Earbuds & In-Ear Headphones
Master & Dynamic’s MW09 Wireless Earphones Feature AI-Enhanced Talk Capabilities and Bluetooth 5.4 Support
M&D’s MW09 Wireless Earphones feature AI-enhanced talk capabilities, 16 hours of playtime, wireless charging, and support for Bluetooth 5.4.
Master & Dynamic MW09 True Wireless ANC Earphone Colors
Master & Dynamic today introduced the MW09 Active Noise-Cancelling True Wireless Earphones, which feature an updated acoustic architecture, refined ergonomic body, up to 16 hours of listening, and aluminum and Kevlar cases with wireless charging. Priced from $349, Master & Dynamic’s latest generation of earphones aim for the ultimate listening experience in a streamlined, powerful package.
Master & Dynamic MW09 True Wireless ANC Earphones Black in Charging Case
“For the MW09, we focused our efforts on producing significant performance enhancements without compromising our obsession with design and materials.  We’re most excited about our proprietary AI-enhanced talk solution and adaptive ANC.  But, we’ve also upgraded the M&D Connect App with new functionality including sidetone, custom EQ settings, earphone battery monitoring and an earphone fit test.  With all these improved features, I’m confident the MW09 will sound as good as it looks.” – Jonathan Levine, Founder & CEO.
Enhanced, Expanded Sound
The new MW09s feature AI-enabled talk capabilities, and best-in-class connectivity. The redesigned acoustic architecture and custom 11mm beryllium drivers aim to create a more spacious sounding presentation in a closed wireless IEM.
Optimized microphone and sensor placement as well as new adaptive noise cancellation algorithms create a precisely-tuned ANC experience that more effectively removes unwanted environmental noises, while maintaining a rich, warm sound. Bluetooth 5.4 provides reliable and clear connectivity.
The MW09 is compatible with Qualcomm’s Snapdragon Sound and is also Auracast-ready.
Master & Dynamic MW09 True Wireless ANC Earphones Blue in Kevlar Charging Case
MW09 Blue inside Kevlar Case ($399)
Refined Design
The earphone silhouette is finished with anodized aluminum and sapphire glass and is available in six colorways. The acoustic enclosure and overall construction have been optimized to provide both a lighter weight and a more secure fit for a wider range of users and added comfort during extended listening. Three colorways are matched with anodized aluminum cases and an additional three colorways are paired with a Kevlar charging case (for $50 more).
All cases offer inductive as well as corded recharging via USB-C.
Master & Dynamic MW09 True Wireless Earphone
New Features
Whether it’s even more battery life, greater talk clarity, easier toggling between devices or more custom control over your custom sound profile, the MW09 boasts several key new features including:
  • Up to 16 hours of battery life per earbud (up to 12 hours with ANC) – an improvement of up to 20% – with an extra 32 hours of battery life in the wireless induction charging cases
  • A new AI-powered high-definition talk solution which delivers clear communication and more natural speech in the noisiest environments
  • Multipoint connectivity which allows seamless toggling between cell phones and laptops or tablets
  • An in-app fully adjustable equalizer which allows the user a full range of customization options
Master & Dynamic MW09 True Wireless ANC Earphones Gold in Charging Case
MW09 Gold with Gold Aluminum Case ($349)
Price & Availability
Master & Dynamic’s MW09 Active Noise-Cancelling True Wireless Earphones are available for $349 / €399 / £319 in:
  • Black with Black Aluminum Case
  • White and Silver with Silver Aluminum Case
  • Gold with Gold Aluminum Case.
Three Kevlar® case models will sell for $399 / €449 / £369 in:
  • Green with Kevlar® Case
  • Blue with Kevlar® Case
  • Gunmetal with Kevlar® case
All styles will be available for purchase or pre-order at masterdynamic.com, starting November 14, 2023.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
In-Wall Speakers
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
