Loudspeakers
MartinLogan Fresco i On-Wall/Off-Wall Loudspeakers Announced
Compact LCR/Surround Speaker Features ATF™ (Advanced Thin Film) Transducers and Flat-Screen Television Friendly Styling
Available: March 2007
US Retail: $995/each
MartinLogan, the loudspeaker technology company, announces the introduction of the compact Fresco i speaker.
An engineering masterpiece, Fresco i blends innovative design, advanced materials, and the latest technology to produce signature MartinLogan sound from a compact and versatile package. ATF™ (Advanced Thin Film) midrange and high-frequency drivers, a precision Vojtko™ crossover, and proprietary dual long-excursion, low-mass woofers combine to supply astonishing performance in any stereo or multi-channel audio system, whether used as a center, left, right or surround speaker. From top to bottom, Fresco i delivers precision and detail, with firm, agile bass and impressive dynamics.
Fresco i’s paintable, super-dense, low-mass cabinet is just 6 inches deep, blending perfectly with wall-mounted flat-panel displays. Each Fresco i comes standard with a low-profile, single-pivot wall bracket that allows vertical or horizontal mounting next to a plasma or LCD display or in any other location. Also standard are Fresco i’s high-gloss ‘Elite Black’ faceplate and black grill cloth. Optionally available are table and floor stands.
Versatility in Application and Installation
Fresco i is suitable for use in any stereo or multi-channel audio system, mounted either on- or off-wall. And it blends well with other MartinLogan speakers in both sound and appearance, which allows mixing and matching to meet specific installation requirements. A unique ‘on wall/off wall’ acoustic contour switch tailors Fresco i’s low-frequency response appropriately for on-wall or off-wall placement, ensuring total system matching in even the most diverse setups.
Precision Crossover for Extreme Clarity
Carefully hand-built using only the finest polypropylene capacitors and air-core coils, the crossover employ’s MartinLogan’s proprietary Vojtko topology for vanishingly low distortion and seamless driver integration. This precision-tuned network preserves even the most subtle sonic nuances while handling the full dynamics of any source.
MartinLogan’s ATF™ (Advanced Thin Film) Transducers Provide Clarity, Detail and Resolution
High-resolution ATF™ drivers (based on RADIA planar technology) approach the clarity and detail of MartinLogan’s electrostatic panels while permitting the use of a compact cabinet. Each MartinLogan ATF transducer has a micro-thin, low-mass diaphragm with an ultra-light, etched aluminum conductive surface, suspended between two opposite-polarity, high-field-strength neodymium magnet arrays. When the electrical audio signal from an amplifier passes through the diaphragm’s surface, it creates an alternating electromagnetic field that interacts with the fields of the fixed magnet arrays, forcing it back and forth to produce sound waves in the air. The strength and polarity of the diaphragm’s field varies according to the audio signal.
ATF transducers and MartinLogan’s award-winning electrostatic transducer share several key performance enhancing features that ensure precise, accurate reproduction with vanishingly low distortion. Each ATF transducer diaphragm is sandwiched between and simultaneously driven by magnet arrays of opposing polarity to create an inherently linear push-pull effect similar to that of an electrostat. Another similarity is that the diaphragm is driven uniformly over its entire surface, rather than at just a small contact area as in a conventional cone or dome driver.
The ATF diaphragm substrate is DuPont Kaladex PEN (polyethylene napthalate). This material is chemically akin to the PET (polyethylene terathylate) film used for the diaphragms of MartinLogan’s renowned electrostatic panels, but capable of handling the heat generated by the current passing through the ATF diaphragm’s conductive aluminum etched skin.
SUMMARY OF KEY FEATURES AND BENEFITS
Feature Benefit
ATF Transducers Efficient output with detail, clarity and resolution.
High-excursion aluminum woofers Superb bass from a small cabinet.
On-wall/Off-wall contour switch Custom acoustic equalization.
Low-profile cabinet Minimizes space and allows any installation location.
Selection of stands All installation options addressed.
Plasma screen friendly design Visually integrates with popular plasma televisions.
Specifications
Frequency response: 75–20,000 Hz, +- 3 dB
Sensitivity: 90 dB/2.83 volts/meter
Impedance: 5 ohms
Crossover Frequency: 500 Hz, 3200 Hz
Components: Air core coils, metal film and low dissipation electrolytic capacitors
High-frequency driver: 1.5″ x 2.25″ (3.8cm x 5.7cm) ATF Transducer
Mid-range driver: 1.5″ x 6″ (3.8cm x 15.2cm) ATF Transducer
Bass drivers: Two 4″ (10.2cm) magnetically shielded, high rigidity aluminum cones with extended throw drive assembly, non-resonance asymmetrical chamber format; bass reflex; unshielded
Power Handling: 150 watts/channel
Weight: 16 lbs. each (7.3 kg)
Size (without bracket): 24″ W × 5″ D × 8.25″ H (61cm W × 12.7cm D × 61.6cm H)
Size (with bracket): 24″ W × 5.7″ D × 8.25″ H (61cm W × 14.5cm D × 61.6cm H)
MartinLogan, one of the most respected names in audio, is located in Lawrence, Kansas, where 80 employees handcraft the company’s ultimate loudspeaker products. The speaker systems, incorporating MartinLogan’s patented CLS™ (Curvilinear Line Source) high-resolution electrostatic technology and ATF™ (Advanced Thin Film) transducers, range in price from $399 to over $9,995 (US Retail). The subwoofer systems range in price from $599 to $2,995 (US Retail). For more information regarding MartinLogan visit www.martinlogan.com, or contact Devin Zell at (785) 749-0133.
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
Loudspeakers
Audioquest has let go of the noted speaker company GoldenEar, but is going to PML a good move?
Ask an Expert
We take a look at the history of the electrostatic loudspeaker and some of the designs that made it prized by audiophiles.
MartinLogan reQuest speakers from 1996 have been out of production for many years but are one of the best used electrostatic loudspeakers if you...
A look back at the most significant loudspeakers of my audiophile journey. What moved the needle for you?
Podcasts
Audio industry icon, Gayle Sanders, the co-founder of MartinLogan and founder of Eikon Audio joins us for a trip down memory lane as we...
Does vintage audio still make sense? Only if you follow some basic rules and understand that bargains are becoming harder to find.
We lost a really good human being last Friday, and why I must go back to the very beginning with the MartinLogan Aerius i...
