosh MA8950 Integrated Amplifier Rear
McIntosh MA8950
Availability & Pricing
The McIntosh MA8950 and MA9500 can be purchased through Authorized McIntosh Dealers at the following prices: $12,000 (MA9500),  $9,000 (MA8950).
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
Digital Music Systems
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Advance Paris brings its range of affordable hifi components to the U.S. market, which feature blue VU meters and tube amplification.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
At $8,000, the McIntosh MSA5500 streaming integrated amplifier isn't for everybody, but it's hard not to be impressed with its styling and audio technology.
