Marantz SR7009 Dolby Atmos A/V Receiver
Marantz is about to release their first Network A/V Receiver with Dolby Atmos capability, the SR7009 ($1,999). The 9.2-channel receiver provides nine discrete amplifier channels, each with 125-watts of power. With its four DSP (Digital Sound Processing) engines the SR7009 is capable of handling up to 11.2 channels to fully support Audyssey DSX, DTS Neo:X 11.1, as well as the latest decoding technology Dolby Atmos. With Dolby Atmos, sound comes alive from all directions, including overhead, to fill the home theater with astonishing clarity, power, detail, and depth. The SR7009 has the processing power to run a more enveloping, 7, 9 or 11 channel Dolby Atmos layout using 5.1.2, 5.1.4, 7.1.2, 7.1.4 or 9.1.2 configurations utilizing ceiling mounted, or Dolby Atmos-enabled speakers. A 5.1.2 or 5.1.4 speaker configuration is based upon a traditional 5.1 speaker layout complemented by 2 or 4 overhead or Dolby Atmos-enabled speakers. A 7.1.2 or 7.1.4 configuration is based on a 7.1 speaker layout with 4 overhead, or Dolby Atmos-enabled speakers. A 9.1.2 configuration is based on a 9.1 speaker layout with 2 overhead speakers.
To finish off, the SR7009 comes with even 3 HDMI outputs and a 13.2ch pre-out capability for extreme versatility. The most advanced Audyssey MultEQ XT32 / Sub EQ HT/LFC (Pro ready) room correction suite adds to the most accurate calibration of the speakers to make every seat in the room is a ‘sweet spot’ for audio.
Price and Availability
The Marantz SR7009 A/V Receiver will be available in black in September 2014 for $1,999.
Marantz SR7009 A/V Receiver Back
Features
  • Dolby Atmos
  • Wi-Fi and Bluetooth built-in
  • Current Feedback topology and new Marantz HDAM
  • 9ch discrete power amplifier, 125 W per channel
  • 125 watts per channel (8ohm 20-20kHz, THD 0.05%)
  • Big trapdoor design; aluminum front panel
  • Dolby TrueHD and DTS HD Master Audio
  • Audyssey MultEQ XT, XT32, LFC, Pro ready
  • Audyssey DSX; DTS Neo:X (11.1ch)
  • Audyssey Sub EQ HT
  • Latest HDMI version with 4k 50/60Hz 4:4:4 resolution
  • 7+1 front HDMI in / 2 out (zone out) (4k 50/60Hz, 3D, ARC, Deep Color)
  • HDMI scaling 1080p, 4k 50/60 Hz
  • MP3, WAV, AAC, WMA, AIFF
  • HD Audio streaming: FLAC 192/24, DSD, ALAC
  • Gapless Playback
  • USB port
  • vTuner Internet Radio, Spotify Connect, Pandora,Sirius XM, (where available, subscription required)
  • Phono (MM) input
  • Setup Assistant and Advanced GUI
  • 4 Smart Select buttons for fast selection of listening presets
  • 11.2ch signal processing and 13.2ch pre-out (with 2 independent subwoofers)
  • Marantz Remote App for iOS and Android devices
  • 3 HDMI out (2 + 1 zone)
  • ECO mode
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
Denon's budget friendly Dolby Atmos AV receiver offers excellent connectivity and sound quality for under $600.
At $12,000, the Marantz Link 10n is the company's flagship network audio player designed to be paired with Model 10 Integrated Amplifier.
CD Players
At $12,000, the new Marantz SACD 10 is the best CD/SACD player the company has ever made and it weighs 73 lbs.
