MartinLogan Dynamo Subwoofer System
Available: September 2004
Dynamo US Retail: $599/each
Lawrence, Kansas, August 2004–MartinLogan, the Loudspeaker Technology Company, announces the introduction of the Dynamo high-resolution subwoofer system. Building upon the unprecedented success of MartinLogan’s subwoofer line, the Dynamo delivers dramatic bass detail and attack using a proprietary low mass, high-excursion driver and ultra-fast, high-resolution 200 watt amplifier. The Dynamo will surpass all preconceptions of subs in its class.
High-Resolution Driver Provides Powerful Bass
At the heart of the Dynamo subwoofer lays a proprietary MartinLogan, 10-inch, high-resolution driver, designed and manufactured with the same meticulous attention, care and precision as those found in the ground breaking Descent subwoofer. The combination of Dynamo’s high-excursion aluminum cone and the tremendous field strength generated by the magnet motor structure results in huge excursions and massive cubic displacement capability.
Intuitive Control Architecture and Advanced Crossover Allow Seamless System Integration
Intuitive control functions allow the Dynamo to be easily tuned for any installation. MartinLogan’s dedicated engineering and design team created a robust input/output architecture that easily integrates in both stereo- and multi-channel audiophile systems. Additionally, RCA output allows multiple Dynamo’s to operate in a serial configuration.
Extreme care has been focused on the group delay (phase) characteristics for each of Dynamo’s crossover settings (ranging from 30–80Hz) to deliver precise contouring in both the amplitude and time domain. The result? Seamless and cohesive integration with any system.
Front-Firing and Down-Firing Configuration Maximizes Installation Options
To maximize performance when installed inside of a cabinet or other custom installation, Dynamo’s standard down firing configuration easily converts into a front firing configuration. A grill cover and 90° RCA adaptors are provided for use in front firing applications.
Versatility in Application
The new Dynamo, available in either silver or black, is optimized for use in stereo- and multi-channel applications and in all installation configurations including in corners, inside cabinets and underneath or behind furniture. Sonically, the Dynamo reproduces sub-bass frequencies with the same exacting accuracy and authority you have come to expect from the MartinLogan line of subwoofer products.
SUMMARY OF KEY FEATURES AND BENEFITS
Feature: High-Excursion Aluminum Driver
Benefit: Massive cubic displacement.
Feature: Low Distortion, Ultra-Fast Amplifier
Benefit: Provides precision and power in a small package.
Feature: Front-Firing/Down-Firing Configuration
Benefit: Maximizes installation options.
Dynamo Specifications
System Frequency Response:
25–120 Hz ± 3 dB. Anechoic through the LFE effects input.
Low-Pass Filter Frequencies:
30Hz–80Hz
High-Pass Filter Frequency:
70Hz
Phase:
0°, 90°, 180°
Components:
10″ (25.4cm) high-excursion, aluminum cone with extended throw driver assembly
Amplifier:
200 watts RMS
Impedance:
L&R RCA — 20,000 Ohms; LFE RCA — 34,000 Ohms
Inputs:
RCA Line Level, RCA-LFE, Speaker-Level
Output:
RCA Line Level, RCA Sub Out
Weight:
28.5 lbs. each (12.9 kg)
Size (Down Firing Config.) (H x W x D):
13.9″ x 11.7″ x 12.6″ (35.3cm x 29.7cm x 32cm)
Size (Front Firing Config.) (H x W x D):
13.9″ x 11.7″ x 12.9″ (35.3cm x 29.7cm x 32.8cm)
MartinLogan, one of the most respected names in audio, is located in Lawrence, Kansas, where 80 employees handcraft the company’s ultimate loudspeaker products. The speaker systems, incorporating MartinLogan’s patented CLS (Curvilinear Line Source) high-resolution electrostatic technology and ATF (Advanced Thin Film) transducers, range in price from $649 to $90,000 (US Retail). The subwoofer systems range in price from $599 to $2795. For more information regarding MartinLogan visit www.martinlogan.com, or contact Devin Zell at (785) 749-0133. High-resolution images are available on-line at www.martinlogan.com/mediaresources.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Loudspeakers
Audioquest has let go of the noted speaker company GoldenEar, but is going to PML a good move?
Ask an Expert
We take a look at the history of the electrostatic loudspeaker and some of the designs that made it prized by audiophiles.
MartinLogan reQuest speakers from 1996 have been out of production for many years but are one of the best used electrostatic loudspeakers if you...
A look back at the most significant loudspeakers of my audiophile journey. What moved the needle for you?
Podcasts
Audio industry icon, Gayle Sanders, the co-founder of MartinLogan and founder of Eikon Audio joins us for a trip down memory lane as we...
Does vintage audio still make sense? Only if you follow some basic rules and understand that bargains are becoming harder to find.
We lost a really good human being last Friday, and why I must go back to the very beginning with the MartinLogan Aerius i...
