Luxman L-507Z Integrated Amplifier & PD-151 MkII Turntable Celebrate 100 Years of Success
The Luxman L-507Z Integrated Amplifier & PD-151 MKII Turntable begin the 100th anniversary party slightly early.
Luxman is rather rapidly approaching its 100th anniversary and the Japanese manufacturer shows no signs of slowing down. That’s becoming a trend with a lot of the older Japanese brands like Nakamichi, Denon, and Rotel — evolve the business and release something new that responds to changing consumer tastes or perish.
Luxman sits in a slightly different position because it competes rather favorably with some of the bigger American brands like McIntosh, Audio Research, and Mark Levinson who appeal to a more traditional high-end customer that already knows that Luxman is one of the best brands to ever come out of Japan.
The company doesn’t refresh its lineup every single year and we’re only seeing a constant flow of new products now because of delays caused by the pandemic and its looming milestone.
Luxman L-507Z Integrated Amplifier Front Top
Luxman PD-151 MkII Turntable
Featuring Luxman’s original LIFES1.0 distortion canceling feedback engine, the new Luxman L-507Z is a Class AB integrated amplifier ($8,995) that promises to deliver excellent quality. The first model in Luxman’s Z Series, the new integrated amplifier joins the Luxman PD-151 MkII Turntable ($6,490), which incorporates a new, proprietary tonearm featuring classic knife-edge bearings.
The turntable retains such key advantages as a low-speed, high torque motor and Luxman’s unique sine-wave/Pulse Width Modulation power supply. “The new components carry forward the Luxman hallmarks of uncompromising sound quality, sophisticated technology and timeless design,” said Jeff Sigmund, president of Luxman America. “They’re fitting additions as we approach 2025, our centennial year.”
Luxman L-507Z Integrated Amplifier Rear
Luxman L-507Z Integrated Amplifier: The Z Series Begins
Built for discriminating music lovers, the L-507Z is the first integrated amplifier in Luxman’s Z Series, which will feature LIFES1.0, the Luxman Integrated Feedback Engine System.
First offered on the M-10X power amplifier earlier this year, LIFES1.0 is uniquely capable of reducing distortion while controlling the feedback inaccuracies that can compromise the expressive power of music reproduction. LIFES1.0 represents a substantial advance from Luxman’s signature ODNF (Only Distortion Negative Feedback) amplifier design.
It results from meticulous computer simulation using dedicated software, careful evaluation of new circuit components, extensive auditioning, and prototype listening tests.
Luxman L-507Z Integrated Amplifier Closeup
The L-507Z is also notable for prominent front panel VU meters; a large, 7-segment LED display that makes it easy to see volume level from any listening position; the “Pentaconn” five-conductor, balanced headphone jack for improved stereo separation; and rear panel 12-volt trigger for compatible home automation systems.
Luxman L-507Z Integrated Amplifier Top Open Internals
Specifications:
  • 110 Watts + 110 Watts RMS, Class AB into 8-ohm loads
  • 210 Watts + 210 Watts RMS, Class AB into 4-ohm loads
  • First integrated amplifier with LIFES1.0 (Luxman Integrated Feedback Engine System) to simultaneously reduce distortion and preserve musical nuance and microdynamics
  • Large dual VU meters with bright LED backlight, supplemented by large, 7-segment LED volume level display
  • Highly regulated power supply with new EI-type transformer and an array of eight 10,000 µF filter capacitors
  • LECUA1000 electronically controlled attenuator with 88 discrete steps, which was first featured in the C-900u control amplifier
  • “Pentaconn” 4.4 mm headphone jack incorporates five conductors for balanced output, improves channel separation for private listening, supplements the standard 6.3 mm jack
  • Home automation compatible with 12-volt trigger in/out connections
  • Robust, anti-resonant construction, including thick aluminum chassis panels and density gradient cast iron feet; weighs 56 pounds (25.4 kg)
  • Meticulous circuit design including smooth, round-cornered printed circuit board traces; beeline topology; low-impedance transmission; and carefully auditioned parts
  • Supplied wireless remote control also operates Luxman digital players released after 1996
Luxman RA17A Remote Control for L-507Z
Luxman RA-17A Remote Control for L-507Z
The Luxman PD-151 MkII Turntable
To serve the needs of the most demanding vinyl enthusiasts, Luxman is replacing the well-received PD-151A turntable with the substantially upgraded PD-151 MkII. The new deck is set apart by an original, new tonearm, the beautifully crafted LTA-309. It incorporates the knife-edge bearing technology originally developed by SAEC, a classic Japanese brand.
