Is the Magnetar UDP900 4K UHD Blu-ray Player a Good Deal?
Priced at $2700, will Magnetar’s UDP900 Flagship Universal Disc Player appeal to audiophiles and videophiles?
Magnetar UDP900 UHD Blu-ray Disc Player Sky
The past few years haven’t been kind to the Blu-ray format. With the ever-increasing popularity of video streaming services, physical video formats such as DVD, Blu-ray, and UHD 4K Blu-ray aren’t even on the radar of consumers anymore; even though the video quality of streaming content still doesn’t match that of the best Blu-ray or UHD 4K Blu-ray Discs.
As a result, Samsung stopped making disc players in 2019, and Sony, Panasonic, and LG have had the same DVD, Blu-ray, and UHD Blu-ray players in the product line-up for over two years.
However, it was the announcement in 2018 that Oppo Digital, maker of reference standard Blu-ray/UHD Blu-ray players for consumers and professionals was ceasing production that made videophiles take notice that the future of Blu-ray wasn’t as secure as once thought. However, even with their discontinuation, existing Oppo players are still used in high-end home theater, video editing suites, and as video source devices at trade shows.
As a result of this demand for high-end disc players, two companies have sprung up to fill the gap, Reavon, and Magnetar Audio
Magnetar UDP900 UHD Blu-ray Disc Player Front
The Magnetar UDP900
What is getting the most attention right now (Spring 2023) is the impending release of the Magnetar UDP900 4K UHD Blu-ray Disc player. This player is designed to deliver high-end video and audio performance for both high-end video and audio systems.
Features
Magnetar UDP900 UHD Blu-ray Disc Player Features
Universal Player: This means that the UDP900 can play almost any video or audio disc format. On the video side that includes DVD, Blu-ray (including 3D), UHD Blu-ray, Audio CDs, DVD-Audio, and SACD discs.
4K: For video, the UDP900 can not only upscale video sources to 4K but can output native 4K resolution when playing UHD Blu-ray Discs.
HDR: Additional video support includes compatibility with HDR10, HDR10+, and Dolby Vision formats.
Surround Sound: On the home theater side, the UDP900 is compatible with most surround sound formats including Dolby Atmos and DTS:X.
Onboard Audio Decoding or Pass-Through: The UDP900  can decode surround sound formats internally and pass audio out via HDMI or its 7.1 channel analog audio outputs, or just pass the format undecoded using bitstream passthrough for decoding by an AVR or AV Preamp/Processor depending on the needs of your system.
Tip: In order to use the 7.1 channel analog output option, you need an AVR, AV Preamp/Processor, or a mix of power amplifiers that can provide a total of 7.1 channel analog inputs.
Pure Audio: The UDP900  also shines with audio playback from DVD-Audio, SACD, and other Hi-Res Audio formats (via HDMI or USB). For additional audio quality support, Pure Audio Mode bypasses all unneeded video and audio processing to provide uncompressed audio free of interference.
DACs: ESS9038PRO DACs used for the 2-channel XLR balanced and RCA unbalanced outputs. An ESS9028PRO DAC is used to prepare 7.1 RCA analog outputs. Support for XMOS USB Audio input is also supported.
Audio Connectors: The UDP900 has premium stereo XLR gold-plated balanced and stereo RCA gold-plated unbalanced outputs.
Circuit Support: To support high-end audio performance, the UDP900 incorporates a 4-layer PCB circuit board where each audio channel is designed with independent wiring.
Network Connectivity: Although the UDP900 doesn’t have any streaming features, you can access content from local network devices (PCs, Laptops, Media Servers, NAS Drives) via Ethernet connectivity through a home router (the UDP900 is also DLNA compatible).
Tip: The UDP900 can also access internet-based BD-Live content associated with specific Blu-ray disc titles.
Solid Build: In addition to video and audio performance, the UDP900 has an all-aluminum alloy body and a reinforced double-layer chassis structure. The internal main components are independently shielded by a metal case. This reduces vibration, noise, and external magnetic field interference.
