CD Players
The Marantz SACD 10 Takes SACD and CD Playback to the Next Level
At $12,000, the new Marantz SACD 10 is the best CD/SACD player the company has ever made and it weighs 73 lbs.
Marantz SACD 10 CD/SACD Player Silver Lifestyle
At the recently held CEDIA Expo 2024, Marantz announced the introduction of its flagship 10 Reference Series audio components. We previously reported on the $15,000 Model 10 Integrated Amplifier and $12,000 Link 10n Network player. Now, the details of the third entry in this product series, the SACD 10 CD/SACD player, have been revealed.
Marantz 10 Series Components with Bowers & Wilkins Speakers
SACD 10 Overview
The SACD 10 is Marantz’s newest CD/SACD player and the successor to the SA-10 ($7,499), which was released in 2017. You might ask yourself why introduce a high-end CD player these when streaming dominates the music listening experience for most?
Whilst new CDs and SACDs (Super Audio CD) are still being purchased in much smaller numbers, there are hundreds of millions in circulation around the globe; especially in markets like Japan and Germany where physical media is still very popular. The used CD market is booming.
Marantz claims that the SACD 10 is the best CD/SACD player they have ever produced and can compete with anything out there.
The SACD 10 incorporates an SACDM-3 transport mechanism for maximum rejection of resonance. Surrounding the transport is a triple-layer aluminum chassis with copper shielding, multi-layer PCBs, isolated sub-enclosures, and an HDAM (Hyper Dynamic Amplifier Module).
Industrial Design
On the exterior, the SACD 10 has a brushed aluminum control surface, spun finish details, a thick-section aluminum structure, and copper-plated. The SACD 10 is available in two colors, Marantz Black and Marantz Champagne.
Sound Master Tuned
The SACD 10 continues the Marantz track record of warmth, spaciousness, and resolution. However, advances in design and precise tuning by the Sound Master provide even more sound reproduction refinement, resulting in more for the listener,
Marantz SACD 10 CD/SACD Player Silver Rear
Musical Mastering
The SACD 10 is targeted to ultimate CD and SACD fans and is engineered with updated Marantz Musical Mastering and a next-generation HDAM (Hyperdynamic Amplifier Module) for more detailed audio reproduction.
Hi-Res Audio Support
In addition to SACD and CD playback, the SACD 10 can access hi-res audio via USB-A and USB-B DAC and has DSD 256 and PCM 384kHz, 32-bit support. Connectivity options include coaxial and optical digital outputs and inputs, and fixed-level XLR and RCA analog outputs.
Headphone Amplifier
Outputs are provided for connecting the SACD 10 to amplifiers (such as the Marantz Model 10), stereo receivers, or powered speakers. However, the SACD 10 also has a built-in headphone amp that provides the best possible headphone listening experience.
