Marantz’s Model 50 Integrated Amplifier Ditches the DAC and Streaming Capabilities
A purist audiophile integrated amp that also makes an ideal match with the Marantz CD 50n Network CD player.
Marantz Model 50 Integrated Amplifier
If your first thought looking at the new Marantz Model 50 Integrated Amplifier ($1,800 USD) is that it looks and feels like the Marantz Model 40n Network Integrated Stereo Amplifier ($2,500), but without any of its streaming capabilities or even a DAC — you would be correct.
Having just released the Marantz CD 50n Network CD player, Marantz seems to be advocating for separates once again which will actually cost you more money when you acquire both. One could add something less expensive like the WiiM Pro Plus or Cambridge Audio MXN10 Network Players to the Model 50, but why not just purchase something like the Marantz Model 40n and have everything in one component?
Having spent time with the Model 40n that offers tremendous performance for the money — this feels somewhat strange.
Features
Marantz Model 50 Integrated Amplifier Right Angle
Analog Only Circuitry: The distinguishing feature of the Model 50 is that it has no digital audio circuitry (this means no DAC). From input to output, this simplifies use and reduces audible interference.
Power: 70 watts per channel and current feedback Class A/B amplification.
Connectivity: A full suite of analog connections for sources and preamp outputs for both a Subwoofer and connection to an additional external amp.
HDAM SA-3 Modules
Musical Phono EQ: MM Phono Stage
Porthole Display: The iconic Marantz porthole status display provides easy visual setup and status information as well as prominently displaying the current volume level.
Build and Craftsmanship: The Model 50 builds on the robustness and craftsmanship of other Marantz AV products, such as Model 40n mentioned at the top of this article.
Marantz Model 50 Integrated Amplifier Rear
Specifications
  • Number of Channels: 2
  • Power Output: 2 x 70 watts (8 ohms), 2 x 100 watts (4 ohms)
  • Power Transformer: Toroidal
  • Linear Drive Power Supply: Yes
  • Heat Sink: Aluminium extrusion heat sink
  • Audio Inputs: (6 Pairs) Phono (RCA + Gnd) RCA (CD, Tuner, Line 1, Line 2, Recorder)
  • Audio Outputs: 1 (recorder or line-out) + Subwoofer
  • Power Amp Direct In:  Yes
  • Source Direct Option: Yes
  • Speaker (A/B): Yes –  A/B/A+B
  • Speaker Terminals: Marantz SPKT-1+ (Dense brass with thick nickel plating)
  • Number of Speaker Terminals: 4 (two pairs)
  • Headphone Out: Yes
  • General EQ Settings: Balance, Bass, Treble
  • Treble Control: ± 10 dB at 15 kHz
  • Bass Control: ± 10 dB at 50 Hz
  • Phono Input: MM (Moving Magnet)
  • Phono EQ: Marantz Musical
  • Frequency Response: 5Hz–100kHz
  • Total Harmonic Distortion: 0.02 %
  • Damping Factor: 100
  • IR Wireless Remote: Included
  • Dimensions (WDH): 442 × 431 × 130 mm (17.4 x 16.97 x 5.1 inches)
  • Weight: 14.2 kg/31 lb 5 oz
  • Finishes: Black or Silver/Gold
Marantz Model 50 Integrated Amp Rear Closeup
Tip: The Marantz Model 50 can be used with just about any source, but was specifically designed to pair with the new Marantz CD 50n Network CD player. The CD 50n provides all the access you need to digital sources, whether it be a CD or streaming content. The CD 50n can transfer all that audio in analog form via its DAC to the Model 50 for amplification.  Both models feature an easy-to-read status display. For added convenience, the remote control supplied with each component is able to operate either unit.
Marantz Model 50 Integrated Amplifier with CD 50n Network CD Player
Marantz Model 50 with Marantz Model CD 50n Network CD Player
Availability and Pricing
Marantz Model 50 Integrated Amplifier is priced at $1,800 at Crutchfield and authorized dealers
6 Comments
6 Comments
  1. MarkH
    October 25, 2023 at 4:50 pm
    Power amp in? What is this for?
    • Ian White
      October 25, 2023 at 5:18 pm
      Mark,
      I’ve been scanning the set-up guide for an explanation and there is nothing. I’m reaching out to Marantz for an answer. Stay tuned…
      Best,
      Ian White
    • Mark Vandenberg
      February 12, 2024 at 1:37 pm
      I realize I’m late to the party here, but this is for home theater bypass. You can connect L/R pre-outs on your AVR — if it has them — and let the Model 50 drive those channels for better sound. Great for a hybrid movie/music system.
  2. Kevin C
    October 25, 2023 at 11:44 pm
    I wonder if the preamp outs need to be routed in to make it an integrated rather than separate pre or power?
  3. Elizabeth
    October 31, 2023 at 1:15 pm
    Seems identical to the setup on previous models like my PM8003. You can use it as a preamp if you want. You can use it as a power amp if you want. If you leave everything alone then it’s a regular integrated amp and you can use the pre-outs as subwoofer outs if you want.
  4. Wade Souza
    October 23, 2024 at 3:34 am
    I wonder if it is the PM8006 repackaged. Its seems to have nearly identical features and specs. The 8006 is a class ab amp and is quite nice. I have one and have been very happy with it. I am looking to replace the dead amp in my office and was going to slot the 8006 there and get something new in my main system. I like the Marantz sound and have owned one of their units since 1975. I have not heard any of the Class D units so a bit apprehensive on those despite lots of good reviews. I do want to upgrade from the 8006 level. I think I paid around 1100 for that new maybe 5 years ago.
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
