Marantz’s Model 60n Network Integrated Amplifier Looks and Feels Like Its More Expensive Sibling For Less Money
At $1,500, the Marantz 60n is a 60-watt per channel integrated amp that connects to a TV, CD Player, turntable, and streams music.
Marantz Model 60n Network Integrated Amplifier
When the Model 40n was released in 2022, it was a welcome addition to the Marantz product line-up. It has all the characteristics of a great integrated amplifier from the past with the addition of streaming and multi-room wireless audio to meet the changing music-listening landscape.
For 2024 Marantz has just released another network integrated amplifier, the Model 60n which includes a lot features from the 40n but with a price tag that is $1,000 less.
Let’s take a brief look at what the 60n offers and how it compares to the 40n.
To start off, the 40n is manufactured in Shirakawa, Japan, and Sound Master Tuned to deliver the texture, nuance, and clarity of the Marantz Signature Sound.
The 60n is manufactured in Vietnam.
Marantz Model 60n Network Integrated Amplifier Rear
Marantz 60n
The 60n incorporates a 60W per channel amplifier that includes HDAM circuit technology for optimal dynamic range and lower distortion. All the physical inputs you would expect are provided such as analog, digital, USB, and MM phono inputs, as well as an ARC-enabled HDMI input for those who enjoy viewing their TVs or projectors with a 2-channel audio setup rather than a full-on AVR-based surround sound setup (although Marantz also offers a selection of AVRs to fill that the need).
Pro-Tip: The 60n includes both preamp and subwoofer outputs and the 40n’s HDMI input and output that also supports video resolution pass-through up to 8K.
HEOS
HEOS App Home Screen 2024
For additional use flexibility, the 60n incorporates the HEOS streaming platform which is accessible via the HEOS app. This allows users to access streaming services including Spotify, Apple Airplay, Deezer, iHeart Radio, Pandora, Sirius XM, Tidal, Amazon Music, and more, and is also Roon Ready. HEOS also supports wireless multiroom audio with compatible speakers and associated devices.
The 60n also incorporates Bluetooth for additional music-listening options.
Although a wireless remote is provided, the 60n also supports voice control via Amazon Alexa, Apple Siri, or Google Assistant.
Industrial Design
The 60n has Marantz’s latest industrial design. Sporting a steel top and chassis, the MODEL 60n features the same architectural design, refined materials, and intuitive operation as the CD 50n, and is available in two colorways: black and silver-gold.
Comparison
Marantz Model 60n and Model 40n Network Integrated Amplifiers
Model 60N (2024)Model 40N (2022)
Price$1,500$2,499
Product Description Network Integrated AmplifierNetwork Integrated Amplifier
Amplifier TypeClass A/BClass A/B
Amplified Channels22
PSU TransformerToroidalDouble Shielded Toroidal
Speaker A/B Switching
Speaker Terminals2 (Marantz SPKT-1+)2 (Marantz SPKT-1+)
Power Output (8 / 4 Ohm RMS)2 x 60 W / 80 W2 x 70 W/100W
Current Feedback TopologyYesInformation Not Provided
HDAM VersionSA3, SA2SA3
Symmetric PCB LayoutYesInformation Not Provided
Aluminum Extrusion Heat SinkYesInformation Not Provided
Linear Drive Power SupplyYesInformation  Not Provided
Digital InputsCoaxial, Optical, USB-ACoaxial, Optical, USB-A
Max PCM Sample Rate192 kHz / 24-bit192 kHz / 24-bit
Max DSD Sample Rate11.2 MHz5.6 MHz
HDMI1 ARC1 ARC
HEOSYesYes
BluetoothYesYes
Airplay 2Yes Yes
Roon ReadyYesYes
Spotify ConnectYesYes
Tidal ConnectYesYes
Tidal (Hi-Res)YesYes
Deezer (Hi-Res)Yes Yes
Amazon Music HDYesYes
