CD Players
Marantz HD-CD1 Premium CD Player
Marantz HD-CD1 CD Player
Marantz announced the HD-CD1, a premium-class CD Player with classic looks in a mid-size design. While small in size, it makes use of state-of-the-art Marantz technology carried over from the company’s award-winning CD players, including the famous Marantz HDAM-SA2 amplifier modules. This unit builds on the success of the highly acclaimed HD-DAC1 Headphone Amplifier and HD-AMP1 Integrated Amplifier.
Marantz HD-CD1 CD Player and HD-AMP1 Integrated Amplifier
The HD-CD1 is a high-quality CD player in the same compact form as the HD-AMP1 amplifier, and a perfect match. This product combines more than 30 years of Marantz expertise in compact disc playback with the latest developments in digital audio technology. It’s ideal for use as a CD transport when used with the HD-AMP1, or as a CD player in any situation where a compact form-factor is required without any compromise on sound quality. Selected components are used throughout the audio signal path, for the very best reproduction of music. A centralized CD mechanism, able to play MP3, WMA and AAC files as well as standard CDs, is also used for ultra-accurate disc-reading. This along with its analog audio outputs, optical and coaxial digital connections which are provided, allows the HD-CD1 to be connected directly to the HD-AMP1’s ultra-high-quality digital-to-analog conversion. The HD-CD1 also features a solid aluminium front panel, double-layer chassis for vibration isolation and retro-style side panels.
Marantz HD-CD1 CD Player Back
The HD-CD1 offers all the technology that’s made Marantz a leader in top-quality CD playback. And central to that is the use of the Marantz-designed HDAM Hyper-Dynamic Amplifier Modules: in place of the all-in-one ‘chip amplifiers’ used elsewhere, these miniature amplifiers are built from separate, optimized components for the very best sound quality, and are found in Marantz products all the way up to the Reference series players and amplifiers. In the HD-CD1 the latest-generation HDAM-SA2 version of this technology is used, to provide a wide dynamic range and wide frequency response with lowest distortion – in other words, to get listeners closer to the music. HDAM technology is also used in the headphone section, which has its own dedicated amplification.
Central to the sound quality of the HD-CD1 is a high-quality CD transport mechanism, designed for ultra-accurate disc-reading. It sends data to the player’s high-resolution digital-to-analog converter, which is the same Cirrus Logic CS4398 device found in top-flight digital hardware. This is used together with a crystal oscillator master clock designed for ultra-low phase noise, and a low impedance capacitor, also designed for low noise, ensuring digital data is converted into an analog sound with lifelike dynamics and timbre, breathtaking presence and sheer musicality.
Marantz RC-031SR Remote ControlWhether listeners choose to use the HD-CD1 on their desk for full-time headphone listening, or just occasionally want to connect a pair of ‘phones for a private music session, the dedicated headphone section in the player is exceptional. To make the most of personal listening, it has its own volume control and a dedicated HDAM-SA2 amplifier, complete with adjustable gain setting – low, medium and high – to enable it to drive even highly-demanding audiophile headphones.
As well as its own high-quality analog outputs, the HD-CD1 is enabled to be used with any amplifier including the matching HD-AMP1, and the HD-CD1 has both optical and coaxial digital outputs. With this it can be used as a CD transport straight into the digital input on the HD-AMP1 allowing it to be used with the superb ESS Sabre DAC built into the amplifier. Like the analog outputs, the coaxial digital connection uses a high-quality gold-plated RCA socket, and a digital cable is supplied with the player.
The HD-CD1 has extensive measures to suppress both electrical and mechanical interference. A high-current power supply with high-capacity storage capacitors is used to ensure the player is able to deliver the dynamics of music, along with high-speed Schottky Barrier Diodes. The player also has auto-standby and very low power consumption when in standby mode. The HD-CD1 is built on a double layer base-plate for rigidity and vibration suppression, aided by the use of compliant feet, a solid aluminum fascia and a rigid top-plate, and is finished with retro-style side-cheeks for that ‘classic Marantz’ look.
Price and Availability
The Marantz HD-CD1 CD Player is expected to be available in September for $599.
Features
  • Award-winning Marantz CD drive technology
  • Support of MP3, AAC, WMA file playback
  • Intensively sound tuned with carefully selected components
  • High quality 192kHz/24bit D/A conversion (CS4398) and accurate system clock
  • Marantz proprietary HDAM-SA2 circuits
  • Full discrete headphone amplifier with HDAM-SA2 and gain control
  • Double layered bottom plate and rigid feet
  • Gold Plated L/R/Coax Outputs
  • System remote to control CD-Player and Amplifier
  • Available in black
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
At $12,000, the Marantz Link 10n is the company's flagship network audio player designed to be paired with Model 10 Integrated Amplifier.
CD Players
At $12,000, the new Marantz SACD 10 is the best CD/SACD player the company has ever made and it weighs 73 lbs.
At $1,500, the Marantz 60n is a 60-watt per channel integrated amp that connects to a TV, CD Player, turntable, and streams music.
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
Part 3 of 3 from CEDIA Expo 2024 highlights Ascendo, Theory Audio, Bowers & Wilkins, L-Acoustics, TCL, JVC and Grimani Systems.
Developed over five years at the renowned Shirakawa Audio Works in Japan, the Marantz Model 10 Reference Integrated Amplifier embodies unparalleled heritage, performance and...
