CD Players
Luxman’s D-07X CD Player Supports Hi-Res Streaming & SACDs
High-end CD players like the brand new Luxman D-07X offer a state-of-the-art playback platform and DAC that can be connected to other digital devices.
Luxman D-07X CD Player
CD players are no longer just source devices but centralized hubs for all of your digital devices. Luxman are certainly not the first to offer CD players with a myriad of digital inputs for network players, laptops, and even desktop computers — but it confirms that brands have come to the realization that CD players can’t be viewed in isolation anymore. Nobody is going to buy one just for CD playback when they are trying to minimize the number of components in their system.
With CD sales in decline, some will bemoan the launch of a $10,000 CD player in 2023, but for some audiophiles with large CD and SACD collections, and high-end network players — the Luxman might make sense.
“This is a transformational period in digital audio, and the new D-07X digital player is at the cutting edge,” said Jeff Sigmund, president of Luxman America. The player supports MQA-CDs, MQA files, 32-bit/768 kHz PCM, 22.4 MHz DSD, conventional USB and Bulk PET file transfer USB sources – all in addition to stereo SACDs and CDs. From the company’s flagship D-10X, the new player inherits key technologies including the LxDTM-i disc transport and ROHM MUS-IC BD34301EKV digital-to-analog converter. The D-07X replaces Luxman’s previous D-06u.
Luxman D-07X CD Player Front Drawer Open
Luxman Original Disc Transport Mechanism-improved (LxDTM-i)
Dubbed LxDTM-i, the disc drive embodies Luxman’s understanding that exposing the disc transport to vibration and resonance can result in subtle distortion. The LxDTM-i is made in Japan and meticulously enclosed in steel top and side plates. For added protection, the physical mounting system forms an integrated structure that supports the side frame.
The drive also features an improved disc reading mechanism, a die-cast aluminum disc tray, and left-side mounting that minimizes signal paths. All contribute to reproduction of exceptional clarity.
Luxman D-07X CD Player Rear
A pair of MUS-IC BD34301EKV converters
The D-07X is Luxman’s second player to incorporate MUS-IC BD34301EKV digital-to-analog converters from Japan-based ROHM Semiconductor. The converters reflect 28 separate parameters optimized for sound quality, including aspects of circuit design, layout, photomask, wafer production and IC packaging.
For example, to optimize sound quality, selected “bonding” wires that connect the chip to the lead frame are made of copper, while others are made of gold. Using 32-bit ΔΣ (Delta-Sigma) design, the converters achieve a phenomenal signal-to-noise ratio: -130 dB. The D-07X applies a pair of these converters in dual mono configuration, delivering a listening experience of unsurpassed musicality.
Because a digital player’s master clock can become a source of subtle noise, Luxman’s clocking system incorporates two high-precision, low-jitter, ultra-low phase noise modules. These reduce noise near the oscillation frequency to a minimum.
Luxman D-07X CD Player Display
Versatile SACD, CD and MQA playback, Bulk PET file transfers
The D-07X plays a robust selection of file formats via USB inputs and the free LUXMAN Audio Player computer software. Available for Mac OS and Windows PCs, the software decodes WAV, FLAC, MP3, DSF, DSDIFF, ALAC and AIFF files.
The USB input accepts PCM signals at up to 768 kHz sampling and up to 32-bit quantizing plus DSD signals at up to 22.4 MHz/1-bit sampling. Coaxial and optical inputs accommodate PCM digital audio up to 192 kHz/24 bits.
The D-07X features Master Quality Authenticated full decoding for MQA files and MQA-CDs. MQA audio files up to 24-bit are supported via USB, optical and coaxial inputs.
In addition to conventional, “isochronous” file transfers at fixed bitrates, the USB input supports two modes of Bulk Pure Enhanced Technology (Bulk Pet) high-resolution audio file transfer. This optimizes data packaging and delivery to the converter, easing the processing load for both the host CPU and the device CPU. This in turn reduces the workload between reading and reproduction, enhancing playback stability and improving sound quality.
Luxman D-07X CD Player Top
Discrete buffer analog circuit
Luxman engineers complemented the MUS-IC digital-to-analog converters with an equally sophisticated analog output circuit. A new current-to-voltage conversion system receives the differential outputs of the paired MUS-IC chips and feeds four discrete, perfectly matched amplifier modules.
High-quality buffer circuitry minimizes output impedance, for ideal connection to any integrated amplifier or control amplifier. While many digital players require a separate low-pass filter stage, the D-07X incorporates the low-pass filter into the buffer stage. This results in uncommonly smooth analog waveforms, greater clarity and greater sonic immediacy.
Luxman D-07X Power Transformer
D-07X power supply
As always, Luxman engineers have considered, evaluated and optimized every detail.
  • The oversized power supply features large filter capacitors and an OI-core transformer 50% larger than that of the predecessor D-06u.
  • The chassis is carefully shielded against the degradations of electromagnetic interference.
