Marantz AV7701 Preamplifier / Processor
Marantz AV7701
Marantz announced the 7.2-channel AV7701 Home Theater Preamplifier offering 4K video support, Apple’s AirPlay, and networking capabilities with advanced system-building flexibility for custom integrators. With AirPlay, users can stream iTunes music, whether from a Mac or PC, as well as directly from their iPhone, iPad or iPod touch. Like all Marantz premium separates, the AV7701 features the striking Marantz chassis design, with an aluminum front panel, the traditional Marantz star and the immediately recognizable illuminated Marantz front porthole display.
A broad range of network and streaming functions in the AV7701 allows users to listen to portable devices via Bluetooth, with the optional RX101 Bluetooth adapter, or when connected to a home network, users can enjoy thousands of internet radio stations via Pandora and SiriusXM Internet Radio services, as well as the popular Spotify music service. The AV7701 is also DLNA 1.5 certified for compatibility with multimedia PCs and other devices. A front panel USB port allows for direct connection to portable devices, and two sets of main audio outputs are provided, including 7.2 channel unbalanced (RCA) jacks as well as 7.2 channel balanced (XLR) outputs.
Marantz AV7701 - back
Marantz RC016SR Remote ControlDesigned for total “future-readiness,” the AV7701 features the latest video processing technologies, and includes the ability to upconvert SD and HD content to 4K high resolution video (3840×2160) for compatibility with advanced video displays. Adding to its leading-edge benefits package, users may control the AV7701 using the newly designed Marantz Remote App, allowing a new level of freedom and flexibility.
Connectivity options include seven HDMI inputs, along with three HDMI outputs, all compatible with 3D and 4K content. Two of the HDMI outputs let users play their favorite movies and shows on two separate HDTVs, while the third HDMI output lets viewers in another room watch a second program from another source. Both main HDMI outputs feature Audio Return Channel functionality. There are also multiple analog video inputs, including component and composite video for hooking up legacy standard definition (SD) and high definition (HD) sources, as well as a 7.1 channel audio input.
The AV7701 features the latest digital audio decoders, including Dolby TrueHD and Dolby Pro Logic IIx, along with DTS-HD Master Audio. There’s also the option for configuring the system to deliver additional front height or front width channels to dramatically expand the front soundstage, and the AV7701 can also be configured for bi-amp mode for the front main (L/R) speakers. The AV7701 also features Marantz HDAM discrete pre-amplifier modules along with our exclusive current feedback design which together, provide superb sound quality.
Audyssey’s MultEQ XT automatic room acoustic correction system analyzes the sound output from every speaker in the room (microphone included), and generates precision digital filters that provide optimum sound quality with virtually any combination of speaker sizes and types. Audyssey Dynamic Volume provides a high fidelity listening experience at reduced volume levels, allowing late night listening without disturbing other family members, and Audyssey Dynamic EQ delivers full range sound quality regardless of the volume control setting. Audyssey DSX processing provides the option of additional front height or front width sound channels, dramatically expanding the front soundstage. Marantz M-DAX audio processing is also included, which re-processes compressed audio sources to deliver the full dynamic range of the original musical performance.
Price and Availability
The Marantz AV7701 Preamp/Processor will be available late-September 2012 for $1,699 (check price).
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
At $12,000, the Marantz Link 10n is the company's flagship network audio player designed to be paired with Model 10 Integrated Amplifier.
CD Players
At $12,000, the new Marantz SACD 10 is the best CD/SACD player the company has ever made and it weighs 73 lbs.
At $1,500, the Marantz 60n is a 60-watt per channel integrated amp that connects to a TV, CD Player, turntable, and streams music.
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
Part 3 of 3 from CEDIA Expo 2024 highlights Ascendo, Theory Audio, Bowers & Wilkins, L-Acoustics, TCL, JVC and Grimani Systems.
Developed over five years at the renowned Shirakawa Audio Works in Japan, the Marantz Model 10 Reference Integrated Amplifier embodies unparalleled heritage, performance and...
