Marantz Products at EHX Spring 2009 Expo
Company To Demonstrate AV8003 Networking AV Preamp/Processor and More at the Orange County Convention Center
At the Spring 2009 Electronic House Expo, Marantz America, a world leader in advanced home entertainment solutions, will demonstrate its AV8003 Networking AV Preamp/Processor (SRP: $2,599.99), recently named a 2009 Innovations Design and Engineering Award honoree by the CEA. During the show (March 11-14), attendees will be able to experience the AV8003’s leading-edge capabilities at Booths 230A and 1302. Marantz will also display its high performance MM8003 8 Channel Power Amplifier (SRP: $2,399.99), BD8002 (SRP: $1,999.99) and BD7003 (SRP: $549.99) Blu-ray Players, and IS301 Wireless Flexible iPod Dock (SRP: $249.99), and LN-11S1 Motorized Anamorphic Lens System (SRP: $3,999.99)
Multi-Zone Processor and Controller
The Marantz AV8003 Networking A/V Preamplifier is a THX-Certified, 1080p scaling, multi-source/multi-zone processor that provides users with an easy way to distribute ultimate-quality audio and video entertainment to three separate zones within the home. Thanks to its built-in digital media player and Ethernet port, the AV8003 allows content from any DLNA compliant Server, PC or NAS device to be streamed from those devices to the AV8003, where it can then be distributed to multiple zones. Marantz’ first built-in video scaler enables enhanced video performance with upconversion and scaling to 1080p from all analog and digital sources and it features a host of today’s most advanced audio and video processing technologies, including HDMI Version 1.3a (4-in/2-out), plus Dolby True HD, dts HD Master Audio, Deep Color and more. In addition, it is HD, XM, and Sirius Radio ready (subscription and antenna required for XM and Sirius) and includes a built-in digital media player with Ethernet capability for streaming audio and video content throughout a networked home*.
MM8003: Ideal for Use With Either 7.1- or 5.1-Channel Systems
The MM8003 combines the best sonic features of past Marantz products along with new flexibility such as 8-channels, XLR input terminals, output channel relay on/off control and slow start to power-on as well as the beautiful new chassis. The MM8003 is ideal for meeting the demands of any multi-channel home theater system, including both 7.1-channel and 5.1-channel systems. (In the case of 5.1-channel systems, the additional channels may be used for “vertical bi-amping,” which provides the ultimate level of dynamics, bass response and sheer presence.) Boasting 140 watts per channel, the MM8003 will provide clean and stable power to any speaker package available.
IS301: Flexibility of Tabletop or On-Wall Placement
The IS301 system consists of a slim lightweight handset (IS301) that attaches to the user’s iPod, as well as a stylish and compact base unit (IS301DS) that’s designed for either tabletop or on-wall placement. An additional RX unit (IS301RX) provides advanced wired connection (CAT5-1/2 audio control, CAT5 — 2/2 video) to a user’s home entertainment system, featuring Analog Audio L/R output, as well as Component, S-Video, and Composite Video outputs, making it easy to use the IS301 as an expansion device. The RX unit also features both IR Flasher input and RS232C control for expandability, and it may be connected with any device that supports Bluetooth A2DP.
BD8002, BD7003: Leading Edge Blu-ray Features and Performance
Thanks to its 10-bit Silicon Optix Realta chipset, the BD8002 Blu-ray DVD player offers improved video performance with upconversion and IP scaling to 1080p. The pixel-by-pixel and Digital Noise Reduction feature afforded by this technology allows the player to remove image-degrading artifacts, resulting in absolutely clear, high-resolution images. The BD8002 also offers High Resolution HD Audio with decoding of Dolby Digital Plus, Dolby True HD and DTS-HD Master Audio and is capable of outputting both 7.1-channel analog signals and PCM audio via HDMI. Finally, in addition to its compatibility with both Blu-ray and DVD discs, the BD8002 can also handle VCDs, SVCDs, MP3s, WMA and DivX video files, and display JPEG images — making it the ideal solution for high-quality enjoyment of today’s many audio and video formats.
With its lower price point, the BD7003 Blu-ray DVD player brings a superior Marantz Blu-ray video and audio experience within reach of more consumers. Thanks to its HDMI 1.3a with Deep Color and Bonus View support, users enjoy richly detailed images and vibrant color production, with 1080p scaling from SD DVDs for additional viewing enhancement. And the BD7003’s audio capabilities are just as impressive: Once the player’s HD audio bitstream is outputted to a connected receiver in a user’s home entertainment system, the signal can then be decoded to high-performance audio formats including Dolby Digital Plus, Dolby True HD and DTS HD Master Audio. The result is dynamic sound reproduction for all home entertainment applications, including both music soundtracks and dialogue.
High-Performance Lens Can Easily Be Retrofitted to Installed Projectors
Currently available for purchase, the new LN-11S1 anamorphic lens features a quiet motorized lens/sled assembly that not only provides for smooth, quiet operation but can also be retrofitted for use with virtually any VP-11S1, VP-11S2 or VP-15S1 already installed in a home theater system. The LN-11S1 features multi-adjustment lens mounts and trigger inputs for easy custom automation and sled activation. A specially designed custom mount is included with the LN-11S1, providing efficient and reliable attachment to the VP-11S1, VP-11S2 or VP-15S1. Additionally, the LN-11S1 is also designed to work with other brands of projectors that incorporate vertical stretch technology.
*A home network is required for streaming of content through the home.
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our favorite integrated amplifiers for audiophiles in 2025 includes models from WiiM, Advance Paris, Moon by Simaudio, Quad and Marantz.
Find out everything the HEOS app can do to simplify and manage a whole-home audio system with Denon and Marantz gear.
Our favorite streaming amplifiers of 2025 for audiophiles include models from WiiM, Marantz, Ruark, Naim and Aavik.
This is the really good stuff for audiophiles, music lovers and home theater enthusiasts that's guaranteed to impress.
Coming early 2025, Marantz previews two modern luxury wireless speakers featuring unique technology, priced at $3,500 and $5,500.
Phil Jones from Harman reveals what makes Denon and Marantz A/V receivers unique to help you decide which model is right for your home...
CEDIA Expo 2025 featured many fine speakers, amps, processors and other audio-related gear. Here are our picks for Best in Show.
Movies
High-end audio, wireless headphone chaos, Spotify’s fake “lossless,” and Hollywood’s latest implosion — from Taylor Swift’s box office reign to Marvel’s flops, the dogs...
