Marantz SR6006 and SR5006 3D A/V Receivers
Marantz announced the SR6006 and SR5006 3D A/V receivers, which replace their flagship SR7005 A/V receiver from last year. Both the SR6006 and SR5006 receivers inherit the best genes of their precursor, and share its highly acclaimed Marantz product design with the distinctive lines and circular display.
Fully equipped for the 'connected home', both AV receivers feature an on-board Ethernet port allowing for audio streaming from home networks as well as subscription-based web-services, and giving access to over 14,000 Internet radio stations worldwide. The newcomers even have AirPlay functionality built-in, letting users unleash their iTunes or iPhone/iPod touch/iPad music libraries to the AV receivers. Thanks to the network connection the AV receivers can easily be controlled, via Apple iDevices, through the free Marantz Wizz App.
The new SR6006 is powerful. Very powerful — 7 x 110-watt rms to be exact. Combined with high-quality audio processing this stylish box of AV armoury creates a devastatingly convincing cinematic experience. That is partly because the digital audio signal – up to Dolby TrueHD and DTS-HD – is fed via one of the seven 3D supporting HDMI 1.4 inputs. The two available HDMI outputs are working simultaneously. In addition, the system's Audyssey Dynamic Volume control ensures that the sound remains at the same level even when a commercial interrupts. Also, the video up-scaling of analogue and digital video signals up to 1080p brings out the best of existing SD quality sources such as DVD, game consoles or even VHS. In addition, for added 'new media' compatibility the SR6006 includes an iPod-digital-compatible USB input. To ensure you get the best possible audio from compressed files on iPod via USB, the SR6006 incorporates the M-DAX2 — Marantz Dynamic Expander version two. This neat little addition also optimizes the quality of MP3 files from either CD or the optional Bluetooth receiver RX101. Everything sounds clearer, more detailed, and more alive. Last but not least, the SR6006 has a Phono input to serve as the perfect stereo entertainment centre. What's more, set-up, optimization and operation are all quick and easy — with the Audyssey MultEQ XT, an intuitive-to-use graphic user interface as well as the new Setup Wizard for convenient installation.
Marantz SR5006 A/V Receiver
The younger brother SR5006 provides 7 x 100-watt rms, has decoders for standard as well as Dolby TrueHD and DTS HD Master Audio, and comes with six HDMI 1.4 inputs — making it immediately ready for 3D video and the ARC (audio return channel) from capable TVs. It easily handles the most demanding of scenes in action films, as well as offering excellent-quality music playback, thanks to the advanced Marantz audio technologies taken from the SR6006. It also comes with a whole host of convenience features such as “auto set-up” with Audyssey MultiEQ and Dynamic Volume, multiroom with multi-source flexibility, and “video-off” mode to ensure movies and music are enjoyed in true dynamic Marantz style.
Price and Availability
The SR6006 ($1,199.99) and SR5006 ($799.99) will be shipped in black and silver/gold colour finish from mid July onwards.
SR6006 SR5006
Number of Channels 7ch Amp. 7.1ch Processing 7ch Amp. 7.1ch Processing
DTS HD Master & High Res. Audio/ES/96/24/Discrete & Matrix6.1/ Neo:6/Express HD Master & High Res. Audio/ES/96/24/Discrete & Matrix6.1/ Neo:6/Express
Dolby True HD/Digital Plus&EX/ Pro Logic IIz, IIx, II/Virtual Speaker/ Headphone True HD/Digital Plus&EX/ Pro Logic IIz, IIx, II/Virtual Speaker/ Headphone
DSD(SA-CD)/NEURAL – / yes – / yes
Discrete Amplification Yes Yes