PandoraYesYes
TuneInYesYes
iHeartRadioYesYes
SoundCloudYes Yes
SiriusXMYesYes
AWAYesYes
Mood: MixYesYes
QplayYesYes
Sony HiResYes Yes
Lossy FormatsMP3, WMA, AACMP3, WMA, AAC
Lossless FormatsDSD/DSF, FLAC, ALAC, WAV, AIFFDSD/DSF, FLAC, ALAC, WAV, AIFF
Gapless PlaybackYesInformation Not Provided
Wi-FiYesYes
Wired LANYesYes
DisplayLow-Noise OLED MonochromeLow-Noise OLED Monochrome
Phono EQMM StandardMarantz Musical Phono EQ
Audio AdjustmentsBass / Treble EQ, BalanceBass / Treble EQ, Balance
Tuner No
Source DirectYesYes
Power Amp DirectYes
Analog Audio Inputs43
Analog Record Out1
Preamp OutputsYes
Subwoofer OutputYesYes
Headphone OutYesYes
Frequency Response5 Hz-100 kHz5Hz – 100kHz
Total Harmonic Distortion (THD): (20Hz – 20kHz, 8Ω)0.02 %0.02%
Damping Factor100<100
Input Sensitivity (MM)2 mV / 47 kOhm2 mV / 47 kOhm
Signal to Noise Ratio (SNR): MM87 dB87 dB
Input Sensitivity (High Level)190 mV / 20 kOhm220 mV / 20 K ohm
Signal-to-Noise Ratio (SNR):  High Level113dB (2V input)106dB
Treble Control± 10 dB at 10kHz± 10 dB at 15kHz
Bass Control± 10 dB at 50Hz± 10 dB at 50Hz
Metal Front PanelYesYes
Power Consumption220 W220 W
Standby Consumption0.3 W0.3 W
Auto Power OffYesYes
Detachable Power CableYesYes
Remote ControlYesYes
System Remote FunctionYesYes
Voice ControlAmazon Alexa
Apple Siri
Google Assistant
Amazon Alexa
Apple Siri
Google Assistant
Dimensions (WxDxH)17.4 x 17 x 5.1 inches17.4 x 17 x 5.1 inches
Net Weight28.1 lbs36.8 lbs
Marantz Model 60n Network Integrated Amplifier Black Angle
Marantz Model 60n
Initial Impression
Coming off the recent release of the $15,000 Model 10 Integrated Amplifier that we saw and heard about at CEDIA Expo 2024, it is great to see Marantz following up with a much more reasonably priced Integrated amplifier with network features that will not only appeal to a wider customer base but has a lot the features of their popular Model 40n network integrated amp.
The Model 60n seems to fit well within the Marantz product lineup with everything you would expect from an integrated amp, as well as extensive streaming and wireless multi-room audio capability.
Marantz Model 60n Network Integrated Amplifier Silver Angle
Marantz Model 60n
Price & Availability
The Marantz Model 60n Network Integrated Amplifier is available in black or silver/gold finishes for $1,500 at Amazon or Crutchfield.
For more information: marantz.com
Related Reading
3 Comments
3 Comments
  1. Mike Cornell
    September 29, 2024 at 12:38 pm
    The back panel of the 60n clearly says Made in Vietnam, so no, the 60n is not made in Marantz’s renowned Japanese facility. The 40n, however, is.
  2. ORT
    September 30, 2024 at 1:30 am
    Make mine Silver/Gold. This and the 40n are the loverliest Integrated amps going. HEOS is excellente’!
    The ONLY thing missing is a pair of VU Meters. Dammit. Now I don’t want to buy one. VU Meters make audio more funner.
    ORT
    • Ian White
      October 5, 2024 at 1:40 pm
      ORT,
      Marantz is really making some great sounding equipment right now. The best in many decades. The bigger issue is the state of their parent company and what happens to all of the brands. We hope to see D&M sold together to someone who actually wants to own a pair of high-end legacy brands that make great equipment and have a genuine story to tell.
      IW
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
HDTV 4K & 8K TV
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Explore Craft Recordings' Record Store Day 2025 preview featuring exclusive releases from Carla Thomas, Thelonious Monk with Gerry Mulligan, and the Jazz Dispensary Night...
HDTV 4K & 8K TV
