Magico’s $135,000 S7 Speakers Set for AXPONA 2026 Debut [Updated]
Magico previews the S7 flagship loudspeaker ahead of AXPONA 2026. Can its latest S-Series design compete with Wilson, Estelon, and Børresen?
Magico S7 2026 Loudspeaker Views
Update: Pricing has been corrected from our original report.
Magico, the California-based loudspeaker manufacturer known for its obsessive focus on enclosure rigidity, advanced driver materials, and extremely tight build tolerances, will preview its new S7 2026 floorstanding loudspeaker at AXPONA (Audio Expo North America), taking place April 10 to 12, 2026 in Schaumburg, Illinois. The S7 enters a segment of the ultra high-end loudspeaker market that has become increasingly competitive, with companies such as Børresen, Estelon, and Wilson Audio all taking different approaches to cabinet construction, driver technology, and system tuning in the race to build reference level loudspeakers that now regularly push past the six figure mark.
Magico’s S Series has traditionally served as the company’s bridge between its flagship statement products and the rest of its lineup, and the S7 appears positioned to continue that role. Debuting the speaker at AXPONA places it in front of one of the largest gatherings of dealers, media, and serious audiophiles in North America, where comparisons to some of the most ambitious loudspeakers currently on the market are inevitable.
magico-s7-2026-loudspeaker-angle
A New Reference in the Company’s S Series Lineup
The S7 2026 is a 384 pound, five driver, three-way floorstanding loudspeaker designed as the flagship of Magico’s S-Series lineup.
The current generation of the S Series began with the introduction of the S3 in 2023, a model that set a new performance benchmark for the line. It was followed by the larger and more ambitious S5 in 2024, which expanded the series with greater scale and output capability. Later that same year, Magico introduced the more compact S2, bringing much of the series’ core technology to a smaller form factor while maintaining the company’s focus on rigidity, driver control, and low coloration.
S7 Development: Advanced Measurement and Engineering from the M Series
The Magico S7 is the result of an extensive research and development program that incorporates engineering tools and methodologies first introduced in the company’s flagship Magico M Series loudspeakers.
During development, Magico used a Near Field Scanner (NFS) robotic measurement system to perform detailed acoustic analysis of the loudspeaker across the full three dimensional space surrounding it. This system allows engineers to capture both on axis and off axis behavior, generating a comprehensive acoustic map of the speaker’s performance.
According to Magico, the data gathered from these measurements was used to refine the S7’s driver integration, crossover behavior, and overall acoustic balance. The company states that the goal was to move the design closer to the theoretical ideal for a multi way loudspeaker while maintaining the accuracy, coherence, and low coloration that define the S-Series.
magico-s7-2026-loudspeaker-back
Enclosure
The S7’s aluminum enclosure features a curved, sculpted form refined through extensive 3D modeling and simulation to reduce internal resonances and improve overall structural rigidity. The cabinet design also allows Magico’s proprietary damping techniques to operate more effectively, while the curved front baffle helps minimize diffraction and improve acoustic consistency.
Magico engineers also employed a Laser Vibrometer to measure extremely small cabinet vibrations and the sound pressure they generated. This level of analysis made it possible to identify and address unwanted resonances early in the development process, with the goal of creating a cabinet that adds no audible coloration to the signal.
As part of the redesign, the S7’s internal volume has been increased from 135 liters to 180 liters compared to the previous S Series flagship. According to Magico, the larger enclosure extends bass response by approximately 5 Hz while maintaining the same overall speaker sensitivity, allowing the S7 to deliver deeper low frequency extension without sacrificing efficiency.
Driver Technology
Driver technology remains central to every Magico loudspeaker design, and the S7 incorporates the company’s latest work in materials and driver architecture.
At the core of the S7 is Magico’s eighth generation Nano-Tec cone, which uses an aluminum honeycomb core sandwiched between graphene reinforced carbon fiber skins. The structure is designed to combine low mass with high rigidity and effective damping, allowing the driver to maintain control across a wide operating range while reducing distortion.
