Digital Music Systems
Marantz Reference NA-11S1 Network Audio Player and DAC
Marantz announced an audiophile-grade digital music player equipped with proprietary multiple HDAM (Hyper Dynamic Amplifier Module) devices and dual master audio clock generators with jitter reduction. The new Reference Class NA-11S1 Network Audio Player and DAC offers superior audio capabilities with advanced Internet streaming and digital connectivity options, all in a package that is easily controlled with the supplied remote as well as with the Marantz Remote App on iPhone, iPad or iTouch.
The Marantz NA-11S1 is equipped with an RJ-45 LAN port so you can connect to your home network accessing thousands of internet radio stations and music streaming via Pandora, SiriusXM and Spotify. The NA-11S1 is likewise equipped with Apple’s Airplay so users can stream their iTunes music, whether from a Mac or PC, as well as directly from their iPhone, iPad or iTouch. Front and rear panel USB inputs expand the musical horizons even more, allowing users to enjoy iPhone and iPod audio via a digital connection and hear the music with new detail and richness through their home audio system, with sonic refinements made possible thanks to the NA-11S1’s advanced circuitry. The front panel USB type A port lets users connect portable devices directly, and it features automatic iPod detection and charging, even during standby mode. The USB type B port on the rear panel lets users connect a PC or Mac directly, and the newly developed Ground/Signal isolator technology helps to reduce PC noise for the highest quality sound. Dual (optical and coaxial) outputs are provided for connection to other components, and there are also dual digital inputs that allow the NA-11S1 to be used as a DAC with other digital audio sources. There’s even a high-quality dedicated headphone amplifier, which features its own output stage equipped with HDAM-SA2 devices along with a precision variable analog volume control.
The NA-11S1 is equipped with dual master audio clock generators with jitter reduction for numerous sampling frequencies and bit depths, up to 192 kHz/24 bits. The NA-11S1 also supports numerous audio file types, including WAV, WMA, MP3, MPEG-4 AAC, FLAC and ALAC, as well as DSD. The latest Marantz DSP processor (DSP PEC777f3) provides precision digital filtering, and the NA-11S1 offers a number of DSP modes that let users customize the sound, including two modes for digital sources, as well as the option of noise shaping and a DC filter with a 1.7 Hz cutoff.
Marantz Reference NA-11S1 Network Audio Player and DAC - back
For optimum audio fidelity, the NA-11S1 features high current, high resolution audiophile D/A converters, operating in differential mode for the lowest noise and widest dynamic range. The critical post-D/A current-to-voltage conversion is handled by the latest Marantz HDAM-SA2 devices, which feature precision discrete components in lieu of standard op amp chips. The final analog output stage features additional HDAM devices, and there are two output choices – unbalanced (RCA) and balanced (XLR). The balanced outputs also feature a phase-inversion option for compatibility with any XLR-equipped pre-amp.
As befits its reference-class status, the NA-11S1 features a rugged chassis with internal copper-plated surfaces. The thick 5mm top panel can easily support the weight of an additional component, and the dual-layer bottom plate and die-cast aluminum cabinet feet provide solid rigidity along with additional resistance from external vibrations. The massive power supply features a high current toroidal power transformer with multiple oxygen free copper (OFC) secondary windings, and is housed in a copper-plated enclosure for maximum shielding. Multiple separate circuit boards ensure minimal interference between the various analog and digital stages.
Price and Availability
The Marantz Reference Series NA-11S1 Network Audio Player and DAC will be available soon for $3,499.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
At $12,000, the Marantz Link 10n is the company's flagship network audio player designed to be paired with Model 10 Integrated Amplifier.
CD Players
At $12,000, the new Marantz SACD 10 is the best CD/SACD player the company has ever made and it weighs 73 lbs.
At $1,500, the Marantz 60n is a 60-watt per channel integrated amp that connects to a TV, CD Player, turntable, and streams music.
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
Part 3 of 3 from CEDIA Expo 2024 highlights Ascendo, Theory Audio, Bowers & Wilkins, L-Acoustics, TCL, JVC and Grimani Systems.
Developed over five years at the renowned Shirakawa Audio Works in Japan, the Marantz Model 10 Reference Integrated Amplifier embodies unparalleled heritage, performance and...
