Keyboards
M-Audio Keystation Mini 32 Keyboard Controller
Avid today announced the M-Audio Keystation Mini 32, a 32-note, USB bus-powered keyboard controller designed for musicians on the go. Small enough to fit in a backpack, this ultra-portable controller delivers unmatched playability in its class.
Simply plug it into your computer or iPad and perform two-hand parts with 32 great-feeling, low-profile mini-keys. Customize the keyboard sensitivity to your playing style with highly musical velocity curves–including one specifically for drum programming. Control your performance with four assignable controls, including a rotary knob. And easily play and write music using the included software.
Features
  • 32 low-profile mini-keys, enabling musicians to play two-handed parts
  • Highly musical velocity curves, allowing keyboard sensitivity customization to individual playing styles
  • 4 assignable controls, including a knob, providing real-time control of DAW and virtual instrument functions
  • USB bus-powered, plug-and-play connectivity including iPad compatibility (iPad Camera Connection Kit required; check specific apps to verify MIDI support)
Availability and Pricing
M-Audio Keystation Mini 32 is now available for $99.99.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