The cone is mounted in an all new third generation driver chassis developed over three years of research and refinement. The redesigned platform improves force distribution and suspension geometry, and uses a dual post architecture intended to balance dynamic wire tension. According to Magico, the design increases structural stiffness while reducing resonance and improving airflow around the motor structure.
The S7 also incorporates three vertically aligned woofers — a configuration derived from technology first used in the Magico M Project loudspeaker. This layout is intended to reduce floor bounce effects and help smooth in room frequency response contributing to more consistent midbass performance in typical listening environments.
magico-s7-2026-loudspeaker-side
Tweeter
For high frequency reproduction, the S7 uses a tweeter derived from those found in Magico’s M Series loudspeakers. Its 28 mm diamond coated pure beryllium diaphragm offers an extremely high stiffness to weight ratio and is driven by a powerful neodymium motor system designed to reduce distortion and improve power handling.
Magico also used extensive FEA modeling to optimize the tweeter’s rear chamber and acoustic loading. According to the company, this approach helps refine high frequency behavior while maintaining the level of detail, control, and transparency expected from its reference level designs.
Midrange
The S7 features a 6-inch midrange driver built around a 3-inch titanium voice coil housed in Magico’s third generation driver chassis. The driver uses the company’s Nano Tec Gen 8 cone along with a full copper cap and oversized neodymium magnet system designed to improve control and reduce distortion.
According to Magico, the combination is intended to deliver highly accurate midrange performance in both frequency response and time domain behavior, with the goal of preserving clarity and tonal realism across vocals and acoustic instruments.
Woofer
For low frequencies, the S7 incorporates three 10-inch woofers built around a 5-inch titanium voice coil and Magico’s Nano Tec-Gen 8 cone. Each woofer also employs a large copper cap and offers approximately half an inch of linear excursion to maintain control at higher output levels.
According to Magico, the design is intended to deliver deep and controlled bass response while maintaining low distortion and consistent performance across a wide dynamic range.
Crossover Design
The S7’s five drivers are integrated through Magico’s Elliptical Symmetry Crossover (ESXO), a three way network that uses acoustical target 24 dB Linkwitz-Riley slopes. This design approach is intended to maintain phase and frequency linearity while reducing intermodulation distortion, allowing the drivers to operate as a more cohesive system.
The ESXO crossover also incorporates high grade components from Mundorf in Germany. For the first time in an S-Series loudspeaker, the S7 also includes CAST PP Radial capacitors from Duelund Coherent Audio in Denmark, which Magico says contributes to improved coherence and stability across the audible frequency range.
Finish Options
The S7 will be offered in a range of premium finishes, including six Softec powder coat options designed to provide deep color, a smooth texture, and long term durability. Buyers will also be able to choose from six High Gloss automotive paint finishes that are polished to a mirror like surface and sealed with a protective clear coat.
Support System
The S7 speaker enclosure incorporates a precision-engineered three-foot support system with constrained-layer damping, further enhancing mechanical stability and sonic performance.
