Logitech Z600 Bluetooth PC Speakers
Logitech Z600 Bluetooth Speakers
Logitech announced the Z600 wireless stereo speakers that use Bluetooth to stream audio from your computer, smartphone or tablet. Three devices can be active at the same time, and switching among them is as simple as pressing pause on one and play on another.
The entire top panel of the right speaker is a smooth, responsive touch disc. To dial the volume up or down, simply glide a finger around the edge. The other controls — power, Bluetooth pairing and 3.5 mm input — are hidden discreetly in the back, along with 3 speaker drivers. Specially designed, lay-flat cables run between the speakers and the power adapter, so there’s never an unsightly tangle of wires on your desk, table or countertop.
A USB Bluetooth transceiver is included with the Z600 to allow you to connect wirelessly to computers that don’t support Bluetooth. In fact, Logitech says this method is preferred over Bluetooth to get the best wireless audio clarity for use with a PC or Mac. In addition, you can connect the multimedia speakers to any device with an audio output using the 3.5mm auxiliary input.
Pricing and Availability
The Logitech Bluetooth Speakers Z600 are expected to be available in the U.S. and Europe in August 2013, for a suggested retail price of $149.99.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Bose just expanded its Bluetooth speaker lineup with one for home and another to take wherever your path leads you.
Sony just released a new and improved version of their neckband speaker but is this another clever gadget in search of a market?
