CD Players
Marantz CD6005 CD Player
Marantz today announced the CD6005 hi-fi compact-disc player for audiophiles, which features proprietary Hyper Dynamic Amplifier Module (HDAM) discrete circuit topology along with a high-resolution CS4398 D/A conversion system, which delivers up to 192 kHz/24 bit resolution. The company says the CD6005 is designed to deliver the utmost in musical fidelity, although it doesn’t play SACD.
The center-mount CD drive mechanism is securely fastened to the chassis to minimize vibrations, and the digital audio circuit block is housed in its own shielded subsection. The player is compatible with music CDs, CD-R and CD-RW discs, and can play a wide range of file types, including WAV, AAC, WMA and MP3 files. A convenient USB port on the front panel works with many USB memory devices, and is iPod and iPhone compatible so users can enjoy their favorite iTunes tracks with thrilling sound quality.
Marantz CD6005 CD Player Back
The CD6005 player even provides a headphone amplifier circuit in a discrete configuration that outperforms separate headphone amps and lets users enjoy high-speed, high-resolution sound through their headphones. To round out listeners’ total enjoyment of music, the CD6005 is equipped with an easy-to-read two-line alphanumeric fluorescent display, and includes a remote control unit that can also operate the matching PM6005 integrated amplifier.
Marantz CD6005 Remote ControlPrice and Availability
The Marantz CD6005 CD player is available now for $499, with a three-year warranty for parts and labor.
Features
  • Disc Capacity: 1
  • Playback Formats: Disc: CD, CD-R/RW(CD-DA/MP3/WMA, AAC), USB: MP3/WMA/WAV/AAC/iPod/iPhone/iPad
  • HDAM: HDAM-SA2
  • Current Feedback Analog Stage: No
  • Power Transformer: No
  • Zero-Impedance Plate: No
  • Double Layerd Bottom Plates: yes
  • Audio DAC: Cirrus Logic CS4398
  • Display On/Off: No
  • Selectable Filters: No
  • SACD/CD Text: No
Inputs/Outputs
  • Analog L&R In: 1
  • Headphone Out: 1 (with Level)
  • Digital Out Coax: 1, Opt: 1
  • Digital In: No
  • Other In/Out USB-A (iPod) : 1(Front)
  • External control: Flasher In
  • D-Bus Remote (RC-5) In/Out: 1/1
Specifications
  • SACD Format: No
  • CD Audio Format: 16-Bit Linear PCM
  • THD: 0.002%
  • Sampling Frequency: 44.1kHz
  • Dynamic Range: 100dB
  • Frequency response: 2 Hz – 20 kHz
  • Color: Black
  • Front Panel: Aluminum/Glass-reinforced resin
  • Remote Control: Device Remote with Marantz Amp. Basic Control Function
  • Power Requirement: AC 120V 60Hz
  • Power Consumption: 32W (Standby: 0.3W)
  • Dimensions W x H x D (Inches): 17.3″ x 4.1″ x 13.4
  • Weight (lbs): 14.6 lbs
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
At $12,000, the Marantz Link 10n is the company's flagship network audio player designed to be paired with Model 10 Integrated Amplifier.
CD Players
At $12,000, the new Marantz SACD 10 is the best CD/SACD player the company has ever made and it weighs 73 lbs.
At $1,500, the Marantz 60n is a 60-watt per channel integrated amp that connects to a TV, CD Player, turntable, and streams music.
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
Part 3 of 3 from CEDIA Expo 2024 highlights Ascendo, Theory Audio, Bowers & Wilkins, L-Acoustics, TCL, JVC and Grimani Systems.
Developed over five years at the renowned Shirakawa Audio Works in Japan, the Marantz Model 10 Reference Integrated Amplifier embodies unparalleled heritage, performance and...