  • Two levels of protection defend against the distortions caused by resonance. On the outside, density gradient cast iron insulator feet diffuse shelf-borne resonance. On the inside, damping countermeasures suppress vibrations generated in the unit itself.
  • The printed circuit boards exhibit Luxman’s signature refinements: gently curved wiring patterns to promote signal flow; heavy copper foil signal traces and gold-plated connections to minimize stray capacitance.
  • For excellent conductivity, the RCA output jacks apply gold plating over brass.
  • Rugged Neutrik terminals provide the balanced XLR outputs while a front panel Phase Invert button enables listeners to swap polarity.
  • Even the back panel AC power socket has been considered. To achieve better support for heavy power cables, Luxman engineers turned the AC inlet 180° from the conventional orientation.
Luxman D-07X CD Player Remote Control
In classic Luxman fashion, the D-07X has a clean, understated design finished in brushed aluminum, which matches the supplied RD-29 aluminum remote control. The front-panel fluorescent display has a selectable 4x zoom mode to facilitate easy reading from the ideal listening position. The D-07X is available now at a suggested retail price of $9,995.
Comparison
D-06uD-07x
Applicable disc2-channel SACD, CDSACD, CD (CD-R, CD-RW, MQA-CD)
Supported sampling frequenciesUSB input (PCM) : 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz, 352.8 kHz, 384 kHz (16, 24, 32-bit)
USB input (DSD): 2.82 MHz, 5.64 MHz (1-bit)
Coaxial / Optical input: 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz 96 kHz, 176.4 kHz, 192 kHz (16, 20, 24-bit)
USB input (PCM): 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz, 352.8 kHz, 384 kHz, 705.6 kHz, 768 kHz (16, 24, 32-bit)
USB input (DSD): 2.8 MHz, 5.6 MHz, 11.2 MHz, 22.4 MHz (1-bit)
Coaxial / Optical input: 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz (16, 20, 24-bit)
Analog output voltage / impedanceUnbalanced: 2.5V / 300 Ω Balanced: 600 Ω Unbalanced : 2.4 V / 300 Ω,
Balanced : 2.4 V / 600 Ω For SACD / DSD : 2.3 V
Frequency responseCD: 5Hz to 20kHz (+0, -0.5dB)
SACD: 5Hz to 50kHz (+0, -3.0dB)
USB: 5Hz to 50kHz (+0, -3.0dB)
CD: 5Hz to 20kHz (+0, -1.0dB)
SACD: 5Hz to 38kHz (+0, -3.0dB)
USB: 5Hz to 47kHz (+0, -3.0dB)
Total harmonic distortionCD 0.0015%
SACD 0.0011%
USB 0.0009%
CD : 0.0016%
SACD : 0.0007%
USB : 0.001%
S/N ratio (IHF-A)CD: 122dB
SACD: 104dB
USB: 123dB
CD: 122 dB
SACD: 125 dB
USB: 122 dB
Disc drive mechanismLxDTMLxDTM-i
D/A converterBurr-Brown-made PCM1792A
(monaural mode) x 2
ROHM BD34301EKV
(monaural mode) x 2
Output amplifier circuitFully balanced/high sound quality IC buffer???
Power consumption29W
1W (at standby)
37W
Dimensions440(W) x 133(H) x 410(D) mm front side knob of 2mm and rear side terminal of 8mm included in depth440(W) x 132(H) x 410(D) mm front side knob of 2mm and rear side terminal of 8mm included in depth
Net weight15.7 kg17.0 kg
AccessoriesRemote control (RD-21)
Power cable
Install software CD
Remote control (RD-29)
Power cable
2 Comments
2 Comments
  1. ORT
    March 21, 2023 at 3:12 am
    Luxman just dropped below Yorx in terms of quality Audio products. Why? Not just MQA but MQA-CD? What pray tell is next on Darth Blob’s quest to pick your pock better than Fagin?
    MQAir?
    So hey, Luxman? You are below Yorx now. In other words, you’ve bottomed out at least until DB demands rights to breathing, i.e., see “MQAir”.
    Luxman? Pfffft!
    ORT
    • Ian White
      March 21, 2023 at 10:53 am
      ORT,
      Too early for me to spit out my tea. I gave up coffee.
      Lord White
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
CD Players
At $2,399, the Shanling ONIX Zenith XST20 SACD/CD Transport is here to breathe new life into the "dead" audiophile formats of SACD and CD.
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
CD Players
At $3,000, the Denon DCD-3000NE plays any disc including SACD, DSD, CD, MP3 and FLAC at up to 384kHz/32-bit resolution.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
Fell Audio aims to attract British hi-fi buyers seeking retro aesthetics with value driven audio performance from its inaugural £1000 stack.
CD Players
Add CD playback to the Ruark R410, R610 and R810 music systems for only $350 with the new R-CD100 CD Transport.
CD Players
At $12,000, the new Marantz SACD 10 is the best CD/SACD player the company has ever made and it weighs 73 lbs.
The Cyrus Audio 40 series hi-fi components includes matching Integrated Amplifier, Streamer, CD Player and Power Supply for $16,480.