magico-s-series-loudspeakers
Left to right: S5, S7,
Comparison
Magico ModelS7 (2026)S5 (2024)S3 (2023)S2 (2024)
Product TypeFloorstanding SpeakerFloorstanding SpeakerFloorstanding SpeakerFloorstanding Speaker
Price (pair) matte finish$135,000$74,500 $45,500 $34,000-$37,400
Price (pair) high gloss$150,000 $83,000$52,500$39,100-$43,000
Speaker Type3-way,
5-driver
3-way,
4-driver
3-way,
4-driver
3-way,
4-driver
Tweeter1 x 1.1” (28mm) Diamond-Coated pure-beryllium diaphragm 1 x 1 x 1.1″ (28mm) Diamond Coated Beryllium Dome1 x 1.1″ MB5FP Diamond Coated Beryllium Dome (x1)1 x 1.1” (28mm) pure-beryllium, diamond-coated diaphragm
Midrange1 x 6” Nano-Tec Gen 8 driver1 x 6″ (15.24cm) Graphene Nano-Tec Gen 8 Cone Midrange5″ Gen 8 Midrange driver (x1)1 x 5” midrange driver
Woofers3 x 10” Nano-Tec Gen 8 bass drivers2 x 10″ (25.4cm) Graphene Nano-Tec Gen 8 Cone9″ Gen 8 Bass driver (x2)2 x 7” bass driver
Impedance4 ohms 4 ohms4 ohms4 ohms
Sensitivity89dB88dB88dB86.5dB
Frequency Response20Hz – 50kHz20Hz-50kHz (in-room) 24Hz – 50kHz26Hz – 50kHz
Recommended Power50W – 1000W 50W – 1000W50W+50W – 300W
Dimensions (WDH)22.9 x  24.1  x 55.9 inches
58.17  x 61.21 x 141.99 cm
19 x 19.3 x 48 inches
49 x 48.5 x 122cm
12 (17″ outrigger) x  17 x 44 inches
30 x  43 x 112cm
15.56 (with outriggers) x 13.59 x 43.48 inches
39.5 x 34.5 x 110.4cm
Weight384 lbs
(174 kg)
262 lbs
(118 kg)
222 lbs
(101 kg)
132 lbs
(60 kg)
The Bottom Line
The Magico S7 represents the most ambitious loudspeaker yet in the company’s S- Series, combining the enclosure engineering, driver technology, and crossover refinement developed over the past several product cycles. With a large aluminum cabinet, three woofer configuration, updated midrange and tweeter implementation, and Magico’s latest Elliptical Symmetry Crossover, the S7 is designed to deliver greater scale, deeper bass extension, and improved driver integration than previous models in the line.
At more than $135,000 per pair depending on finish, the S7 clearly sits in the ultra high end category. Loudspeakers at this level also demand serious supporting gear, and prospective owners will almost certainly need to invest well into six figures for amplification, source components, and cabling to extract their full potential.
Before anyone gets too dizzy looking at the price tag, it’s worth remembering that the top of the loudspeaker market has moved even further up the ladder. Compared to statement models like the Børresen M8 Gold Signature loudspeakers, which stretch past the one million dollar mark per pair, the Magico S7 almost starts to look…reasonable. Almost.
Price & Availability
The new 2026 Magico S7 floorstanding speakers are priced starting at approximately $135,000 per pair for the Softec finish and $150,000 for the High Gloss finish, with shipping expected in Q3 2026.
The official S7 product page has not been posted yet, but in the meantime, you can check out Magico’s Official S-Series product page.
2 Comments
2 Comments
  1. Anton
    March 13, 2026 at 5:18 pm
    It’s no wonder the headphone industry can get away with charging $6,000 for a pair of headphones.
    $200,000 for a pair of speakers. Could be worse — could be those obscene looking Børresen speakers for $1 million dollars.
    I know that Magico makes good speakers but $200 is utterly ridiculous.
    • Ian White
      March 13, 2026 at 9:23 pm
      I think there is a big difference between $6,000 headphones and $200K speakers in a rather wide number of ways. You would (hopefully) get superior dynamic capabilities, more robust bass performance, and midrange and treble performance.
      That being said, the $6,000 Audeze CRBN2 are very special headphones. I would buy them if I could afford them.
      IW
Splurge Audio Video Hi-Fi Tech Gifts 2026
Linn's new 343 brings Pistonik bass to a compact floorstander, with Exakt Integrated and powered-bass versions starting at $67,500 per pair. Worth the premium?
Fyne Audio celebrates a decade with its most advanced IsoFlare driver, integrated SuperTrax and just 30 pairs of the $50,000 F1-10 Anniversary.
Magico rebuilds the A3 with M9-derived engineering, new drivers and a new cabinet. The other upgrade? Entry-level Magico now costs $25,000.
Can Castle’s new Tintagel and Walmer speakers challenge established rivals with ribbon tweeters, real wood cabinetry, and pricing from $2,749?
Loudspeakers
Diapason has built handcrafted Italian loudspeakers since 1987. With MoFi Distribution and Paolo Tezzon behind it, the U.S. may finally notice.
