MartinLogan Vista Floorstanding Loudspeaker Announced
A stellar performer at an exceptional price — offering unparalleled sonic purity, precision, clarity, and openness
MartinLogan, the Loudspeaker Technology Company, announced today the introduction of the new Vista™ loudspeaker. The result of years of research, the new Vista™ hybrid electrostatic loudspeaker features advanced technological developments, dramatically reducing cabinet size and establishing new standards for efficiency, dynamics and precision in a floor-standing loudspeaker.
Vista’s™ Features Include:
  • XStat™ Electrostatic Transducer featuring:
  • Ultra-Rigid AirFrame™ Technology
  • Advanced Vacuum Bonding
  • MicroPerf Stators
  • ClearSpar™ technology
  • CLS™ (Curvilinear Line Source)
  • High-Resolution 8-inch Aluminum Cone Woofer
  • Precision Performance Crossover Engineering
Incorporating ultra-high-resolution XStat™ and AirFrame™ technologies originally developed for the Summit speaker, Vista is capable of an exceptionally dynamic and realistic performance. An aluminum cone woofer, super-dense compact cabinet, Energy Transfer Coupler spikes, and bi-wirable toolless binding posts further reinforce Vista’s high-end pedigree. The result? A stellar performer at an exceptional price.
Key to Vista’s performance is MartinLogan’s advanced XStat electrostatic panel, which covers most of the audible range (from the midrange to beyond the limit of human hearing) with unprecedented accuracy, low-level sonic detail, and efficiency. A perfectly integrated, MartinLogan engineered 8-inch aluminum cone woofer supplies an authoritative bass performance with extreme precision.
MartinLogan’s state-of-the-art custom toroidal audio transformer and crossover engineering ensure an absolutely transparent link from amplifier to electrostatic panel and woofer. Using polypropylene capacitors and MartinLogan’s own air-core coils, Vista’s crossover employs MartinLogan’s proprietary Vojtko topology for vanishingly low distortion and seamless driver integration. This precision-tuned network preserves even the minutest sonic nuances while handling the full dynamics of any source with unparalleled purity, precision, clarity, and openness.
XStat™ Transducer and Ultra Rigid AirFrame™ Enhance Electrostatic Purity
Revealing every subtle nuance of recorded sound with unflinching accuracy, Vista’s ultra rigid AirFrame and curvilinear XStat electrostatic transducer reveal a magical performance with precision, dynamics and three-dimensional sound staging–all from an extremely compact stat panel.
Housed within a radical, ultra-rigid, extruded aluminum and composite AirFrame™, Vista’s™ CLS™ (Curvilinear Line Source) XStat™ transducer builds upon the legacy of MartinLogan’s electrostatic heritage. The integration of exotic toroidal transformer engineering and an electrical interface technology developed by MartinLogan’s Statement™ e2 engineering team extends effortless dynamics and purity resulting in the highest sonic standards of efficiency and precision.
MicroPerf stator technology, featured in Vista’s XStat™ transducer, maximizes playable area in each panel. The Vista™ loudspeaker boasts an XStat™ electrostatic transducer with a playable area equal to that of a traditional electrostatic transducer nearly twice its size.
Further enhancing efficiency and dynamics as well as MartinLogan’s trademark transparency, rigid ClearSpars™ spacers (originally engineered for the cost-no-object Statement™ e2) allow XStat™ transducers to maintain an extremely uniform tension of the diaphragm during critical panel construction processes, permitting critical stator and diaphragm spacing within an exact tolerance.
Ultimate Crossover–Ultimate Clarity
Featuring an advanced proprietary Vojtko™ crossover topology derived from the Statement™ e2 loudspeaker, Vista’s crossover utilizes only the finest of components and construction techniques to assure the cleanest, most precise signal path possible. The resulting precision crossover flawlessly preserves every sonic subtlety while effortlessly handling the broadest range of dynamics contained within even the most demanding sonic source.
Variety of Finish Options
Vista features a variety of real wood veneers with multiple layers of hand-rubbed lacquer.
Toolless Binding Posts Simplify Connections
The Vista is supplied with bi-wire, high-resolution, proprietary toolless binding posts for effortless cable attachment and management.
Energy Transfer Coupler (ETC) Spikes Maximize Low Frequency Performance
To further enhance Vista’s performance, sturdy ETC™ spikes are provided for tighter, better defined bass, cleaner micro dynamic resolution, and improved imaging and focus.
SUMMARY OF KEY FEATURES AND BENEFITS
FEATURE BENEFIT
XStat™ Transducer Provides ultimate precision and efficiency
Ultra-Rigid AirFrame™ Technology Provides a rigid housing for the advanced XStat™ transducer
Advanced Vacuum Bonding Provides ultimate precision and efficiency
CLS™ (Curvilinear Line Source) Achieves a controlled horizontal dispersion pattern radiating ideal frequency response throughout the living Environment yet at the same time dramatically minimizing acoustically destructive room interactions
MicroPerf Stators Creates unparalleled performance from an extremely compact electrostatic transducer
ClearSpar™ Spacers Maximizes efficiency and dynamics while enhancing MartinLogan’s exclusive transparent look
Precision Performance Crossover Engineering Flawlessly preserves sonic subtleties while handling a broad range of dynamics contained within even the most demanding sonic source
SPECIFICATIONS
System Frequency Response 43–23,000 Hz ± 3db
Dispersion Horizontal: 30 Degrees Vertical: 40″ (102 cm) line source
Sensitivity 90 dB/2.83 volts/meter
Impedance Nominal: 4 ohms Minimum: 1.2 ohms @ 20 kHz
Crossover Frequency 450 Hz
Components Custom-wound audio transformer, air core coils, polypropylene capacitors
Woofer Type 8″ (20.3 cm) cast basket, high excursion, aluminum cone with extended throw driver assembly, bass reflex
Power Handling 200 watts per channel
Signal Inputs Custom bi-wire binding posts
Weight 54 lbs. each (24.5 kg)
Size 57″ h × 10.7″ w × 16.8″ d (144.7 h × 27.3 w × 42.7 d cm)
Available: Now Shipping
Retail Price: Contact your local distributor for pricing.
MartinLogan, one of the most respected names in audio, is located in Lawrence, Kansas, where 80 employees handcraft the company’s ultimate loudspeaker products. The speaker systems, incorporating MartinLogan’s patented CLS™ (Curvilinear Line Source) high-resolution electrostatic technology and ATF™ (Advanced Thin Film) transducers, range in price from $399 to over $9,995 (US Retail). The subwoofer systems range in price from $599 to $2795 (US Retail). For more information regarding MartinLogan visit www.martinlogan.com, or contact Devin Zell at (785) 749-0133.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
Loudspeakers
Audioquest has let go of the noted speaker company GoldenEar, but is going to PML a good move?
Ask an Expert
We take a look at the history of the electrostatic loudspeaker and some of the designs that made it prized by audiophiles.
MartinLogan reQuest speakers from 1996 have been out of production for many years but are one of the best used electrostatic loudspeakers if you...
A look back at the most significant loudspeakers of my audiophile journey. What moved the needle for you?
Podcasts
Audio industry icon, Gayle Sanders, the co-founder of MartinLogan and founder of Eikon Audio joins us for a trip down memory lane as we...
Does vintage audio still make sense? Only if you follow some basic rules and understand that bargains are becoming harder to find.
We lost a really good human being last Friday, and why I must go back to the very beginning with the MartinLogan Aerius i...