Power Transformer EI EI
D/A Conversion 192kHz/24-bit 192kHz/24-bit
Digital Signal Processing Analog Devices SP21487 / 400Mhz Analog Devices SP21487
Video Off (Pure Direct) Yes Yes
Source Direct Yes Yes
Chassis Steel Steel
Variable X-over Yes Yes
Video Up-conversion Composite/Component to HDMI, HDMI to HDMI Composite/Component to HDMI, HDMI to HDMI
Auto Calibration by MIC Audyssey MultEQ XT Pro Audyssey MultEQ XT
Satellite Radio Ready
AM/FM tuner HD Radio: 1 1
Bass Management Yes Yes
Lip-sync (digital audio delay) Yes Yes
Software Upgradable Through Internet Through Internet
HDMI In 7 (including Front input: 1) 6
Component In 2 2
S-Video In 0 0
Composite In 5 (including Front input: 1) 4 (including Front input: 1)
HDMI Out 2 – Simultaneous 1
Component Out 1 1
S-Video Out 0 0
Composite Out 2 1
Analog L&R In 7 (including Front input: 1) 6 (including Front input: 1)
Analog L&R Out 1 1
Digital Optical In 2 2
Digital Coaxial In 2 2
Digital Optical Out 0 0
Digital Coaxial Out 0 0
Pre-Amplifier Out 7.1ch + 2nd Subwoofer :1 2.2ch
Multi-Channel In 7.1ch 7.1ch
Multi-Room Audio Out Zone 2 and Zone 3, Pre out: 2, digital, HPF, Mono, and Tone Control Zone 2 Pre out
Multi-Room Speaker Out Assignable Surround Back Speaker as for Zone 2 Assignable Surround Back Speakers as for Zone
Speaker A/B Yes Yes
Networking DLNA 1.5 certified Audio/Photo Streaming, Internet Radio, Streaming service capability(Rhapsody/Napster/Pandora/flickr) DLNA 1.5 certified Audio/Photo Streaming, Internet Radio, Streaming service capability(Rhapsody/Napster/Pandora/flickr)
External control RS-232C
DC Triggers 1 (12V, 150mA)
D-Bus Remote (RC-5) In/Out 1-1 1/1
Flasher In/IR Receiver In/Emitter out 1 / 0 / 0 1 / 0 / 0
Front Panel A/V Inputs USB: 1, Composite Video: 1, Analog L/R: 1 USB: 1, Composite Video: 1, Analog L/R: 1
Headphone Out 1 1
AC Outlets (Switched/Unswitched) – / – – / –
Power Output (8 Ohm) 110W (20Hz – 20kHz, 0.08% THD, 2ch driven) x7 100W (20Hz – 20kHz, 0.08% THD, 2ch driven) x7
S/N Ratio 98dB (IHF-A weighted, Source Direct Mode) 98dB (IHF-A weighted, Source Direct Mode)
Freq. Response (Analog In) 10Hz – 100kHz (+/-3dB, Source Direct Mode) 10Hz – 100kHz (+/-3dB, Source Direct Mode)
Freq. Response (Dig In)
FM Frequency Range 87.5 – 107.9MHz 87.5 – 107.9MHz
FM S/N Ratio (Mono/Stereo) 72 / 67 dB 72 / 67 dB
AM Frequency Range 520 – 1710kHz 520 – 1710kHz
Video Freq. Response (Component) 5Hz – 60MHz (+0, -3dB) 5Hz – 60MHz (+0, -3dB)
Video Freq. Response (Composit, S-Video) 5Hz – 10MHz (+1, -3dB) 5Hz – 10MHz (+1, -3dB)
Front Panel Star and Circle Display/Glass-resinforced resin Star and Circle Display/Glass-resinforced resin
Power Requirement AC 120V 60Hz AC120V 60Hz
Power Consumption 650W (Standby: 0.2W, CEC Standby: 3W) 650W (Standby: 0.2W, CEC Standby: 3W)
Dimensions W x H x D (Inchs) 17-3/8″ x 6-5/16″ x 15-5/16″ 17-3/8″ x 6-5/16″ x 15-5/16″
Weight (lbs) 26 25.6
MSRP $1,199.99 $799.99
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
At $12,000, the Marantz Link 10n is the company's flagship network audio player designed to be paired with Model 10 Integrated Amplifier.
CD Players
At $12,000, the new Marantz SACD 10 is the best CD/SACD player the company has ever made and it weighs 73 lbs.
At $1,500, the Marantz 60n is a 60-watt per channel integrated amp that connects to a TV, CD Player, turntable, and streams music.
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
Part 3 of 3 from CEDIA Expo 2024 highlights Ascendo, Theory Audio, Bowers & Wilkins, L-Acoustics, TCL, JVC and Grimani Systems.
Developed over five years at the renowned Shirakawa Audio Works in Japan, the Marantz Model 10 Reference Integrated Amplifier embodies unparalleled heritage, performance and...
