Luxman LMC-5 MC Cartridge Might Cost More Than Your Turntable
The Luxman LMC-5 MC Cartridge is their first in 40 years. At $2,695, it needs to be their best cartridge in 40 years as well.
Luxman LMC-5 Phono Cartridge on Turntable
Luxman is one of our favorite Japanese high-end brands for the simple reason that it doesn’t do a refresh every year and the build quality is incredibly high; one pays a hefty price for that quality but you’re unlikely to upgrade it anytime soon.
The turntable side of its business has focused on 3 models that were recently discontinued after remaining in the lineup for almost 6 years; the company has been quiet about replacement models but we suspect tables designed around this cartridge are forthcoming.
Not since the original LMC-1 of 1981 and 1982 follow-up model LMC-2 has Luxman offered a phono cartridge. That 40-year absence ends now with the introduction of the LMC-5 moving coil cartridge.
Luxman LMC-5 Phono Cartridge low
“This new reference class MC cartridge is the result of two years of research into every aspect of cartridge design,” says Jeff Sigmund, president of Luxman America. “Our LMC-5 is designed and intended to satisfy demanding music listeners with a unique purity of reproduction; the result of painstaking materials evaluations, repeated prototyping and extensive listening tests. The resulting sound quality must be heard to be appreciated.”
Stylus and Mechanics
To reveal the full richness of vinyl music playback, Luxman engineers decided on a moving coil design, preferred for ultra-low armature moving mass. A Shibata profile stylus type was selected for its ability to deliver extended high frequencies with low groove tracing noise, even on challenging inner grooves.
This solid nude, square shank diamond stylus is fixed to a low mass, 0.5 mm aluminum pipe cantilever, with this combination preferred for sonic characteristics and high trackability.
Luxman LMC-5 Phono Cartridge with shell up
To secure the fulcrum of the vibrating system, the single-point support uses a high-precision piano wire some 80 micrometers in diameter, about the thickness of a human hair.
The MC generator incorporates a cross-mounted iron core with the left and right coils wound symmetrically for superior channel separation. To achieve optimally consistent coil windings with minimum moving mass, the coils themselves are even thinner than the piano wire.
Luxman chose the thinnest available Urethane Enameled Wire (UEW), 30 micrometers in diameter. Because the coil and magnetic field are uncommonly compact, the cartridge is highly resistant to external noise.
Luxman LMC-5 Phono Cartridge up
Structure and Design
Like a microphone, a phono cartridge converts mechanical motion into voltage. So it’s no surprise that phono cartridges are subject to microphonics, the unwanted pickup of ambient sound that inevitably colors the music reproduction. Luxman engineers understood that the coil and the cantilever of closed-body moving coil cartridges are particularly sensitive to reflected sound. For this reason, the LMC-5 has an open-body design.
To control weight and suppress resonance, the cartridge outer housing is pared down substantially. Even the housing’s inverted egg shape is carefully tailored to minimize sound reflection and resonance. The product of painstaking engineering and extended listening tests, the LMC-5 reproduces treasured vinyl with effortless musicality.
Luxman LMC-5 Phono Cartridge with shell low
The precision machined aluminum body is anodized to a deep red, Luxman’s corporate color, with a laser etched Luxman “L” in front. In the best tradition of Japanese cartridge manufacture, each cartridge is carefully assembled by Luxman’s craftspeople and delivered to music lovers worldwide.
The LMC-5 moving coil cartridge is available now at a suggested retail price of $2,695.
For more information: luxmanamerica.com
Related reading: Best Affordable Phono Cartridges
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Ask an Expert
Are you a recent convert to vinyl playback? Are you records not sounding as great as you would have hoped? Your phono cartridge installation...
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
At $5,995, the Luxman L-505Z is the company's most affordable stereo integrated amplifier featuring 100-watts per channel and LIFES 1.0.
Does one need to spend more than $500 for a phono cartridge? Grado, Sumiko, and Goldring would beg to differ.
At $5,499, the AT-ART1000X Direct Power Stereo Moving Coil Phono Cartridge improves upon the AT-ART1000 with improvements in design and materials.
Rega's Nd3 MM phono cartridge is the first to use ultra-high powered Neodymium N55 magnets with a brand new generator geometry.
Ortofon's new 2MR series make it easier to install their award-winning MM cartridges on tonearms that do not offer adjustable VTA. Rega and Pro-Ject...
