Luxman’s L-505Z Integrated Amplifier Completes the Z Series Range with Some Key Features Found on More Expensive Models
At $5,995, the Luxman L-505Z is the company’s most affordable stereo integrated amplifier featuring 100-watts per channel and LIFES 1.0.
Luxman L505Z Integrated Amplifier Front Angle Silver
Have you ever wanted to own a high-end Luxman Integrated Amplifier? The iconic Japanese manufacturer does not cut corners and that has made its components rather expensive over the past century. Quality engineering, bulletproof build quality and world class sonics come with a hefty asking price. The latest from Luxman appears to offer all of those things — but for only $5,995 USD.
And yes — $5,995 USD is a lot of money for any hi-fi component in case you think we consider that to be “affordable.” It’s just affordable for Luxman.
The L-505Z completes Luxman’s Z Series integrated amplifier line. This new model represents the latest development in a series of 505 models going back to the L-505f of 2001 while introducing significant upgrades including the Luxman Integrated Feedback Engine System (LIFES1.0) and the Luxman Electronically Controlled Ultimate Attenuator (LECUA)
Luxman L505uxII Stereo Integrated Amplifier
Luxman L505uxII Stereo Integrated Amplifier (previous model)
The L-505Z is designed to replace the previously released L-505uXII (2018) and completes the Z Series joining the L-507Z (released in 2022) and 509Z (released in 2023).
Upgrades from the 505uXII include an improved moving magnet/moving coil phono preamp, LECUA controlled LR balance adjust function, 12-volt triggers, parallel headphone output jacks including a “Pentaconn” balanced type and 7-segment LED volume level-VU meter display.
LUXMAN Integrated Feedback Engine System (LIFES 1.0)
Luxman LIFES
The LIFES 1.0 power amp stage is designed to combine the power of negative-feedback-free amplifiers with the ultra-low distortion that feedback enables. While feedback plays a major role in reducing distortion, it can compromise musicality.
To overcome this paradox Luxman developed the Only Distortion Negative Feedback (ODNF) circuit in 1999 and refined it through five generations up to 2021. LIFES1.0 now supersedes ODNF, with a redesigned circuit featuring improved distortion detection, regulation, and thermal stability.
The result is a combination of low distortion and the natural sound quality associated with “non-feedback” type circuits.
The L-505Z combines high power and precise linearity. This is accomplished by using bipolar transistors in a triple parallel Darlington push-pull configuration.
For added support, the highly regulated power supply boasts a massive, 540 VA EI-type transformer and an array of four new-generation type 10,000 µF filter capacitors.
The Class AB output stage is rated at 100W+100W at 8 ohms and 150W+150W at 4 ohms.
The Importance of the Volume Control
The volume control is often an afterthought but it can be the source of audio playback issues. Conventional, variable-resistor volume controls often introduce noise and left/right tracking errors can unintentionally shift the stereo balance as the volume is adjusted.
Luxman L505Z Integrated Amplifier Volume Control Knob
As a result, Luxman has implemented its LECUA system. This system is built around a solid-state IC precision attenuator. It delivers accurate volume adjustment across 88 discrete steps while minimizing distortion. LECUA technology is also applied to the balance control.
Vinyl Record Playback Support
The L-505Z provides several source inputs (including one set of balanced inputs) but Luxman has also paid close attention to vinyl playback with an advanced phono equalization circuit featuring a parallel first stage for better musicality. The circuitry accommodates both moving magnet and moving coil cartridges via a front-panel selector.
Luxman L505Z Integrated Amplifier Input Selector
To maintain signal integrity while enhancing the output quality, Luxman considers the preamplifier stage as a “power amp driver.” This means that the last stage of the preamplifier is fitted with discrete buffer circuitry and a high-current supply.
Status Display
The L-505Z incorporates a 7-segment LED display. This enables users to see volume levels from any listening position. Instantaneous output is displayed on large, VU meters illuminated by white LEDs for optimum viewing.
Luxman L505Z Integrated Amplifier VU Meters
The “Pentaconn” 4.4 mm, five-conductor, balanced headphone jack provides independent left/right grounding for improved stereo separation. It supplements the standard 6.3 mm jack. If desired, users can disable the display using the supplied remote control.
Trigger Control
Luxman L505Z Integrated Amplifier Rear
Rear-panel 12-volt trigger input and outputs provide home automation systems. Control input and output terminals coordinate operation with compatible Luxman components. A preamp output and power amp input enable bi-amping and powered subwoofer connections.
Internal Topology
Luxman L505Z Integrated Amplifier Internal Top Down View
Beeline topology minimizes internal signal runs. Oxygen-free copper (OFC) wiring helps ensure optimum musicality. The internal cables also protect the signal with spiral wrap shielding for each non-plated core wire. Because slight variations in ground impedance can have a subtle smearing effect on music, the L-505Z  features a loop-less chassis structure.
The L-505Z circuit boards solidify Luxman’s build approach with round-cornered asymmetric printed circuit traces to ensure smooth current transmission while resisting interference. There is also the 18-mm spacing between input terminals to accommodate high-grade interconnects. The speaker terminals offer spacing for large gauge speaker cables and Y terminators.
Luxman L505Z Integrated Amplifier Bass, Treble, Balance Knobs
Hefty Weight
To suppress vibrations that can interfere with quiet musical passages, the L-505Z weighs in at a hefty 50 pounds (22.5 kg).
Pro Tip: The supplied RMA-17A wireless remote control also operates Luxman digital players released after 1996.
