Apps
Lumen TL800 App-Enabled Bluetooth LED Smart Bulb
Lumen TL800 Smart Bulb
Tabu Products just released the Lumen TL800, an app-enabled Bluetooth smart bulb that can be controlled via smartphone. The Lumen Smart Bulb combines the practical utility of a standard white bulb, the party fun of multi-colored lights, and the longevity and cost saving of an LED light bulb. The Lumen TL800 lasts thirty times longer than typical incandescent bulb but uses five times less power. With 16 million color options, the dimmable LED RGBW (Red, Blue, Green and White) bulb lets users customize lighting to create a desired atmosphere.
Because it uses Bluetooth Smart, the bulb can be used anywhere there is a socket. The only tools needed are the bulb and Lumen’s proprietary app, currently available for Apple and some Android models. Simply download Lumen’s proprietary app, plug in the bulb and light up the room. The bulb will turn on when in Bluetooth range of the bulb, and off when outside of the range for low power consumption, both for both the phone and the bulb.
The 400 lumens bulb is the equivalent of a traditional 40W light bulb, with much lower power consumption, Lumen is able to create the same amount of light as a conventional light bulb. Besides energy savings, the Lumen also has a longer life span, translating to obvious money savings.
The TL800 provides various modes for different occasions. Features include:
  • Call Alert Mode: Notifies users of incoming calls by flashing when the phone rings.
  • Music Sync Mode: Visualize your music by synchronizing your music and lighting effects. Music Sync Mode is customizable, allowing users to choose desired color combinations.
  • Party Mode 1 and 2: Transform any space into a dance floor with pre-programmed flashing beats that match the music.
  • Wake Mode: Mimics the sunrise in the morning, gradually brightening until it reaches maximum intensity at the stipulated wake up time.  Users can customize how long the brightening process should take, from 5 minutes to 15 minutes.
  • Romance Mode: Creates the perfect condition for a romantic date or quiet evening at home with a warm atmosphere.
  • Relaxation Mode: Simulates calming moonlight, creating a relaxing ambiance.
Lumen is compatible with the following Bluetooth 4.0 enabled iOS devices: iPhone 4S, iPhone 5, iPad with Retina display, iPod touch 5th generation Apparels Android: Nexus 7, Samsung Galaxy S4.
Price and Availability
The Lumen TL800 is available at Amazon.com for $69.99.
Nothing KEF Headphone 1 Lifestyle
Nothing challenges the Apple AirPod Max with the new Headphone 1 with Sound by KEF.
Cyrus Audio 40 PPA Phono Preamp Front Cyrus Audio 40 PPA Phono Preamp Front
At $2,899, Cyrus Audio makes a bold claim about its 40 PPA which supports MC and MM cartridges with balanced XLR outputs and upgraded...
iFi Go pod MAX wireless IEM Adapters iFi Go pod MAX wireless IEM Adapters
The iFi Go Pod Max turns wired IEMs wireless with Bluetooth 5.4, balanced amp, and high-res audio—elevating sound while exposing your IEMs’ true colors.
Dangbei MP1 Max 4K Projector Lifestyle Dangbei MP1 Max 4K Projector Lifestyle
At under $2,000, the Dangbei MP1 Max is a compact 4K lifestyle projector with Google TV, AI setup, and hybrid laser-LED tech for screens...
Yamaha YH-L500A Wireless Headphones Lifestyle Yamaha YH-L500A Wireless Headphones Lifestyle
With proprietary Sound Field technology, the Yamaha YH-L500A wireless headphones provide personalized cinematic audio for $229.
V-MODA M10 and M100 Pro DJ Headphones V-MODA M10 and M100 Pro DJ Headphones
Not all headphones are designed for all listening needs. The V-MODA M-100 PRO and M-10 are affordable headphones that provide the quality and durability...
Amazon Prime Day is July 8-11, 2025
Daily Deals
Amazon Prime Day is a four-day shopping event from July 8-11, 2025 offering the biggest discounts of the year on consumer electronics.
