Logitech MX Sound are Bluetooth PC Speakers
Logitech MX Sound
Logitech announced a Bluetooth speaker system for $100 called MX Sound. The two-piece setup is designed to complement a desktop PC or laptop with wired and wireless connectivity. It can pair up to two Bluetooth devices and/or connect one device via the 3.5 mm input. The Logitech Easy-Switch technology lets you seamlessly switch between audio sources — just pause the audio on one and press play on the other.
Logitech MX Sound offers 24 watt peak (12 watt RMS) power, high-end drivers and uniquely designed port tubes to extend the bass range. A 10° backward tilt puts the listener in the sweet spot for a better sound experience. What’s cool are motion activated touch controls that light up when your hand gets near the speaker. The backlit touch controls make it easy to adjust the volume or pair Bluetooth devices.
To conserve electricity, Standby mode is automatically triggered after 20 minutes of inactivity.
Pricing and Availability
Logitech MX Sound is expected to be available in October 2017 for $99.99.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Bose just expanded its Bluetooth speaker lineup with one for home and another to take wherever your path leads you.
Sony just released a new and improved version of their neckband speaker but is this another clever gadget in search of a market?