Other tonearm features include static balance, machined aluminum arm base, and arm height that adjusts to accommodate different cartridges. The PD-151 MkII carries forward the key advantages of its predecessor, including Luxman’s proprietary power supply and speed control technologies.
Luxman PD-151 MkII Turntable Cover Open
Specifications:
  • Supports classic vinyl with 33-1/3, 45 and 78 rpm speeds
  • Original, new LTA-309 tonearm is built around the highly-regarded knife-edge bearing technology developed by SAEC, a classic Japanese brand; achieves ultra-low friction, ultra-accurate groove tracing; arm height adjusts to accommodate different cartridges
  • Luxman’s unique sine-wave/Pulse Width Modulation power supply for ultra-stable direct current
  • Low-speed, high-torque DC motor is built on a high-precision cast alloy chassis; minimizes acoustic noise with super-smooth bearings and careful internal construction
  • Rotational speed meticulously maintained by Luxman’s Proportional-Integral-Differential (PID) feedback control loop
  • 9-pound (4.0 kg) platter uses high mass to help maintain rotational precision, offers diamond-cut finish
  • Highly rigid, 16-mm stainless steel shaft with a lower thrust bearing carefully lubricated with polyether ether ketone (PEEK)
  • Brass radial bearing filled with organic molybdenum oil supports the upper shaft
  • Anti-resonant rubber hybrid record coupling mat
  • 10mm thick aluminum top panel supports internal electrical components attachment using Luxman’s original “damped underslung hanging method”
  • Special rubber polymer damping isolates heavy electrical components from the chassis
  • Isolator feet with special damping material protect the turntable chassis from shelf-borne vibration; each foot offers 5 mm independent height adjustment
  • Available and highly recommended, the OPPD-DSC151 dust cover is 4-mm clear acrylic and includes cam/spring supporting hinges for easy opening and smooth closure
  • High-grade AC input supports the weight of heavy accessory power cables
Luxman PD-151 MkII Turntable Rear
Price & Availability
Both are available now at the following MSRPs:
  • Luxman L-507Z Integrated Amplifier – $8,995
  • Luxman PD-151 MkII Turntable – $6,490, including the optional dust cover.
For more information: L-507Z | PD-151MkII
7 Comments
7 Comments
  1. GABRIEL AWOFISAN
    September 7, 2022 at 4:11 pm
    I’ll like to purchase the amplifier only, but I live in United Kingdom, how can I purchase the amplifier? Could you calculate the amount in pounds. Kind regards
    GABRIEL AWOFISAN
  2. Brian Mitchell
    September 8, 2022 at 3:07 am
    The Luxman L-507Z should be available for £7,995.00 in the UK.
  3. Mark
    September 8, 2022 at 4:07 am
    Call me silly, but on the heat sinks, why are the transisters generating the heat so close to each other? Shouldn’t they be separated from each other?
  4. Eduardo Roxas
    September 9, 2022 at 12:56 pm
    At first glance it looks like an Altec 9440 power amp
    Anyway a Luxman is A LUXMAN a name that hi end home audio craving to own for .
  5. Yuval Goldstein
    September 10, 2022 at 12:58 pm
    Both the amp and the TT are perfect examples of Luxman’s meticulous engineering and (a tradition of excellence). I must admit both are to expensive for me, but,the company does have a distributor in my country (Israel),and I’m sure both will sell nicely for those audiophiles who have the wherewithal to purchase them
    • Ian White
      September 10, 2022 at 2:36 pm
      Yuval,
      Luxman is a really good brand that doesn’t replace their lineup every single year and the products are very reliable. When I was the “Aliyah” stage back in 2000, I visited a few dealers in Tel Aviv and someone in Herzliya, and the prices were crazy back then.
      We hope to do 2-3 Luxman reviews at the end of 2022.
      Shavuah Tov,
      Ian White
  6. Steven Denfeld
    November 11, 2022 at 1:20 am
    If I won the lottery I wouldn’t tell anyone, but there would be signs. These two righteous pieces of gear would be among the first of them.
Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
Starting at $21,600, the high-end Burmester 232 Integrated Amplifier offers DAC and Phono pre-amp upgradability for $13,300 extra.
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Advance Paris brings its range of affordable hifi components to the U.S. market, which feature blue VU meters and tube amplification.
Audio Cables
At £1,000, Chord Company's PhonoARAY can minimize external interference and ground issues that may affect turntable performance.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
