Marten’s Coltrane Quintet Speakers Promise Extraordinary Performance For Those With Very Deep Pockets
At $190,000/pair, Marten Coltrane Quintet loudspeakers feature a new 5-driver design for improved bass response, dynamics and resonance reduction over its predecessor, Coltrane 3.
Marten Coltrane Quintet Loudspeakers
2024 has seen a rather interesting mix of new product introductions and that has included a substantial number of ultra high-end loudspeakers. Magico and Sonus faber have introduced models over $300,000 (the Italian manufacturer’s new statement level loudspeaker is $750,000 USD) and we must confess to being rather perplexed by the trend. Marten is known for its rather expensive floorstanding models, so we’re not entirely surprised by the new Coltrane Quintet which start at $190,000 USD.
Imagine spending $190,000 on a single pair of loudspeakers.
Marten Coltrane Quintet Loudspeaker Dark Grey
Marten Coltrane Quintet Loudspeaker in Dark Grey
Core Features
The Coltrane Quintet is the successor to the Coltrane 3 (released in 2016) and continues the Coltrane tradition of delivering high-resolution, crystal-clear sound with a wide and accurate soundstage that is designed to be life-like and natural. The Coltrane Quintet incorporates improvements in bass response, dynamics, and resonance reduction.
The Coltrane Quintet incorporates a first-order crossover and four custom drivers:
  • Pure diamond tweeter.
  • Beryllium high-midrange.
  • Carbon fiber mid-bass (new for 2024).
  • Aluminum sandwich bass drivers.
Tech Note: To extend bass response further, the Quintent has a bass reflex design.
The Coltrane Quintet cabinet is 25% larger than the Coltrane 3, providing more interior volume that supports a lower bass frequency response. A carbon fiber cabinet provides superior resonance control while retaining the sleek and robust profile of a Coltrane.
Marten Coltrane Quintet Loudspeaker in Oak
Structural enhancements to the interior and front plate enhance rigidity and stability. For the first time, the cabinet is offered in polished carbon fiber laminate with an option for a lacquered Piano Black finish.
The stand has been enlarged to enhance stability, working in tandem with Marten Isolators to separate the speaker from the listening environment.
Comparison
Marten Coltrane Quintet (left) vs. Coltrane 3 (right)
Coltrane QuintetColtrane 3
PriceStarts at $190,000 (pr)$100,000 (pr)
Speaker Type4-way bass reflex3-way bass reflex
Frequency Range (+/- 2dB)20-40,000 Hz20-60,000 Hz
Power Rating350 W350 W
Sensitivity (1 m / 2.83V)89 dB88 dB
Impedance4 ohm (3.0 Ohm min)6 ohm (3.7 Ohm min)
Tweeter1 x 1-inch pure diamond1 x 1-inch diamond
Mid-range1 x  3-inch pure beryllium1 x 7-inch ceramic
Mid-Bass1 x  7-inch carbon fiber
Woofer2 x 10-inch aluminum sandwich2 x 10-inch aluminum sandwich
Crossover FrequencyFirst order: 170, 1000, 6000 HzFirst order: 320 & 3800 Hz
Connection TerminalsWBT Nextgen Bi-wiringWBT Nextgen bi-wiring
Internal WiringJorma (optional Statement)Jorma Design
Cabinet20-30 mm carbon fiber laminate Piano lacquer with the front baffle in a sandwich with aluminum, fiberboard, and solid wood.
25 mm carbon fiber laminate cabinet, 68 mm laminated wood/aluminum front.
FinishesMatte Walnut / Oak or Piano Black / Grey / Plum / Red / GoldMatte Walnut/ Oak or Piano Black / Grey / Gold/Silver
StandsMirror-polished stainless steel with Marten Isolators (in partnership with IsoAcoustics)68 mm laminated wood / Aluminium front brushed stainless steel with Marten Isolators
Dimensions (WHD)41.2 x 120.5 x 74 cm
(16.2 x 47.4 x 29.1 inches)
39.5  x 122 x 64 cm
(15.5 x 48.0 x 25.2 inches)
Net Weight115 kg (255 lbs)95 Kg (209 lbs)
Marten Coltrane Quintet Loudspeaker Side View
Initial Thoughts
We have no doubt that the Coltrane Quintet sounds great based on a brief observation in our High-End Munich 2024 Show Report. However, the market is getting very crowded in the ultra-high-end speaker category and we wonder how this trend is sustainable over the long run given a lot of competition in this seemingly narrow market. Yet Marten is not shying away as the Coltrane Quintet joins even more expensive step-up models, Momento 2 and Supreme 2, in the flagship Coltrane series.
Marten Coltrane Quintet Loudspeaker Pair
Pricing & Availability
The Marten Coltrane Quintet starts from $190,000 (USD) per pair.
The Coltrane Quintet Statement Edition is $209,000 (USD) per pair. The Statement Edition, adds Jorma Statement internal cables and higher-quality crossover components.
Marten Speakers can be purchased through Authorized Representatives. For more information, visit martin.se.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
While Record Store Day (RSD) is over for now, Mark Smotroff reports on his scores, some of which you still may be able to...
Think you’ve seen it all? These 25 essential American films are the ones every true movie lover should own.
Hi-Fi Components
Goer Dynamics will expand the distribution of Gryphon Audio Designs into Asia and open up opportunities in the luxury car audio sector.
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
