Logitech just announced the Wireless All-in-One Keyboard TK820, a wireless keyboard with a built-in touchpad that lets you type and swipe comfortably together. Its ultra-slim design takes up less space on your desk because it connects wirelessly to your computer and streamlines navigation with a built-in touchpad. The touch area is significantly larger than a built-in laptop touchpad, so you can point, zoom and swipe smoothly and comfortably. The touchpad also supports up to 13 Windows 8 multi-touch gestures with the download of Logitech SetPoint software.
In addition to its attractive design, this keyboard delivers superior typing comfort. The Logitech PerfectStroke key system distributes typing pressure evenly across the key surfaces, so every keystroke is whisper quiet and feels smooth, even if you strike the edge of a key. The IncurveTM keys have softly rounded edges to help your fingers glide across the keyboard, so typing feels fluid and comfortable, hour after hour.
The Logitech Wireless All-in-One Keyboard TK820 also comes with a tiny Logitech Unifying receiver, which uses Advanced 2.4 GHz connectivity to give you the reliability of a cord with the convenience of wireless. The wireless connection is robust and reliable, so you can place the keyboard in the most convenient position for you and still enjoy fast data transmission with virtually no delays or dropouts.
Pricing and Availability
The Logitech Wireless All-in-One Keyboard TK820 is expected to be available in the U.S. and Europe in August 2013, for $99.99.