Magnetar UDP900 UHD Blu-ray Disc Player Top Open
Specification (continued)
  • Disc Support: UHD Blu-ray, Blu-ray, Blu-ray 3D, DVD-Video, DVD Audio, AVCHD SACD, Audio CD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE
  • Additional Video File Support: MKV, AVI, MP4
  • Video Output Resolution (HDMI 2.0b): 4K UHD / 1080p24  / 1080p / 1080i / 720p / 576p / 576i / 480p / 480i
  • Audio Output (HDMI 2.0b): Up to 7.1 channel 24-bit/192kHz PCM, up to 5.1 channel DSD, Bitstream (Dolby Atmos/DTS:X)
  • Additional Audio File Support: WAV, FLAC, APE, DSD
  • Audio Output (Optical/coaxial):  2 channel/192kHz PCM, Dolby Digital, DTS
  • Audio Outputs (Multi-channel Analog): 8 RCA unbalanced
  • Audio Outputs (Stereo Analog): XLR balanced (1) and RCA unbalanced output (1)
  • Audio-only Input: USB (provides up to 16TB hard drive support in addition to USB flash drives)
  • Dimensions (with feet): 445 x 321 x 133 mm (17.52 x 12.64 x 5.24 inches)
  • Weight: 15.5Kg (34.17lbs)
Magnetar UDP900 UHD Blu-ray Disc Player Rear
Availability and Pricing
The Magnetar UDP900 will be available for $2,700 in the US, £2,200 in the UK, and €2,490 in the EU when it launches. The exact release date is forthcoming. List of Magnetar Global Distributors
Tip: Value Electronics is an authorized US Dealer for the Magnetar UDP900.
Advantages of Physical Media
You can’t afford to purchase all your favorite content on physical media, but despite the advent of streaming, it still has a valuable role to play. Here are three things to consider:
  1. It’s not guaranteed that your favorite movie or show will always be available on a streaming service. Most streaming services cycle content in and out on a monthly basis.
  1. If you buy a digital version of a movie, it may not remain accessible over the long term, despite assurances by the streaming/download service you “purchased” it from.
  1. Unlike physical media, a streaming or digital version can be altered, censored, or removed for a variety of reasons including the changing winds of political or cultural standards.
7 Comments
7 Comments
  1. Scott Muh
    April 30, 2023 at 2:42 am
    Unfortunately, just like every other player since the Oppo demise, it’s missing their best feature that is the HDMI IN. For someone with a 100% analog system other than the digital Blu-ray player, that is actually must for me!
    In your list of the advantages of physical media, you forgot the most obvious one. Video and especially audio is *way* better on physical disk and streaming will ever offer!
    • Ian White
      April 30, 2023 at 12:47 pm
      Scott,
      I agree with you 100%.
      Best,
      Ian White
    • J in B
      May 25, 2023 at 2:51 pm
      hi, can you please explain WHY the HDMI IN is important? I have a 100% analog rig as well (I think): LCD TV and I run a blu ray player through my all-analog integrated amplifier for two-channel audio. What can’t I do without the HDMI IN on my blu ray player? Thanks (I’m trying to learn before I buy).
      • Rob
        May 28, 2023 at 4:10 pm
        I am not sure either? Perhaps if you have a streamer (eg Roku) that only has hdmi out you could use the blu rays hdmi input and the analog outputs directly to your preamp? Fortunately; I picked up an old Roku with an optical output that I run into a separate DAC then into my preamp
      • Rob
        May 28, 2023 at 4:15 pm
        As another follow up to your question, I suppose you could also use the video scaling feature internal to the blu ray player.
  2. Bigears!
    May 4, 2023 at 10:56 am
    another clone. after Oppo ( US collaborators if I remember well ?) GIEC, Reavon, Pannde, Block (price down, be aware), how many new clones 100% made in Shenzhen, China ? Poorly translated instructions and permanent updates for the 800 (check their website).
    A bit expensive for the weight if you already have very good UHD/bluray player and CD player, no ?
    And not especially beautiful. I would have liked a nice brushed aluminum, like in the 80’s.
    It’s a pity that the Japanese don’t release new products anymore, at least outside Japan (great choice at Panasonic there !)
    • Ian White
      May 4, 2023 at 3:11 pm
      Big,
      I held onto my Oppo and whilst it won’t last forever, it has always worked well. I do have 3 Panny UHD 4K players that have proven to be very reliable as well.
      Best,
      Ian White
Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Because your streaming service doesn't cut it and these are 4K Blu-ray players in 2025 that still matter.
From media players to video processors, giant TVs and auto-masking screens, here are our picks for best video products at CEDIA Expo 2025.
Magnetar’s blu-ray disc players prove physical media isn’t dead with 4K UHD, hi-res audio, Roon Ready, and reference build quality that will take a...
Howdy by Roku offers ad-free streaming for just $2.99/month with a solid library but lacks the latest blockbusters and premium features like HDR and...
Streaming killed physical media—or did it? Explore the rise of indie record stores, the vinyl and Blu-ray comeback, and why real ownership still matters...
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
At $300, Sony is going to make UHD 4K fans both happy and somewhat upset with new UBP-X700/K Blu-ray disc player for 2025.
The kiosk DVD and Blu-ray disc rental service Redbox is shutting down. Is physical entertainment media doomed?