Comparison
Marantz SACD 10 vs. SA-10 CD Players
SACD 10 (2024)SA-10 (2017)
Price$12,000$7,499
Device TypeSACD, CD PlayerSACD, CD Player
Disc Playback TypesSACD
CD-R/-RW
DVD-R/-RW/+R/+RW (Data Discs – Music Files Only)
SACD
CD-R/-RW
Playback File FormatsPCM (2-channel)
DSD (2-channel/Multi-Channel)
MP3
WMA
AAC
WAV
FLAC
ALAC (Apple Lossless)
AIFF
PCM (2-channel)
MP3
WMA
AAC
WAV
FLAC
AIFF
Signal To Noise Ration (SNR)SACD: 118dB
CD: 116dB
SACD: 112dB
CD: 104 dB
Dynamic RangeSACD: 112dB
CD: 98dB
SACD: 109dB
CD: 98dB
Headphone CircuitDiscreteHDAM-SA2 current feedback
Headphone Amp Gain SettingLow / Mid / HighLow / Mid / High
H/P On/Off SettingYesYes
Headphone Output Level130mW 140 mW @ 600 Ω
330 mW @ 250 Ω
710 mW @ 100 Ω
Headphone Output Impedance32 ohms32  ohms
Output CircuitNew HDAM (Hyper Dynamic Amplifier Module)HDAM
DAC CircuitNew MMM-Conversion (Marantz Musical Mastering Conversion)MMM-Conversion
DitherMMM-Stream (Dither 1, 2, Off)MMM-Stream (Dither 1, 2, Off)
Noise ShaperMMM-Stream (Balanced, Natural, Dynamic Music, Dynamic Voice)DSP (Marantz)
Digital FilterMMM-StreamFilter 1, 2 SelectableMMM-StreamFilter 1, 2 Selectable
Jitter ReducerYes
DAC Master Clock Design (No Support for Network Playback)YesYes
Asynchronous mode (for USB-B input)YesYes
Isolator (for USB-B input)Yes (Complete Isolation System Duo)
Fixed Analog Output (RCA)Cinch × 1
Thick nickel-plated Maching copper L/R independent terminals
Cinch × 1
Fixed Balanced XLR Output11
Optical input/output (Maximum Support)2 / 1
(44.1 kHz – 192 kHz)
1 / 1
(192 kHz / 24-bit)
Coaxial input/output (Maximum Support)2 / 1
1 / 1
(192 kHz / 24-bit)
Headphone OutputYes (6.3 mm x 1)Yes (6.3 mm x 1)
Remote Control Bus TerminalYesYes
Remote Internal / External SwitchYesYes
Power TransformerToroidalToroidal
Power Consumption55W Less than 0.3W (at Standby)47W Less than 0.3W (at Standby)
Front Panel ColorsBlack / Marantz ChampagneBlack/Gold
Dimensions (WHD)440 × 192 × 442 mm
17.3 x 7.56 x 17.4 inches
440 x 123 x 419 mm
17.3 x 4.84 x 16.5 inches
Net Weight33 kg (73 lbs)16.4 kg (36 lbs)
Included AccessoriesWireless Remote (RC004PMND)
Battery (AAA ×2)
Power Cord (ALL region: Audio Grade: OFC)
Stereo RCA Cable ×1
Remote connector cable ×1
Quick Start Guide
Wireless Remote (RC004PMSA)
Battery (AAA ×2)
Stereo RCA Cable ×1
Quick Start Guide
Marantz SACD 10 CD/SACD Player Black
The Bottom Line
There is no question that the Marantz SACD 10 is remarkably expensive for a CD/SACD player in 2024; one can assemble a fantastic sounding system for $12,000 that includes a high-end CD player, network player, and turntable with money to spare for amplification and speakers. We even have some suggestions that you can read up on here.
What’s slightly crazy is that the Marantz SACD 10 does not even come close to being the most expensive CD player on the market right now. It might not even crack the top 10.
Having listened to the Model 10 integrated at CEDIA Expo 2024, the SACD 10 might be worth considering if you are assembling a system in the <choke> $50,000 to $60,000 range and require an ultra high-end CD/SACD player.
The SACD 10 also incorporates the latest Marantz technology refinements as well as a super-sturdy build that tops it off at 73 lbs.
When was the last time you saw a CD player that weighed 73 pounds?
If you are looking for a high-end SACD/CD player and have a lot less money to spend and want to stick with the Marantz brand, you might check out the Marantz SACD 30n which incorporates Network streaming in addition to SACD and CD playback for about $3,000.
Price & Availability
The Marantz SACD 10 CD/SACD Player is priced at $12,000 (US), €11,000 (EUR), £9,500 (UK) through Authorized Dealers in black or silver.
1 Comment
1 Comment
  1. Keith McAvoy
    October 28, 2024 at 2:35 am
    I was a dealer some 15 years ago and sold a complete reference set of Marantz. $7000 was the list in 2008, now we are talking $12,000 and of course new features and sound quality. It seems the norm and not the exception these days that manufacturers are building stratosphericly priced audio for a different buying class. Good news is the are more foreign competitors in the market to help challenge this trend.
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
