Master & Dynamic MW60 Wireless Over-Ear Headphones
Master & Dynamic MW60 Gunmetal
Master & Dynamic just announced their first wireless headphones, the MW60 over-ear model, which take several cues from company’s flagship MH40 over-ear Headphones, while establishing their own distinctive, elegant style. Signature Master & Dynamic design elements, including a minimal industrial aesthetic, premium materials and tactile components, are apparent throughout. While most wireless headphones trade metal for plastic, the Master & Dynamic MW60s combine patent pending stainless steel componentry with their “form-meets-function” machined all-aluminum antenna to create uncompromised durability, style and best-in-class signal range.
Master & Dynamic MW60 Black/Gunmetal
The MW60 Wireless Over Ear Headphones accommodate multi-point connection, allowing connectivity to two devices at once for a smooth transition from phone to computer. They come with a 16-hour lithium ion rechargeable battery, but can still be used in wired mode if the battery dies.
The MW60 is made from heavy grain cowhide leather in the headband and memory foam in the ear pads, which are wrapped in soft lambskin leather. An omnidirectional microphone is integrated into the ear cup for crystal clear calling. Tactile controls, ergonomically positioned on the ear cups, pay homage to elements found on high-end timepieces, allowing for effortless media control toggling. Other sophisticated features include Bluetooth 4.1 with AptX high quality audio, custom 45mm neodymium high-performance drivers and stainless steel foldable hinges that allow the folded unit to fit in the palm of the hand.
Master & Dynamic MW60 Brown
Price and Availability
The new MW60 Wireless Over Ear Headphones will be available in silver/brown and gunmetal/black for $549 on November 17, 2015.
Technical Specifications
  • Model: MW60
  • Dimensions: 200mm x 185mm x 50mm
  • Drivers: 45mm Neodymium
  • Impedance: 32 ohms
  • Weight: 345g
  • Materials: Premium grain leather, lambskin leather, stainless steel, aluminum
  • Cable: Detachable 2.00m Standard Cable, Micro USB Input Cord
  • Headphone Connection: 3.5mm Passive Audio input micro USB charging/firmware update input
  • Ear Coupling: Circum-aural
  • Microphone Type: Omni-directional
  • Machined Aluminum Antenna
  • Ear Pads: Detachable lambskin memory foam
  • Bluetooth Profile: Bluetooth 4.1 with Aptx high quality audio
Master & Dynamic MW60 Brown Folded
Master & Dynamic MW60 Ear piece
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Our picks for the best wireless noise cancelling headphones to buy in 2022 at various price points may surprise you.
Our comprehensive list of the best true wireless earbuds and earphones of 2022 features some surprises.
If you're looking for a better sounding alternative to Apple AirPods, these are the best true wireless earbuds of 2021 so far.
With some mild EQ adjustments, Master & Dynamic's MW09 are the best sounding wireless noise cancelling earphones we've heard to date.
M&D's MW09 Wireless Earphones feature AI-enhanced talk capabilities, 16 hours of playtime, wireless charging, and support for Bluetooth 5.4.
Master & Dynamic Earphones and Headphones are now available in new Lamborghini inspired designs for only $50 more.
At $399, the second generation Master & Dynamic MH40 Wireless Over-Ear Headphones arrive with some key improvements.
The ANC wireless headphone category is getting very competitive. Can the Master & Dynamic MW75 best the Sony and B&W Px7 S2?