Remote Control for Luxman L505Z Integrated Amplifier
RA-17A Remote Control
From Jeff Sigmund, president of Luxman America: “The Z Series is now complete, in anticipation of the company’s 100th anniversary in 2025,…The global community of reviewers, resale partners, and music lovers has welcomed our Z Series. We’re looking forward to introducing the L-505Z’s level of performance to a wide range of listeners.
Luxman Z-Series Comparison
L-505Z
(2024)
L-505uXII
(2018)
L-507Z
(2022)
L-509Z
(2023)
Price (USD) $5,995$4,695$8,995$12,495
Product TypeIntegrated AmplifierIntegrated AmplifierIntegrated AmplifierIntegrated Amplifier
Amplifier ClassABABABAB
Rated Power  Output 100W + 100W (8Ω)
 150W + 150W (4Ω)
100W + 100W (8Ω)
 150W + 150W (4Ω)
110W + 110W (8Ω)
210W + 210W (4Ω)
120W + 120W (8Ω)
 220W + 220W (4Ω)
Input Sensitivity/ Input ImpedancePHONO (MM): 2.5mV/47kΩ
PHONO (MC): 0.3mV/100Ω
LINE: 180mV/47kΩ
BAL.LINE:180mV/55kΩ
MAIN IN: 1V/47kΩ
LINE: 180mV/47kΩ
BAL.LINE:180mV/55kΩ
MAIN IN: 1V/47kΩ
LINE: 180mV/47kΩ
BAL.LINE:180mV/79kΩ
MAIN IN: 1.5V/47kΩ
PHONO (MC-H): 0.3mV/100Ω
PHONO (MC-L): 0.3mV/40Ω
LINE: 180mV/47kΩ
BAL.LINE:180mV/79kΩ
MAIN IN: 1.1V/47kΩ
Output VoltagePRE OUT: 1VPRE OUT: 1V
REC Out: 180mV
Frequency ResponsePHONO: 20Hz to 20kHz (±0.5dB)
LINE: 20Hz to 100kHz (within -3dB)
Total Harmonic Distortion0.009% or less (8Ω, 1kHz)
0.09% or less (8Ω, 20Hz to 20kHz)
0.007% or less (8Ω, 1kHz)
0.03% or less (8Ω, 20Hz to 20kHz)
S/N Ratio (IHF-A) PHONO (MM): 87dB or more
PHONO (MC): 70dB or more
LINE: 104dB or more
PHONO (MM): 91dB or more
PHONO (MC): 75dB or more
LINE: 104dB or more
LINE: 105dB or more
PHONO (MC-H): 70dB or more PHONO (MC-L): 62dB or more
LINE: 106dB or more
Volume Adjustment LECUA LECUA LECUA1000LECUA-EX
Amplification feedback circuitLIFES 1.0ODNF 4.0LIFES 1.0LIFES 1.0
Output Configuration Bipolar parallel push-pullBipolar parallel push-pullBipolar 3-parallel push-pullBipolar 4-parallel push-pull
Damping Factor 200210300330
Tone Control RangeBASS: ±8dB at 100Hz
TREBLE: ±8dB at 10kHz
BASS: ±8dB at 100Hz
BASS: ±8dB at 100Hz
BASS: ±8dB at 100Hz
TREBLE: ±8dB at 760Hz
Power Supply230V~(50Hz)
115V~ (60Hz)
230V~(50Hz)
115V~ (60Hz)
230V~(50Hz)
115V~ (60Hz)
230V~(50Hz)
115V~ (60Hz)
Power Consumption330W
90W (under no signal)
0.5W (at standby)
300W
85W (under no signal)
0.4W (at standby)
350W
86W (under no signal)
0.4W (at standby)
390W
150W (under no signal)
 0.5W (at standby)
External Dimensions (WHD)17.3 x 7.01 x 17.9 inches
(440 x 178 x 454 mm)
17.3 x 7.6 x 18.23 inches
(440 x 193 x 463 mm )
Net Weight49 lbs 10 oz
(22.5 kg)
49 lbs 10 oz
(22.5 kg)
56 lbs
25.4 kg
64 lbs
(29.4 kg)
AccessoriesRemote control (RA-17A)
Power cable
Power cable
Power cable
Power cable
Luxman L505Z Integrated Amplifier Front Silver
Luxman L-505Z Integrated Amplifier
The Bottom Line
Luxman has been making audio components for 100 years, making them one of the oldest brands still in existence (along with Denon and Yamaha). Also, Luxman joins other brands such as McIntosh, Audio Research, and Mark Levinson to name a few that occupy the high-end tier. This means that you will have to dig deep into your wallet to be able to afford many of their products.
That being said, Luxman puts a lot of thought and engineering savvy into all other product lines and their Z-Series integrated amplifiers are a prime example.
Price & Availability
The L-505Z integrated amplifier is available now at a suggested retail price of $5,995 through authorized distributors and dealers.
For more information: luxmanamerica.com
Related Reading
2 Comments
2 Comments
  1. ORT
    September 30, 2024 at 7:19 pm
    “Ah, but a man’s reach should exceed his grasp, or what’s a Luxman for?” – robORT Browning
    Stunning only covers half the experience. The other half is when you awaken and the music is playing.
    ORT
    • Ian White
      October 5, 2024 at 1:38 pm
      ORT,
      When I look at some of the current pricing of new loudspeakers and turntables, my only thought (aside from…who is buying this stuff) is that one could own a top range Luxman system for the same amount of money and that seems like an investment for a lifetime that would actually make sense. Amplifier/Pre-amp/Phono Pre-amp/CD player. I know which one I would rather own.
      IW
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Explore Craft Recordings' Record Store Day 2025 preview featuring exclusive releases from Carla Thomas, Thelonious Monk with Gerry Mulligan, and the Jazz Dispensary Night...
